Old 01-22-2012, 09:21 AM   #1
Renner OP
rockin' the toaster
Renner's Avatar
Oddometer: 2,243
R27: the super-slow resto
'61 BMW R27
Manufactured on Februyr 21st
delivered on September 28th, 1961 to the BMW dealer Lindner in Blaichach.
Despite my good intention this project has been idly occupying my garage for far too long. I'd rather be riding it.
Maybe some computer time spent running this thread will provide a bit of incentive to keep the job rolling(?)
As is common these days, plenty of other projects promise to perpetuate a plodding progress.
The good news is I plan to post a plethora of pics.
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is offline   Reply With Quote
Old 01-22-2012, 09:22 AM   #2
Renner OP
rockin' the toaster
Renner's Avatar
Oddometer: 2,243
Resources I've used so far listed here.
Shops
Craig Vechorik at Bench Mark Works, LLC...... http://www.benchmarkworks.com/
Dan Neiner at Cycleworks: ......................... http://www.cycleworks.net/
http://bore-tech.com/
http://www.ulismotorradladen.de
http://www.meyer-bikes.com
http://www.motorrad-stemler.de/index.htm
Clubs
http://bmwvmca.org/
http://vintagebmw.org/
Fora
http://autos.groups.yahoo.com/group/bmw-mono-club/
Renner screwed with this post 11-09-2013 at 05:50 PM
Old 01-22-2012, 09:29 AM   #3
Cordless
Two Wheel Addict
Cordless's Avatar
Oddometer: 2,045
Alliteration
Please post progress promptly. Public pleased as punch to peruse posthaste all pictures til that one plunger putts its ppb pb pb pb pb pb pb pb pb pb pb pb pb pb pb
CaPische?
Cordless is offline   Reply With Quote
Old 01-22-2012, 09:36 AM   #4
Renner OP
rockin' the toaster
Renner's Avatar
Oddometer: 2,243
"ppb pb pb pb pb pb pb pb pb pb pb pb pb pb pb" indeed
8 minutes into the thread and already I'm being schooled by a master
Renner screwed with this post 01-23-2012 at 04:42 AM
Old 01-22-2012, 09:46 AM   #5
Renner OP
rockin' the toaster
Renner's Avatar
Oddometer: 2,243
first bit of bling
gotta go now, not sure where I left the cam and generator.
Old 01-22-2012, 02:20 PM   #6
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,743
Following.
Needs a bunch of "before" pictures.
What is that bling in Post#5? Flywheel/clutch? It's lightened and balanced...
'73 R60/5 Toaster
Old 01-22-2012, 03:35 PM   #7
Renner OP
rockin' the toaster
Renner's Avatar
Oddometer: 2,243
Sorry, no "before" pics, and only rumors regarding its past.
The basket case included the rolling frame and painted sheet metal plus a bunch of new & old parts.
Some parts duplicated, some not correct.
This is what I brought home.
Most everything appears to be ok.
I've since torn down the engine and transmission for inspection because I don't know where the previous owner(s) left off.
Nice cross-hatch on the cylinder walls. The bore averaged 2.6755 inches, slightly under spec so perhaps it was re-sleeved?
The piston looked new.
I sent both to Bore-Tech for their carbide bore and piston coating processes.
The assembled head also looks new. Probably I'll remove the valves and inspect seats, faces, spring rates, and valve shaft & guide dimensions to verify all is within spec. Also checking for leaks past the valves by pooling gas in the combustion side and seeing if any gets past the seats.
I removed the transmission cover but am waiting for bearings before I actually pull the gear shafts. No sign of rust.
I removed the crank and found the slinger clean. Dan at Cycleworks inspected the crank which checked good, he replaced the rod bushing.
Dan also lightened the flywheel as shown above.
Richard Sheckler recommend this for better acceleration off the line.
Bore-Tech shaved the cylinder top .040" for me at his recommendation as well.
I've worked a few of the smaller issues: rewired the left switch assembly, corrected both wheel bearing stacks, bought and installed some missing hardware etc.
...but like the bike, this project has been going nowhere fast.
On the + side: yesterday I finally managed to remove the aft cam bearing.
Eventually I'd like to commute on the bike. Work is less than 5 miles away.
Renner screwed with this post 01-21-2014 at 08:49 PM
Old 01-22-2012, 04:53 PM   #8
Kai Ju
Kai Ju's Avatar
Oddometer: 1,868
Super slow
My first bike was a 1954 R25/3 that I bought when was still living in Germany, back in 1972. Bought it for the equivalent of about $15.00. Rebuilt it without restoring it, kinda wish I had brought it with me when I moved to the US.
Looking forward to watching yours come back to life.
That flywheel is a work of art. Almost a shame to hide it behind the clutch.
Looks great so far.
Kai Ju is offline   Reply With Quote
Old 01-22-2012, 05:29 PM   #9
Bill Harris
Oddometer: 7,743
But still, they are as before-ish as we'll get on this phase of the project. I've never seen the insides of a thumper before.
'73 R60/5 Toaster
Old 01-23-2012, 05:15 AM   #10
FreeTheBeast
valebat ascensorem
FreeTheBeast's Avatar
Oddometer: 3,025
Thumb Git 'er dun!
That's a nice bike! They don't make them like this anymore. You'll be so pleased to ride it once it's done.
Think beyond yourself.
The Hampster Ride - A mainly dirt route to ride the length of New Hampshire.
Max the Motorcycle - children's book written by Mrs. FTB
SmugMug Photo Gallary
FreeTheBeast is offline   Reply With Quote
Old 01-23-2012, 04:15 PM   #11
Renner OP
rockin' the toaster
Renner's Avatar
Oddometer: 2,243
Quite right.
though I don't have a handle on the bike's past, I've managed to accumulate a brief history with it.
#1 lump with the generator out
driven end of the oil pump shaft lives under a cover near the dipstick.
pushrods exit the upper pair of holes
coil ignition. these points weren't so good.
fitting the master link to this cam chain may be a breeze compared to the type 247 challenge
clutch on display
and a closer look.
Sprockets look serviceable.
Apparently I stopped taking pics during crank removal (what was I thinking).
Old 01-23-2012, 04:21 PM   #12
Beater
Freakin' Swamped
Beater's Avatar
Oddometer: 3,365
The first trip better be to the bar.
'85 R80RT G/Sified * '73 R75/5 LWB
Fred: Fascinated by All Things Simple / Easily Amused
Beater is online now   Reply With Quote
Old 01-23-2012, 06:38 PM   #13
mykill
odd
mykill's Avatar
Oddometer: 1,166
Fantastic project! I might be hitting you up for info soon-ish. I'm supposed to assemble one for a friend, he is paying me with a Montesa Impala!
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 01-23-2012, 07:12 PM   #14
Bill Harris
Oddometer: 7,743
Wonderful pics. I was a bit unsure of the details of a Thumper so I did a Google browse this morning and familiarized myself. I was really puzzled by the "Dipstick and oil-pump drive" holes nextto the pushrod tube holes...
The more I look at older BMWs the more I see familiar parts used on later models. Great heritage.
'73 R60/5 Toaster
Old 01-24-2012, 01:55 AM   #15
davorallyfan
Commonist
davorallyfan's Avatar
Oddometer: 16,190
Hmm have you ridden one? They are one of the most gutless bikes ever made.
Pretty yes... but effort and reward???
I dont mean to piss on your fireworks just letting you know.
7th Day Adventourist.
Re-incarnated
Terrafied
I have learnt a lot from my mistakes. I am heading out to make a few more.
davorallyfan is offline   Reply With Quote
Times are GMT -7.   It's 01:45 PM.
