Old 01-23-2012, 08:44 AM   #31
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 8,319
I love that radiator gaurd! I have heard the Evotech made for my bike is so dense that is causes the fan to run more often: no good. The TT gaurd looks like it will block everything but air. Unfortunately, they don't make one for my Aprilia, so I'm thinking about getting the palmerproducts.co.uk gaurd.
I have also thought about removing my lower fender. Have you noticed additional mud build-up on the radiator without the lower fender?
High Country Herb is offline   Reply With Quote
Old 01-23-2012, 12:22 PM   #32
toro618
toro618's Avatar
Oddometer: 966
Originally Posted by WW Ronin View Post
Toro - Thanks for pointing out the line rubbing issue. Are you talking about the diagonal piece that slants up to the instrument cluster right above where the T is mounted?
Took a picture with my phone so hope it's clear enough. I circled the area that my brake line is rubbing against.
In this photo it appears like the black banjo on the T fiiting is the culprit....it's just an illusion. The cause is from the brake like that's attached to the right side of the T fitting.
toro618 screwed with this post 01-23-2012 at 12:41 PM
toro618 is offline   Reply With Quote
Old 01-23-2012, 04:40 PM   #33
Ronin ADV OP
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Toro
Thanks for the picture, I'll keep an eye on that spot.
High Country Herb
I haven't had it out yet in any real mud, but since it just rained like hell here this week I'll probably be testing that soon enough
Dan
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 01-23-2012, 06:09 PM   #34
angrywhiteguy
i wanna ride!
angrywhiteguy's Avatar
Oddometer: 154
Re the voltmeter
Is the voltmeter's backlight always on? I just got one and the light doesnt go out....battery issues?
angrywhiteguy is offline   Reply With Quote
Old 01-23-2012, 09:33 PM   #35
Ronin ADV OP
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Yeah, I had that same concern but it does eventually go out. It would be a bit ironic if the device you get to watch over the battery causes it to prematurely die.
According to the Argus website the Battery Bug draws power equivalent to a car digital clock and would take > 5 months to deplete a battery that is not charging.
Dan
Ronin ADV screwed with this post 01-24-2012 at 10:19 AM Reason: additional info
Old 01-24-2012, 10:13 AM   #36
Ronin ADV OP
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Someone asked earlier about the mirrors. Here are a pics with the HDB mirrors in and out.
They work well and are easy to pull in and out although I find you need to tighten the main bolt down quite a bit or they will move in the wind at highway speed. It also leaves a nice open view where the stock mirrors were. I may find some future use for the stock mirror attachment points but for now I just capped them.
As it turned out, the only place locally I could find these M10 x 16mm stainless allen head bolts was Fastenal, and they made me order a package of 10. So if anyone is pulling their mirrors and they want a couple to cap the attachment points, shoot me a PM and I'll send you two.
Dan
Old 01-26-2012, 12:30 PM   #37
Ronin ADV OP
Gear addict
Ronin ADV's Avatar
Oddometer: 594
So look what came in the mail today:
Looks like it will fit.
Old OEM plastic piece out of the way.
Three bolts and some loc-tite later:
It's too clean, time to go get some dirt on it.
This is one beefy, quality made piece of kit. Expensive but definitely looks like it will protect the case. Thanks to Stephan at Scefffelmeier Metall for building such a great piece and thanks to Lukas for bringing it to the ADV community attention and setting up the group buy.
Dan
Old 01-26-2012, 01:06 PM   #38
Buster714
VP of crash testing
Buster714's Avatar
Oddometer: 653
sprock cover
Beefcore! Do you have the link to the GB?
Aram :: SoloMotoParts.com :: Motorcycle Parts, Gear, and Accessories
Premier Brands / No Tax / Free Shipping / Hassle-Free Returns / Friendly Customer Service
Buster714 is offline   Reply With Quote
Old 04-03-2012, 09:58 AM   #39
runnin4melife
Oddometer: 803
WW Ronin,
Why did you relocate the T brake line hookup as opposed to running a dual banjo at the original ABS hook up near the stearing stem? I am looking at mine and that looks like the easiest option but if it is and wasn't utilized is there a reason, like it didn't work etc...?
Adam
I also PM'd you regarding some other mods if you could hit me back.
runnin4melife is offline   Reply With Quote
Old 04-03-2012, 12:05 PM   #40
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,220
Originally Posted by runnin4melife View Post
WW Ronin,
Some have done it that way.
The problem is that there are two axis of motion involved; suspension action and steering. By using the T fitting, the two actions are managed seperatly. The line from the ABS line at the steering head to the T flexes only for steering, the two lines from the T to the calipers flex only for suspension action. This makes for much less twisting and flexing of the lines and reduces the potential for binding and chafing.
I did my lines this way and have run the setup for over a year now with no issues. There is a lot of stuff in the way and not much space for the lines around it all in the area of the steering head. The reduced potential for catching on something is well worth the extra cost and effort in my opinion.
Ed
2009 BMW F800GS, 2008 BMW K1200GT
MCMXCIVRS is offline   Reply With Quote
Old 04-03-2012, 02:34 PM   #41
señormoto
Supermoto Abuser
señormoto's Avatar
Oddometer: 1,110
Originally Posted by dendrophobe View Post
Have you sized that up at all? The 950SE fender looks the same as the 690, but is a bit bigger... Most people switching over on the 800 or the KTM 950/990 Adventure have found that it's a tad too large. If you have the opportunity, try putting the 690 and 950SE fenders side by side...
Turns out the 950SE fender fits like a charm:
I have a 690 SM fender and a 525XCW fender that I'll take side by side pics of for you. The difference is rather dramatic :)
I have a feeling that there are some decisions being made on certain teams lately to make things more complex in order to ensure a certain technological standard of confusion is met.
señormoto is offline   Reply With Quote
Old 04-03-2012, 02:42 PM   #42
runnin4melife
Oddometer: 803
That makes sense, I figured that was the primary reason for that. Do you happen to have the lengths of the brakelines you utilized? Also which fork guards did you use? I have been trying to determine if I will modify the lower fender to retain the OEM guards or install something else. I have the knowledge to do a custom job I am just in a poor location away from my tools (military moved me...)
Old 04-10-2012, 11:26 AM   #43
dendrophobe
Motorbike Junky
dendrophobe's Avatar
Oddometer: 859
Looks good! I'll be interested to see the difference... I have Lukas building me a set of forks, and I'm probably getting a new fender for when I paint my Touratech tank... Might have to go with the 990 version!
Doug
Semper Fi
2009 BMW F800GS, Olive Drab
2006 Ducati Sport 1000, Black
Custom built Ducati GT1000 Scrambler, Red
dendrophobe is offline   Reply With Quote
Old 04-10-2012, 01:46 PM   #44
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,220
Brake line info in this post
http://www.advrider.com/forums/showp...&postcount=142
I just kept the original fork guards by cutting them off the low fender.
Ed
Old 04-10-2012, 10:27 PM   #45
Ronin ADV OP
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Sorry about the slow response. I haven't really been paying attention to my own thread.
Yeah the brake line lengths are noted above and also cross referenced in the first part of this thread. Those lengths worked out perfectly for me. As far as the fork guards go, cutting down the OEM fender will definitely be easier. You won't have to worry about fabricating mounting brackets which will be required with aftermarket guards like the UFO ones I used. This is probably the largest time sink of the mod as you have to spend a fair bit of time getting everything to line up / etc and you can't really do it without the bare forks to measure and tweak the final fitting of whatever guard you go with. That said, I'm very happy with the guards I went with. They offer good coverage and with the mounts I made they are bombproof and hold the brake lines really well. Now by far the cleanest approach would be to go with the single brake line / rotor like Senormoto.. I probably need all the brakes I can get so I kept the dual lines but I really like the simplicity of the single line. Not to mention you wouldn't have to worry about all those complex clearances with the T fitting.
Dan
Times are GMT -7.   It's 11:37 AM.
