Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 03-13-2013, 12:54 AM   #151
Padmei
enamoured
Oddometer: 3,651
Was that last picture of Saturn or Uranus
(tehehehe uranus get it tehehe)
Padmei is offline   Reply With Quote
Old 03-13-2013, 01:42 AM   #152
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,240
The 'pins' go through the pressure plates & into the clutch carrier. They work the same on the clutch carrier & the heavy flywheel.
I have two of sets of pressure plates here, one with less than 10k kms if you want to compare or (use). i've got the heavy flywheel / clutch pack in Gus at present.
Look at the edges of the pressure plates - that will give you the wear on the inner & outer lips.
Any roughness on the pressure plate will wear off - but remember you are using your new friction plate to grind it.
I didn't go Koko's route because then you likely need to keep buying specially made up friction plates - to allow for any amount ground off the pressure plate.
Tired to call you - but some one else has your work phone
Originally Posted by Padmei View Post
Was that last picture of Saturn or Uranus. (tehehehe uranus get it tehehe)
Pipe / slippers / straight jacket?
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is online now   Reply With Quote
Old 03-13-2013, 02:43 AM   #153
igormortis OP
igormortis's Avatar
Oddometer: 1,353
Tonight's entertainment...
P1050822
...tyre fitting practice.
Steve, I'll PM you my new number.
igormortis is offline   Reply With Quote
Old 03-13-2013, 09:32 PM   #154
Steve in NZ
scared/cheap
Steve in NZ's Avatar
Oddometer: 1,045
P1050822
like the wheels with rim black. which way did u do it. TIA
Cheers Steve
bike = the purple pig
Steve in NZ is offline   Reply With Quote
Old 03-20-2013, 01:48 AM   #155
Padmei
enamoured
Oddometer: 3,651
Just while I was on youtube i spied this....
Old 03-20-2013, 03:51 PM   #156
igormortis OP
igormortis's Avatar
Oddometer: 1,353
The expensive way... Re-laced and powdercoated by Woody's in the US.
Old 03-20-2013, 11:15 PM   #157
igormortis OP
igormortis's Avatar
Oddometer: 1,353
Paralever Pie...
IMG_0149
Goes with iced bearings.
IMG_0150
Also - some thoughts about my starter.
Old 03-21-2013, 09:32 PM   #158
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,426
Dude! You're lucky you didn't wreck it on that setting! 'Fan Forced' is just for turbo engine parts. Airhead BMW bits should only use the 'Classic Bake' mode
Keep up the good work
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 03-21-2013, 10:33 PM   #159
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,644
I just cooled down the bearings used the heat gun for a bit and bashed them in afterwards. Using the oven is way to risky....
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 03-21-2013, 10:45 PM   #160
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,240
Didn't you see the meat thermometer? Uniform precision heating here. None of that hairdryer namby-pamby stuff here . Unless you were concerned that Penny might deal to him for using the kitchen appliances...then, well, valid concern I guess
Old 03-21-2013, 11:56 PM   #161
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,644
Yes, my wife would kill me, I have no idea how Igor got away with it.
R1150GS
R80GS Basic
Old 03-24-2013, 03:04 AM   #162
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,539
While you have the clutch/flywheel off any thought to replacing the oil pump seal? and maybe the flywheel one?
Also the breather gasket, mine looked ok but ended up dripping oil onto the clutch.
Did you see the easy way to do tyres, involved about six tie downs and they tyre went on easy.
Voltaire is online now   Reply With Quote
Old 03-26-2013, 04:04 AM   #163
igormortis OP
igormortis's Avatar
Oddometer: 1,353
Well, I almost put a piston in the dishwasher tonight...
Old 03-26-2013, 04:09 AM   #164
igormortis OP
igormortis's Avatar
Oddometer: 1,353
Hmm... don't get me thinking about those seals again. I decided to leave them well alone, thoughts of crankshafts walking in the back of my mind. Yes, it's something I'll have to do one day, but the list is long enough and I will have an oil-proof clutch in there.
I'd seen that tyre tie down trick, but I reckon the tubeless rims might nix that idea. The shoulder where the spokes seat into might be just too tall to get it on easily.
Old 03-26-2013, 04:16 AM   #165
igormortis OP
igormortis's Avatar
Oddometer: 1,353
Will this get me carbon credits?
Top end off, to do pushrod seals...
IMG_0161
Ye-uck.
IMG_0162
IMG_0163
Times are GMT -7.   It's 02:27 PM.
