Old 01-23-2012, 07:15 PM   #16
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,412
Instead of buying that overpriced kit from Sudco that comes with the old-style slant-slide FCR, why not just grab an FCR-MX carb off any of the newer 450's? That's what I'm planning on doing.
jesusgatos is offline   Reply With Quote
Old 01-23-2012, 07:20 PM   #17
MuscleGarunt OP
Oddometer: 107
I found a good deal on a TM40 Mikuni pumper for the XR650R they say. Things I have heard say the R carb bolts right up to the L then just the jetting and maybe cables. I measured and it looks like it's a go ahead. I had a Mikuni pumper on a XT500 and that bike had mega power.
Man talk about price scalping, Sudco is spendy.
MuscleGarunt is offline   Reply With Quote
Old 02-04-2012, 09:45 PM   #18
MuscleGarunt OP
Oddometer: 107
TM40 fell through so I sourced a XR650R carb. It is a little but longer than the stock carb. It takes some pushing and wiggling to get it in the intake manifold. The bell for the air box is bigger and longer than stock but with some careful screwdriver prying gets it on all the way. Stock cables will work if you shorten the housing on both cables, not easy by the way. I went with the jetting recommended by the nice man earlier in this thread and it works great, thank you very much.
The skinny is, this does fit, but it's not the easiest. But with a little determination and swearing and busted knuckles it will work. Throttle response is way better and power is increased. Just give it some gas and it does a wheelie!
Old 10-24-2012, 03:37 PM   #19
jesusgatos
jesusgatos's Avatar
Oddometer: 2,412
Any interest in carb adapters for the newer-style FCR MX carbs? I used one of Noss' universal FCR adapters on my 650R with a 39mm FCR off a late-model CRF450 and it ripped, but the adapter dimensions weren't quite right. So we're going to have them make some custom adapters for the XR650R and the XR650L. I don't have a 650R anymore, but my buddy James wants one and I need to have some 650L adapters made for these bikes. Figured we might as well make them available. His regular universal adapters cost $65, so am guessing these will probably be a little bit more expensive, but can't imagine they'll end up costing any more than $80. It's pretty easy to find good deals on used FCR MX carbs ($300?) because there are so many of them out there (being used on virtually all of the modern 450cc motorcross bikes). So this can be a relatively low-cost upgrade, and the performance is flat-out awesome. Fitment is pretty straightforward. There are no clearance issues, so this is literally a bolt-in deal and you can even use the stock FCR throttle cables and twist-grip (stock CRF cables are perfect length with aftermarket tripleclamps and taller bars). Shoot me a PM if you want one!
jesusgatos screwed with this post 10-24-2012 at 03:47 PM
Old 10-24-2012, 05:18 PM   #20
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,563
adapter
yep
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 02-10-2013, 06:15 AM   #21
1Bonehead
Fearless of Falling
1Bonehead's Avatar
Oddometer: 1,113
Anyone put a lectron on a xrl ?
1Bonehead is offline   Reply With Quote
Old 11-09-2014, 09:37 AM   #22
gorilla2891
gorilla2891's Avatar
Oddometer: 358
Hey Steve, was this jetting for stock engine? I have been toying with my xrr carb for a while and have not found a happy place. It good on the bottom end and sluggish on top, or the opposite. I tried this setup yesterday, and bike was way down on power compared to stock Dave's carb. It was only better in second gear lugging acceleration.
So is it worth it to take it and have it tuned at a shop?If I can get better power and throttle response then I will. Or should I just live with the stock carb for now. Bike is a 14' with UNI, no snokel, fmf pwerbomb pipe and Q4 muffler. Thanks in advance.
Shawn
Originally Posted by mcma111 View Post
Yes it does. Here is what you need to do to the jetting:
Jetting for the XR carb is 65s slow/pilot and 165 main and a HRC needle on the second slot from the top
Words from the prosecutor " you have a penchant for speed don't you?"
14 XR650L, 03SV100S, 95GL1500 ANI, 88ZB50/100, 83XL600/XR
gorilla2891 is offline   Reply With Quote
Old 11-09-2014, 09:58 AM   #23
mcma111
mcma111's Avatar
Oddometer: 12,854
That jetting was supplied by CW and I ran it on my bike that had a Wiseco 102.4, 10.5cr piston. It worked OK.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-09-2014, 02:32 PM   #24
gorilla2891
Oddometer: 358
Ok. Thanks.
Times are GMT -7.   It's 06:38 AM.
