Old 01-20-2012, 07:11 PM   #1
MuscleGarunt OP
Oddometer: 107
XR650L carburetor options?
I'm looking for a drop in replacement or kit that uses the stock airbox and intake manifold. I am aware of the XRs Only Mikuni kit which is a pumper for 450 or so and the Sudco Keihin FCR41 kit which is 550. Are there any cheaper options? I don't need an accelerator pump. Does anyone make a kit for the XR650L with a round or flatslide non pumper slide carb in the 200 to 300 range? Google has turned up nothing.
MuscleGarunt is offline   Reply With Quote
Old 01-20-2012, 07:46 PM   #2
PistonPants
Crankcase Scavenger
PistonPants's Avatar
Oddometer: 453
Why not modify or jet kit the stock CV? Good bang for the buck. De-snorkel the air box, massage the stock carb, good to go.
Peace
Piston
PistonPants is offline   Reply With Quote
Old 01-20-2012, 08:43 PM   #3
MuscleGarunt OP
Oddometer: 107
I did that, drilled the slide, dynojet kit, 58 pilot jet, desnorkel, baffle removed from exhaust. it made a huge difference. The only thing is low RPM performance is really crappy with a CV carb and only one lung.
Old 01-20-2012, 08:45 PM   #4
mcma111
mcma111's Avatar
Oddometer: 12,595
Use a XR650r carb
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-20-2012, 08:58 PM   #5
MuscleGarunt OP
Oddometer: 107
Does it fit right in with no modification or adapters? If so that sounds like the ticket!
Old 01-21-2012, 04:32 AM   #6
mcma111
mcma111's Avatar
Oddometer: 12,595
Yes it does. Here is what you need to do to the jetting:
Jetting for the XR carb is 65s slow/pilot and 165 main and a HRC needle on the second slot from the top
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-21-2012, 07:24 AM   #7
rufus
We're burning daylight...
rufus's Avatar
Oddometer: 4,247
Originally Posted by mcma111 View Post
Use a XR650r carb
I did that.
Lots better throttle response at low rpm. Smoother, easier starting. But from 1/3 throttle on up it seemed slower and flatter than with the stock CV. I changed jets about 50 times (realistically...20) and never got it to run as good as the CV does at road speeds.
I switched carbs back to back and finally went back to the stock CV.
But IT sucks.
I have an FCR on order from sudco. If that satisfies me then i will get the do 2nd and 5th gear mod.
rufus is offline   Reply With Quote
Old 01-21-2012, 07:27 AM   #8
rufus
rufus's Avatar
Oddometer: 4,247
I looked for ,but never found, an XR 600 carb. It should fit right in. My 650L has never run as good as the 600 I had.
Old 01-21-2012, 09:48 AM   #9
Wattner
Wattner's Avatar
Oddometer: 5,450
I used a Mikuni flat slide non-pumer for years.... I bet Sudco still has the parts to get it for you!
IMO, they work better than the stock CV, but nowhere near a pumper... KeiHin is the best!
Wattner is offline   Reply With Quote
Old 01-21-2012, 10:28 AM   #10
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,822
+1, I wore one completely out, then got another. xrsonly does them for an xr600 replacement carb, but they'll do you one to fit an L
It won't be enough carb for the 728 though, nor my TM40.
katbeanz is offline   Reply With Quote
Old 01-21-2012, 04:59 PM   #11
MuscleGarunt OP
Oddometer: 107
Thanks for all the replies! Great information from everyone.
Is the HRC needle something I will need to order?
Old 01-21-2012, 05:04 PM   #12
MuscleGarunt OP
Oddometer: 107
How about this carburetor? Or would the stock XR650R carb work better?
http://www.ebay.com/itm/Mikuni-TM40-...ht_2808wt_1000
Old 01-21-2012, 08:43 PM   #13
darenative
Oddometer: 208
With the R carb, your stock throttle cables need to be modified or you can purchase an R carb with throttle assembly.
I'm in the middle of the swap so I'm not a wealth of information, but the few times I've ridden the bike with the R carb, I could tell low end throttle response is hands down better the the cv carb....
darenative is offline   Reply With Quote
Old 01-21-2012, 09:15 PM   #14
MuscleGarunt OP
Oddometer: 107
So assuming I get the Mikuni TM 40 can I go with my current jet sizes from my CV carb? Everything I am reading is talking about smaller jets in this carb for same motor? Anybody done this before?
Old 01-23-2012, 07:02 PM   #15
MuscleGarunt OP
Oddometer: 107
Anyone done a TM 40? I'm about to take the plunge and be the first here pretty soon or one of the few anyway.
Times are GMT -7.   It's 08:23 AM.
