07-27-2012, 05:42 AM
#46 |
Oddometer: 346
It should, they are wider (front to rear) in the cradle.
KTM RFS/SXF hybrid http://advrider.com/forums/showthread.php?t=662808 CR500/KTM hybrid http://advrider.com/forums/showthread.php?t=757835 |
08-12-2012, 09:25 AM
#47 |
Oddometer: 346
I used a stock KTM rfs decompression cable and lever (any hot start or decamp should work)
It's not good looking but it's functional. I need to machine the whole setup out of Al, but this was quick to make. http://www.youtube.com/watch?v=WTBnl...ature=youtu.be ![]()
08-12-2012, 01:42 PM
#48 |
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 643
Looks a little bit complicated to me?
I would take the decomppression unit of an rotax engine, there you only have to mount the cable: Here: http://www.bmz.fr/boutique/haut-mote...l16--2704.html |
08-13-2012, 04:41 AM
#49 | |
Oddometer: 346
08-13-2012, 09:52 AM
#50 |
Oddometer: 643
The clamp is certainly a problem in the optical design. My intension are about the use or maintance, the way the deco is used now is pulling and open the deco, then starting the engine wjile pulling the öever to close the valve again.
The setup I mentioned and is used for Rotax engines for example is one action, a spring holds permanently the valve closed, by pulling the lever you open the the valve, when you loose grip to the lever the valve will automatical close again. Isn't this much more comfertable and easier to use? |
08-13-2012, 11:21 AM
#51 | |
Oddometer: 346
I only manually closed it in the video to show it's operation.
KTM RFS/SXF hybrid http://advrider.com/forums/showthread.php?t=662808 CR500/KTM hybrid http://advrider.com/forums/showthread.php?t=757835 jar944 screwed with this post 08-13-2012 at 11:28 AM |
08-13-2012, 11:51 AM
#52 |
Oddometer: 643
I hope this mechanism works (closes) well without any spring. When the spring is loosing tension it will get spitty around the deco in my experience, (This happend after a decade or so). They also have the tendency too loosen. I therefore check them once or twice a year if they still sit thight.
08-13-2012, 12:06 PM
#53 | |
Oddometer: 346
The valve is the standard Sthil type saw valve that is used in everything from chain saws to Harley Davidson V-twins. It has a detent that engages in the closed position to assist closing and keep it closed. This is the specific valve recommended by the Cr500 community. Also the valves themselves are only $12, so if needed can be replaced (or spares kept) cheaply.
08-13-2012, 12:55 PM
#54 |
Oddometer: 643
Ahh kind of semi automatic
08-13-2012, 03:28 PM
#55 |
Oddometer: 1
What I have been waiting for!
Would you be able to make the spacers and mounts? I have a cr500 engine and I think I may be able to get my buddies blown up 08 xcf for a reasonable price. If so, what would the price range be??
08-13-2012, 09:41 PM
#56 | |
Oddometer: 346
average price on a blown rf4 is about $1000-1500
09-01-2012, 08:44 AM
#57 |
Oddometer: 1
Hi.i m doing a cr500 ktm project too. 94 engine with a sxf 450 2008 frame. It s welded painted put together almost completly. I m waiting for the air boot and griphics. I notice that the cdi u r using ( the part attached to the frame and connected to the spark plug) is not the original one and fit perfect on the frame mount. Where does it come from? Also my brake pedal is a little too close from the case, did u have to bend it too? I really like ur blog it help me a lot on my builng. I should have it running next week end. My engine was nothing like urs, just did top end. I also have different radiators, from a xc i think, so i ll run some different hose and use the two holes on the head. I didnt have to mod much the pipe and silenceur either. Lucky on that one. Thx
09-01-2012, 11:55 AM
#58 | |
Oddometer: 1,071
09-04-2012, 05:28 AM
#59 |
Oddometer: 346
The compression is so high it closes the valve before the bike fires. I could modify the valve to stay open longer however I wanted a lever to remove the need to "find" the decomp every time I want to start it. It also makes bump starting after a stall very easy.
09-04-2012, 05:31 AM
#60 | |
Oddometer: 346
Yes the brake pedal was bent out a couple mm to clear the case.
