Old 01-26-2012, 03:01 AM   #46
AkBrian
Oddometer: 12,087
Originally Posted by Skinner View Post
Ok I tried real hard but don't how to embed this!
http://youtu.be/ypmI-heWqF8
AkBrian is offline   Reply With Quote
Old 01-26-2012, 06:06 AM   #47
P B G
Oddometer: 10,001
Lets think simple here.
A very slowly revolving motor with an eccentric bearing on the top mounted on a pivoting arm with a rubber band to hold it in so that when the eccentric came around it would push the button and the rubber band would allow it to ride up when the button was pushed.
Or a really cheap RC car remote/reciever, and a servo. Mount with a bit of sticky velcro, when the lights kick off fire up the transmitter and turn them back on.
Old 01-26-2012, 08:10 AM   #48
Tweaker
Oddometer: 9,589
This is not your problem. If they want you to work, it is up to them to provide you with an adequate working environment. Overriding their controls is probably against some rule somewhere if not some law.
Tweaker is offline   Reply With Quote
Old 01-26-2012, 09:17 AM   #49
difuser
Oddometer: 29
Go to the Radio Control Nuts thread down in Shiny things and ask them to build a receiver, servo, battery and suction cup device.
Hit the radio the servo arm pushes the button while the suction cup attaches to the wall plate surround.
Easily attached and removed
All from cast off parts might make it a $20 proposition?
http://www.advrider.com/forums/showthread.php?t=454360
difuser is offline   Reply With Quote
Old 01-26-2012, 09:33 AM   #50
troidus
Oddometer: 15,402
Too bad it's not a motion sensor so he could just drive a radio control car back and forth in front of it periodically.
troidus is online now   Reply With Quote
Old 01-26-2012, 02:56 PM   #51
buickid
Lets ride!
Oddometer: 310
Giant marble track that ends at the button? When it turns off, roll a marble down the track!
buickid is offline   Reply With Quote
Old 01-26-2012, 07:41 PM   #52
tucsondude
tucsondude's Avatar
Oddometer: 255
posting again....
document this and talking to boss/hr about the safety issue.
conveniently trip.
sue the shit out of the evil company bankrupting it
and retire...
isnt there some OSHA hotline?
DOCUMENT. this page does not count.
if its on the fly, please expect to get fired, charged with vandalism, and if anything is burned, ARSON CLASS 2 FELONY... ie you would get less time shooting your boss in the face.
i have been on my share of rickety ladders, at a couple jobs. however this is BS.
cbr600rr
tucsondude is offline   Reply With Quote
Old 01-26-2012, 07:52 PM   #53
the_gr8t_waldo
Oddometer: 2,130
the lads in canada...presumably, the job is too!
the_gr8t_waldo is offline   Reply With Quote
Old 01-27-2012, 10:14 PM   #54
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,764
Originally Posted by GreaseMonkey View Post
I remember reading that and thought it was some WW2 thing, turns out they were trying it in 1979, here is a newspaper article:
http://news.google.com/newspapers?ni...g=6738,2797617
I am surprised no one has suggested a more substantial button pusher:
And we have a weiner!
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 01-28-2012, 09:17 AM   #55
Peanuts
Peanuts's Avatar
Oddometer: 1,666
Maybe his wife has a similar device she uses because he spends more time in the office than in her company? Slightly softer tip, same action.... ;)
Peanuts is offline   Reply With Quote
Old 01-28-2012, 10:45 AM   #56
Dusty_Bottoms
Adventurer Ordinaire
Dusty_Bottoms's Avatar
Oddometer: 821
my invaluable contribution
or put a fan near it, you know motion and cooling of the switch
and in the spirit of offering useless but funny solutions ...
http://www.youtube.com/watch?v=-s8Gk...eature=related
Dusty_Bottoms is offline   Reply With Quote
Old 01-28-2012, 09:32 PM   #57
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,317
OK here is a Rube Goldberg possibility-
Get a low RPM motor, I see that motors made for mirror balls are 1-2 rpm:
Ten-ish $ online:
http://www.google.com/products/catal...d=0CIgBEPMCMAA
Now make an eccentric to attach to the shaft, either a disk with a hole drilled offset or some cam-lobe shape. Then attach to a board you can lean against the button or clamp to a chair and set next to the button so it can push the light switch every minute.
GreaseMonkey is offline   Reply With Quote
Old 02-01-2012, 12:18 AM   #58
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
If it's a pushbutton that starts an electronic timer somewhere, then the circuit to the switch is more than likely low volt and low current, possibly low volt AC. Get a meter and see what kind of power is available in the box, and DC/AC voltage across the switch and current through the switch. It's a pushbutton, but is the contact making or breaking, because it could be either.
Have you removed the switchplate yet? What size gang box is it? What's the available room inside? What size are the knockouts? If you need extra room , and provided the device is small enough, you can drop the device through a knockout and let it live in the wall. Take a picture.
Does the timer reset to 10 minutes if the button is pressed after say 8 minutes? What happens if the button is pressed during the day?
There may be an off-the-shelf item that can be modified to suit. I know the DIN rail timers below look big, but if something like this would work, you can take it apart and pare it down to just the essentials.
http://www.astra247.com/ProductImages/5925_lg.jpg
http://www.broycecontrol.com/SERIES/300/M1MFT.JPG
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside screwed with this post 02-01-2012 at 12:40 AM
Poolside is offline   Reply With Quote
Old 02-01-2012, 12:46 AM   #59
advNZer?
advNZer?'s Avatar
Oddometer: 2,909
Originally Posted by configurationspace View Post
As I explained in the previous post, this is a situation where I either fix it myself in a discrete and slick way, or it does not get fixed. "Complain to the boss" is a strategy that does not work.
sue them
aka BMWST?
advNZer? is offline   Reply With Quote
Old 02-01-2012, 08:02 AM   #60
the_gr8t_waldo
Oddometer: 2,130
and i thought americans were sue crazy!....by the way, there's no "fixing" involved here. it's working just the way the BOSS wants it to work.
the_gr8t_waldo screwed with this post 02-01-2012 at 09:25 AM
Times are GMT -7.   It's 06:10 PM.
