02-18-2012, 10:34 AM
#31 | |
Oddometer: 123
02-18-2012, 11:10 AM
#32 |
Oddometer: 116
cluth adjustment
The easiest way I've found to adjust the clutch is to get a piece of coat hanger, cut to exactly 201mm. This is the space between the transmission housing front casting area where the cable fits through (rear surface of the transmission housing there), to the forward edge of the lever rear hook area. You can adjust the cable at both ends. When you are done you should have just a little free play at the lever. Hope that helps...
02-18-2012, 12:08 PM
#33 | |
because I can
Oddometer: 6,066
10-20-2012, 07:48 PM
#34 |
Oddometer: 123
Back at it...
Since my last post, I have rebuilt the starter and started tearing down the front end. I realized both fork tubes were bent and one was even cracked! The cracked one is stuck to the lower triple/steering stem (if that's what its called). I hope once I can pull the tube out the triple+stem will not be bent- I really would not want to replace these. Do these ever get bent? ![]() How the bike sits:
10-20-2012, 08:10 PM
#35 |
Jobless, Its OK!
Oddometer: 629
civhatch90 slid this into his first post
"Can't wait to ride it. I want to see what you old folks love so much about them...
"I remember being young Now I can look back at all the Airheads I had and why I had them. Was it because they were COOL? NAH! Was it because they handled and stopped so well right from the dealers showroom? NAH! Was it because chicks dig them? NAH! NAH! It was something deeper, rooted to my passion of riding, knowing that someday when I am old, some young guy will post on a website "Can't wait to ride it. I want to see what you old folks love so much about them... "Welcome to the passion kid
10-20-2012, 08:23 PM
#36 |
Stay Horizontal
Oddometer: 1,601
Looking at this picture I see two things. ![]() 1. The clutch arm may be too close to parallel to the gearbox. It's usually at a bit of an angle. Hard to tell, but sure worth checking and may solve the clutch adjustment issue. 2. You're about to lose the float bowl. The clip needs to be on further. You should feel a click when it seats correctly. The wire seats at both sides of the bowl. Have a good read here...http://forum.boxerworks.com/viewtopic.php?f=1&t=5461 Airbear has done the brake conversion to his single disc 90/6 and he is very happy with the result. It may even be cheaper and better than using BMW second hand bits and pieces.
R100RS Gallery, over 800 pictures... |
10-20-2012, 08:46 PM
#37 |
I like everything.
Oddometer: 353
Sad news on the front end but very awesome that you found it that way!
10-20-2012, 10:47 PM
#38 | |
Oddometer: 814
New Forks
Big Bamboo screwed with this post 10-20-2012 at 10:53 PM |
