Old 05-07-2012, 05:37 AM   #46
epicxcrider
epicxcrider's Avatar
Oddometer: 645
Were you ever able to sort out the error lamp with the HDB Blinkers? I'm ordering a set and hoping you'll be able to clue me in on the fix :) If not I'll let you know what I find.
Old 05-07-2012, 03:56 PM   #47
Ronin ADV OP
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Hate to say it but after several fails with aftermarket resistors I just got sick of it and went back to some smaller incandescent lamps. If you find something that works, let me know. Its too bad because I've got the HDB blinkers front and back on my Yamaha and they work great, but the BMW is another story. Every combo I tried was a no go and I just couldnt get rid of the error message. Good luck.
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 05-07-2012, 05:26 PM   #48
epicxcrider
Oddometer: 645
Did you wire the resistors in series or parallel?
Old 05-07-2012, 05:36 PM   #49
Ronin ADV OP
Gear addict
Ronin ADV's Avatar
Oddometer: 594
My electronics expertise is lacking to say the least. So I wired them according to the instructions.
I started with the Wunderlich "flash killers" (I think thats what they are called). They have and unsual setup where one resistor is wired between two lights and the positive wire and then has a single ground (If I remember this correctly, I am not in home now so I'll correct this later). That failed in any combination front and back. So then I went with Custom LED (?). These resistors were wired in between the light and the positive wire, one to each light. Again, no love. The LED blinkers would work and the rate was acceptable but I continued to receive the error code. Both Wunderlich and Custom LED claimed that the resistors would fake the bike into thinking there were incandescent bulbs still attached. But apparently the GS is a bit smarter and continued to register the error code. The lights work, it just turns on the error code the first time you activate the blinker after starting the bike. The yellow triangle then stays on until the bike is turned off again.
Dan
Old 05-07-2012, 06:27 PM   #50
epicxcrider
Oddometer: 645
Well, luckily I have an entire company's worth of electrical engineers to ask about this so hopefully I'll find a solution :)
Thanks for all the tips from your experience!
Old 05-09-2012, 04:11 PM   #51
aidriu
Oddometer: 7
I just happened to ask in my dealership about getting the LED turning signals on my bike today. When the service manager was explaining why it takes a technician 40 minutes to add the front and back signals he mentioned reprogramming the bikes computer. So it might be possible to get around this step using resistors but if your bike is in the shop you could always ask! If someone finds an alternative I'll be interested in hearing it. I'd prefer to have the LED blinkers on my bike but I'm not going to pay the same amount for labour as the blinkers cost me.
You only become a failure when you stop trying
aidriu is offline   Reply With Quote
Old 05-09-2012, 06:45 PM   #52
epicxcrider
Oddometer: 645
Thanks for the tip!!!
Old 05-22-2012, 04:37 PM   #53
epicxcrider
Oddometer: 645
I solved this - will post solution with pics soon!
Old 05-22-2012, 08:17 PM   #54
epicxcrider
Oddometer: 645
What you need to do is add a resistor in PARALLEL with the LED blinker. I added the resistor at the spot where I soldered the new blinker to the wires,
What this does is fool the computer into thinking there is an incandescent bulb installed. Unfortunately you do this by turning the power into heat but at least you don't throw a code.
Notes on the resistor -IMPORTANT-
-I used a 20 ohm resistor, but anything 18-24 or so should work. But don't hold me to those numbers!
-the resistor MUST BE RATED FOR OVER 10W power dissipation. You will be burning the power intended for the old blinker as heat, so proper thermal management is key. I used a 100W ceramic resistor attached to a small piece of aluminum.
Resistors with aluminum backing attached. Green loc-tite on the fastener and thermal paste between the thermal mass and the resistor.
Soldered in parallel before heat-shrinking
epicxcrider screwed with this post 05-23-2012 at 09:49 AM
Old 05-23-2012, 03:14 PM   #55
Ronin ADV OP
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Nice work epicxcrider.
Dan
Old 06-29-2012, 11:19 AM   #56
Ronin ADV OP
Gear addict
Ronin ADV's Avatar
Oddometer: 594
So a couple of recent additions.
I keep telling Dave at MOD I will post pics of my toolbox mounted so here they are. I mounted the MOD box inside my left SW Motech pannier rack. The SW racks certainly have their problems but one nice thing is the space allows for placement of something like the tool box. With the lock and quick detach I can also pull the whole set-up off quickly. As for the MOD box, it is top notch.
I also got tired off burning through my TKCs when I was doing more paved riding, so I had Woody make me this.
Its a 19" Excel rim, superlaced on a Rad Billet hub with Galfer rotors. I put Avon Distancias on this wheel and my 17" rear and now I have a decent road touring setup.
And for the dirt I added this.
18" Excel rim, superlaced to a Rad Billet hub with a Galfer rotor, a KTM 990 sprocket carrier and a 45 Supersprox rear sprocket. I pair this with my 21" front.
I had been running 15/42 gearing on the 17" rear so by switching to the 45 on the 18" the gearing should stay similar. If I plan any extended road trip, I may slap the 16 front tooth back on with the 42 tooth rear.
Dan
Old 09-04-2012, 09:13 PM   #57
toowheels
on a mission...
toowheels's Avatar
Oddometer: 963
Hey WW Ronin,
Thanks for posting that!
I missed it when you posted it way back when and i just bumped into it because I just "removed" my beak (I was thinking of doing it anyhow...honest).
So I was checkin out your high fender mod and all.
Glad you like the Tool Box and it worked for you.
Hope your ridin season is going well!
Dave
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
www.motooverland.com
toowheels is offline   Reply With Quote
Old 09-11-2012, 09:21 AM   #58
Buster714
VP of crash testing
Buster714's Avatar
Oddometer: 658
Lookin good Ronin! I've been melting those TKC's on the street. I have another set of stock wheels but I just couldn't bring myself to mount them up in case I passed some dirt and bent them all up too. I loved seeing those Galfer rotors on your bike... Howz it feel??? I can ride the sh*t outta this thing on the street so I can't imagine what that new front wheel is doing for ya.
Does that Supersprox bolt on to the stock carrier? Just curious why the 990 carrier was necessary with the Rad hubs......
Aram :: SoloMotoParts.com :: Motorcycle Parts, Gear, and Accessories
Premier Brands / No Tax / Free Shipping / Hassle-Free Returns / Friendly Customer Service
Buster714 is offline   Reply With Quote
Old 09-11-2012, 09:24 AM   #59
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,712
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Old 09-11-2012, 09:31 PM   #60
Ronin ADV OP
Gear addict
Ronin ADV's Avatar
Oddometer: 594
You gotta ask Woody some of those questions about the carrier / hub combo. I talked with him and told him basically what I wanted and he suggested the specifics. Of coarse they work great. The street set with the smaller front does indeed make the bike feel snappier. I'm also a big fan now of the Distancias. I really like the TKCs on this bike in the dirt, but i just burn through the damn things on pavement. I'm hoping the Distancias will last longer than the TKCs. They corner great and after watching Idle run them on his Husky they handle the dirt fairly well too.
I have been riding my WR lots lately (just got back from Utah), so I haven't really thrashed on the dirt set of wheels. All in all, if you got the cash burning a hole in your pocket, the second set of wheels is like having a different bike.
Too wheels : The toolbox is awesome! Keep making cool stuff.
Dan
Times are GMT -7.   It's 11:22 AM.
