01-22-2012, 05:21 PM
#31 |
Onward through the fog...
Oddometer: 1,395
Slap one of these stickers over the switch.
Stand a milk crate on the floor in front of it. Leave the front door open.
'77 Harley Ironhead 6,000 miles across Oz http://advrider.com/forums/showthread.php?t=527966 Reryder (AKA Hopper) 1977 Harley Sportster 81 BMWR100RS 01 HONDA VFR800 99 SV650 Ancient Harley 45, Snortster (Sporty engine in a Norton), Norton Atlas, Honda 350/4, Ariel HS scrambler |
01-22-2012, 08:55 PM
#32 | |
delooper
Oddometer: 6,926
JR, nice to see there's a person willing to offer something constructive! Has this forum ever degraded.
Unfortunately I can't really pitch anything to "them". For example, we have "high efficiency" toilets in the building. They're motion sensor triggered. So every time you sit down to use the toilet it will flush five times before you're done. And if you walk out without putting the toilet seat down, some kind of magic will happen where the toilet will flush once every 20 seconds or so, until somebody comes back into the room and puts the toilet seat down. The net effect of all this green technology is we appear to be using about 20 times as much water as with the "wasteful" technology. No amount of talking to the efficiency or maintenance people has had any affect. It appears that taping a ruler to the button won't do the trick -- it needs to be pressed and released. The remote idea sounds neat. I might have a go at that, provided there's enough space behind the switch so that it can be properly hidden. Quote:
01-22-2012, 09:27 PM
#33 |
Oddometer: 254
Go tell your boss/HR politetely that you feel this a safety/ trip hazard that strains your eyes? i dont know how dark it gets.
where is the simpons episode where homer uses the bird to press buttons on his keyboard?
cbr600rr |
01-22-2012, 09:32 PM
#34 |
delooper
Oddometer: 6,926
As I explained in the previous post, this is a situation where I either fix it myself in a discrete and slick way, or it does not get fixed. "Complain to the boss" is a strategy that does not work.
01-22-2012, 09:57 PM
#35 |
Oddometer: 6,951
Spend less time on ADV during the day so you can go home at a normal time?
![]() (Seriously, just get a floor/desk lamp. Don't get fired for messing with the building.) |
01-22-2012, 10:48 PM
#36 |
Oddometer: 1,395
And seriously, if you can't go to your workplace health and safety person and explain the hazard of stumbling about in the dark and get it fixed, why in the hell do you want to stay there at 7pm at night?
I used to do all that stuff too. And got no thanks for it. And ended up with health problems as a result. (hence stuck at home blabbing absolute shite on advrider) Go home. Problem solved.
01-22-2012, 11:06 PM
#37 | |
delooper
Oddometer: 6,926
01-23-2012, 07:35 PM
#38 |
Oddometer: 1,395
Sorry mate.
The absurdity of your situation with the mindless corporation refusing to put in a occupancy sensor for a conscientious employee was all to much for me. ( No wonder the Occupy movement is getting so much traction.) Back to the technical challenges of your original quest, it seems like the biggest hurdle is that switch being 110 volt switch mounted in a very small wall-mount switch box behind the wallboard, leaving no room for any kind of hidden switching device heavy duty enough to switch 110 volts. That, plus the danger of frying yourself, or at least tripping a circuit breaker and giving the game away, while trying to splice into a live 110 volt line. Not for the faint-hearted to be sure. Your original idea of hiding a compact mercury switch inside the switch box and having the bulky operating magnet temporarily mounted outside the switch box is on the right track, but mercury is not magnetic so will not respond to the magnet. A magnetic reed switch is more like what you will need. but like a 110v mercury switch, a 110v reed switch is unlikely to fit inside the wall switch box, and you cant exactly go punching holes in the wall to mount it nearby. That is why I was thinking more along the lines of an electromechanical device, temporarily mounted outside the switch box each night, that physicaly pushes the existing button in response to a remote or timed signal. This is safer and more practical than a concealed second switching device. But if you could somehow jerry rig a magnetic reed switch in there, and splice it in live, then all you have to do is hook a remote controller unit, or a repetitive timer, up to an electromagnet and a battery, find a way of sticking it over the switch at night, eg large suction cup used for lifting glass sheets, and you are all set. Still seems to me like the electromechanical button pusher would be easier to make and install. Or, why don't you pull that switch out one night and take a look at it. If you are in luck it just might, small chance, be a wireless remote signalling device. In which case you can buy another one just like it and send your own signals. ![]() Good luck with the project and let us know how it goes.
01-23-2012, 09:54 PM
#39 |
Oddometer: 7,702
solenoid, with plunger.
battery capacitor potentiometer relay suction cup or magnetic base, as appropriate. Google "decay circuit". |
01-23-2012, 09:57 PM
#40 |
Oddometer: 6,951
01-24-2012, 06:54 PM
#41 |
Oddometer: 1,395
Yikes, even more so then.
01-25-2012, 04:52 AM
#42 |
Oddometer: 852
Crossbow with soft tipped arrows?Guys at work used to make blow guns that shot foam earplugs.That is until someone put a length of welding wire through one and sharpened the end,changed the game quite a bit.Ed
amish people think i dress funny |
01-25-2012, 09:46 AM
#43 |
Oddometer: 1,855
if you start to delve into the switch AND the boss finds out, you'll probably get a really big "atta boy"- in the form of a final check.( and rightfully so)... if youre trying to get ahead, try doing it during reg office hours.
01-25-2012, 11:22 AM
#44 |
Location: The largest geological formation in the U.S.A.
Oddometer: 1,884
This is still going on? You haven't bought a floor lamp for your office yet?
Neutiquam erro. |
01-25-2012, 02:03 PM
#45 |
Mr.KTM
Oddometer: 5,093
You might be an ADVRider if:You recognize your friends by the sound of their mufflers. http://www.meetup.com/Chicagoland-Du...torcycle-Club/ Skinner screwed with this post 01-25-2012 at 02:10 PM |
