Old 03-09-2012, 04:32 AM   #46
Cat Daddy OP
Cob Artist
Cat Daddy's Avatar
Oddometer: 837
Originally Posted by cruiser58 View Post
Come on Cat Daddy, don't leave us hanging.
It's almost done. I just need some time to do the color on the gas tank and put a chain on it. I'll post pictures when I do.
Cat Daddy is offline   Reply With Quote
Old 03-09-2012, 04:55 AM   #47
CHECK_OIL
CHECK_OIL's Avatar
Oddometer: 369
Thumb
CHECK_OIL is offline   Reply With Quote
Old 03-16-2012, 06:35 PM   #48
eyedragaknee
McGuyver
eyedragaknee's Avatar
Oddometer: 2,319
175
Nice rebuild. I really like the colors.
Here is one I did
http://2wheelconnection.com/photo_player_flash.html
2008 KTM250-XCFW
2013 Beta 300 Trials
1966 Honda 305 Scrambler
eyedragaknee is offline   Reply With Quote
Old 04-15-2012, 06:51 PM   #49
Droz88
Oddometer: 33
Very nice restoration work!
The only thing that I would add is that you might as well get the autolube system working. It would only be a few extra lines/cables/banjo bolt and you'd have a much better fuel delivery system than just mixing. I have the factory service manual for your bike in a .pdf file so if you'd like it I can send it to you but it looks like you know what your doing haha.
Would you be able to give me some pointers as far as the ignition system goes? I actually picked up a 1973 CT3 the other day and am in the process of getting it running The previous owner ripped out all the electrical and basically turned it into a dirtbike just like you are doing. I saw that you redid the magneto/ignition yourself so basically I'd like to do whatever you did.
Droz88 is offline   Reply With Quote
Old 04-18-2012, 05:10 PM   #50
cruiser58
Cranky
cruiser58's Avatar
Oddometer: 8
OK, who do we have to beg for more pictures of this great project. It has gone stale and needs to be finished, I volunteer to take it off your hands and finish it.
cruiser58 is offline   Reply With Quote
Old 04-18-2012, 05:15 PM   #51
Cat Daddy OP
Cob Artist
Cat Daddy's Avatar
Oddometer: 837
Droz, no way on the Autolube. I went to a lot of trouble to make block off plates for the pump opening and shave the tabs off the frame. I knew before I ever unlocked my tool box that I was going straight premix on this bike.
Cruizer, soon. I just need to paint the tank. Other than that, it's complete. I have the tank straight and thrice block sanded slick. It's in primer and I'm letting the bodywork shrink for one more final blocking then paint.
Old 04-20-2012, 06:45 AM   #52
athomerecords25
Vintage YZ *****
Oddometer: 145
Wow. Simply amazing. I think I better start paying closer attention to detail on my 1980 YZ465 Marty Moates replica rebuild. Man this thread is wonderful. Great work.
athomerecords25 is offline   Reply With Quote
Old 04-22-2012, 01:16 PM   #53
Droz88
Oddometer: 33
Cat Daddy,
I was going to start working on the 1973 ct3 I picked up and I wanted to re-wire the ignition just like you did since mine is also going to be a pure dirtbike. Can you show/explain how you did it because I don't understand the routing or what parts need to be involved. Thanks in advance.
Old 04-28-2012, 12:12 AM   #54
Hunsta
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,458
Im with you Cat Daddy. And I hope you dont mind, but I literally stole your block off plate idea for my `76 DT250 Flat Tracker, complete with hand cut gasket and gasket cement.
I REALLY AM A NICE GUY. JUST ASK ANYONE WHO HASN`T MET ME.
Hunsta is offline   Reply With Quote
Old 05-05-2012, 08:42 AM   #55
third eye
back road loon
Oddometer: 157
cycle tech is right, remove the emulsion tube out of the carb and clean.
Looking forward to seeing it done
third eye is offline   Reply With Quote
Old 05-29-2012, 11:08 PM   #56
awshouse
Downwardly mobile
awshouse's Avatar
Oddometer: 444
Did you ever finish this thing??? Looked like you got to 90% in no time flat.
Sent from my iPad using Tapatalk HD
2008 Husky TE 610, 2008 KTM 250 XCF-W, 2004 KTM 950 ADV
awshouse is offline   Reply With Quote
Old 05-30-2012, 03:35 AM   #57
Cat Daddy OP
Cob Artist
Cat Daddy's Avatar
Oddometer: 837
It's all finished except the gas tank. I did some powdercoating work for one of my buddies who is a pro painter. I'm dropping the tank off shortly to have him spray it. Otherwise, yes, it's finished.
Old 07-22-2012, 05:39 PM   #58
Cat Daddy OP
Cob Artist
Cat Daddy's Avatar
Oddometer: 837
After nearly two months lying dormant, the project is back on the burner. I finally got the tank dropped off at my painter buddy's place last week, and today he texted me a picture. It still needs color sanding and buffing. I should get it back this week.
Now all I need is to order new tank emblems (ouch, very expensive) and a new gas cap. It's 100 percent complete otherwise.
Old 07-23-2012, 12:12 PM   #59
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,663
I gotta ask.... why didn't you powder coat the tank? Looka real nize.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 07-23-2012, 12:19 PM   #60
Cat Daddy OP
Cob Artist
Cat Daddy's Avatar
Oddometer: 837
It's a real nice tank but still needed some general all over body work. I can do some filler work under my powder but it's hard to beat what a pro can do with normal paint and body procedures.
Times are GMT -7.   It's 01:42 AM.
