Go Back   ADVrider > Riding > Regional Forums > New Zealand
Old 08-24-2012, 01:36 PM   #106
Padmei
enamoured
Oddometer: 3,760
You suck igormortis.
Don't keep us waiting. We don't like waiting
Padmei is offline   Reply With Quote
Old 08-25-2012, 06:13 PM   #107
advNZer?
advNZer?'s Avatar
Oddometer: 2,947
igor will do....
aka BMWST?
advNZer? is offline   Reply With Quote
Old 10-05-2012, 12:30 AM   #108
Padmei
enamoured
Oddometer: 3,760
What exactly are you up to over there?
Old 01-30-2013, 11:50 PM   #109
Padmei
enamoured
Oddometer: 3,760
Originally Posted by igormortis View Post
IMG_0003
06">
r...
If one has a screechy sound when starting which compnent does one re grease?
Old 01-31-2013, 12:49 AM   #110
guzzitony
Guzton
guzzitony's Avatar
Oddometer: 170
i'd go for the turny bits, drive end bush - any bushes really. are the brushes ok?
hope that helps. cheers Tony
SHEDSAM- objects given/collected and stored in a
shed/mancave. esp car/bike parts.
guzzitony is offline   Reply With Quote
Old 01-31-2013, 11:11 AM   #111
Padmei
enamoured
Oddometer: 3,760
Thanks Tony
I found Antons writeup via Snowbum
http://www.largiader.com/tech/valeo/
Old 01-31-2013, 11:30 AM   #112
igormortis OP
igormortis's Avatar
Oddometer: 1,402
Well, this has dragged on, hasn't it? But now we've essentially booked tickets to Russia, it's almost time to get off this:
And get on to this:
igormortis is offline   Reply With Quote
Old 01-31-2013, 11:59 PM   #113
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,392
I can come around & assist supervise the (bike not house) rebuild (from a chair) anytime in the next 2 or 3 weeks if needed...
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 02-03-2013, 06:48 PM   #114
igormortis OP
igormortis's Avatar
Oddometer: 1,402
Thanks! I may just take you up on that at some point.
Old 02-03-2013, 06:56 PM   #115
igormortis OP
igormortis's Avatar
Oddometer: 1,402
Wheel bearings...
Some wisdom if you please...
When the wheels were re-done, I got the bearings done also. I understand that they seat against the hub, so the following may not be a problem, but first - let's compare with this post: http://www.advrider.com/forums/showp...7&postcount=21
The R100GS spacer in the hub has collars that center it and line up to the bearing's inner race. Looking back at my pic, they were left out and it's all floaty floaty in there.
Is it necessary to centre this spacer? What's its purpose? I'd actually like to leave it as-is if I can get away with it, 'cause that means I could tap them out if required on the road.
Old 02-03-2013, 08:00 PM   #116
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,717
I'm not familiar with the " modern' BMWs but they run ball bearings? The spacer as far as I know playing with other bikes is to prevent loading of the bearing when you tighten up the axle.
I did the Guzzi recently and the spacer was able to be moved with your finger, fitted together all good with no apparent tightness.
I have been painting my house over summer.....mainly the basement , soffits and barge boards as its brick and tile with aluminium windows....was never a fan of 70's houses until this year.....
Did you say Russia?
Its amazing what you can do with a deadline.....I built up a kombi to go overseas and had to tidy up the house for rent years
ago.... nothing like painting in the dark with lamps..... and jogging between jobs...
Voltaire is offline   Reply With Quote
Old 02-03-2013, 08:41 PM   #117
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,392
Originally Posted by Stagehand View Post
They just keep the spacer in the middle of the bore so that you can jam the axle in there without it getting all bound up, I'm pretty sure.
Originally Posted by datchew View Post
I'm guessing they provide support for the inner race of the bearing. They match it perfectly in diameter. Not exactly like preload, but support load... terminology fails me today, the gin wore off.
And what Stage said definitely applies as well. keeps junk out, guides axle installation, etc.
I went ahead and put a tiny coating of grease on the lip of each end of the spacer where it interfaces with the inside of each bearing. Just cause.
Both apply. Mine moved around as well. Enough so that I could punch the bearing out without using a blind puller.
Old 02-03-2013, 09:47 PM   #118
igormortis OP
igormortis's Avatar
Oddometer: 1,402
Ahhh, that makes sense. Yep - ball bearings, and my spacer moves around like that also.
Yes, I would have agreed with your earlier sentiment until quite recently. I'm rueing the lack of riding of late, but am quite glad for the relatively good run of fine weather this summer - means I can actually get things done!
Did you say Russia?
Yup! We fly to Seoul, uncrate the bike, ride on to a ferry, then on to Vladivostok. Point the bike West and ride to Europe via Mongolia and the 'stans.
Its amazing what you can do with a deadline.....I built up a kombi to go overseas and had to tidy up the house for rent years ago.... nothing like painting in the dark with lamps..... and jogging between jobs...
Indeed. I know what this is like.
igormortis screwed with this post 02-03-2013 at 09:54 PM
Old 02-03-2013, 09:52 PM   #119
igormortis OP
igormortis's Avatar
Oddometer: 1,402
OK, this is encouraging. I think I'll tighten everything to spec and check for binding. If everything still spins freely and is snug then leave it at that?
I like the prospect of a simpler bearing change out on the Steppes.
Old 02-03-2013, 10:00 PM   #120
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,392
Pop the side seals in each bearing, & pack a bit more grease in. Standard they have 'sufficient' to run the bearing, but more grease will keep water & dirt out. If there's too much in there, it'll just spit it out anyway, but won't damage anything.
Times are GMT -7.   It's 01:21 PM.
