Old 02-16-2012, 04:00 PM   #61
Renner OP
combustophile
Renner's Avatar
Oddometer: 1,559
a-Ha
very good, Night Rider. I'm enjoying your project at http://vintagebmw.org/v7/
I was looking through the Motorrad Stemler R26/R27 catalog and saw the bracket I think you're looking for on page 56, part number listed on the next page is 61 33 8 046 124.
do you have their downloadable catalog?
http://www.motorrad-stemler.de/lists/26_e.htm
The views are so easy to comprehend that I'm tempted to break out the crayons.
And FWIW the the fuse isolating the battery negative terminal from engine/chassis ground sounds good to me as well, electrons flowing from that terminal as they do.. seems to be the quickest way to stop a surge capable of torching wires or worse
This part has me puzzled
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is offline   Reply With Quote
Old 02-17-2012, 09:58 AM   #62
Night Rider
Night Rider's Avatar
Oddometer: 45
Whatsits
Exhaust Clamp?
Great link- thank-you. Pictures are much clearer than the parts book I have.
'12 KTM 200 XCW, '10 BMW F800GS, '06 HD XL1200R, '94 Ducati 900SS,'03 TTR125, '77 Yamaha RD400 vintage racebike,72 Suzuki T250J, '60 BMW R27
GBNF-'72 DT250,KZ400,Kaw 700LTD,'98HD XL883,99HD-FXDL,'99 Duc ST4,
'01 Duc 748, '05 Duc Multistrada 1000SDS,'06 BMW R1200GS, '12 HD FLSTN
Night Rider screwed with this post 02-17-2012 at 10:19 AM
Night Rider is offline   Reply With Quote
Old 02-17-2012, 02:37 PM   #63
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 2,872
I have a couple pics here, looks like they are reprints of a BMW brochure.
You may notice....I'll make them big, that the knee pads aren't paralell to the stripes and seem to come pretty close to them at the front.
Have tools, will travel!
Old 02-17-2012, 06:11 PM   #64
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 3,903
Hmmm, so the convergent stripes are a factory beauty-mark? It'll save a lot of time to not to have to re-do the stripes.
'73 R60/5 Toaster
Old 02-17-2012, 09:42 PM   #65
Renner OP
combustophile
Renner's Avatar
Oddometer: 1,559
good eye H96669.
Looking at tank stripes online I see the majority aren't parallel just as you point out.
Given the published images and the commonality of that detail, I'm tempted to assume that those stripes parallel to the pads may not be OEM handwork... but I can only speculate.
Obviously I can't compare R27 tank stripe contours to those on the /2 tank.
Small cosmetic problem is my stripes run under the pad up front, at least on the right side (haven't yet checked the left).
I bought some acetone and mild (24%) sulfuric acid today. Probably tomorrow I'll try some test patches to confirm whether or not the tank is powdercoated black with enamel stripes.
I plan to strip the powdercoat off the air cleaner cover to reveal the lettering, so I need an effective polymer stripper such as (98%) sulfuric acid or benzyl alcohol once I locate a source.
If I can remove the stripes without complications and at a later date have them re-applied at $75-$150, even if I need to ship the tank somewhere it doesn't seem too exorbitant.
Renner screwed with this post 02-17-2012 at 10:16 PM
Old 02-17-2012, 10:13 PM   #66
advNZer?
advNZer?'s Avatar
Oddometer: 2,213
wow.....until this moment i would not have given tuppence for an older bike....but those old beemers are even more attractive than my current ones( and i like them all)
aka BMWST?
advNZer? is offline   Reply With Quote
Old 02-17-2012, 10:19 PM   #67
Renner OP
combustophile
Renner's Avatar
Oddometer: 1,559
nice assortment you have there
is that another pair of mirrors I see within the depths of the garage?
Old 02-19-2012, 11:49 AM   #68
Renner OP
combustophile
Renner's Avatar
Oddometer: 1,559
fun with chemicals
As it turns out, acetone applied to the tank has no significant effect on the finish while easily softening the pinstripes.
Good to know but I didn't take it any farther than that as I'm not ready to pull the trigger on a pinstripe do-over.
The 24% sulfuric acid took the shine off the black but nothing else very quickly.
Some time ago a friend donated a half can of JASCO Premium paint & epoxy remover.
I found nothing on the can listing the chemical ingredients. Pulling up the MSDS via Google revealed a composition of Methylene Chloride and Methyl Alcohol, etc. which are described as the most effective powdercoat strippers in Wikipedia-powdercoat.
It works like a charm on my aircleaner housing cover
which now clearly indicates:
Knecht LP458
Filtereinsatz bei verschmutzung
oder nach ca. 10000 km austauschen
Nicht reinigen! Nicht einolen!
or near as I can tell:
Filter for contaminants
or replace after about 10000 km
Don't clean! Don't oil!
good to know the engine has schmutz-protection
This particular JASCO product is a convenient semi-paste for better control, making easy work of stripping local areas.
Next, the frame serial number.
Old 02-19-2012, 02:01 PM   #69
Bill Harris
Oddometer: 3,903
Good deal. MEK is useful stuff, albeit deadly.
On the instructions, they usually tell you to "check or inspect" (prüfen) the filter at so-and-so kilometerage. And yes, dose verschmutzen will really mess up der ringen...
'73 R60/5 Toaster
Old 02-19-2012, 04:14 PM   #70
Kai Ju
Kai Ju's Avatar
Oddometer: 1,026
Translation
The actual translation is as follows:
Knecht LP458
Replace filter element when contaminated or at 10,000 km.
Do not clean ! Do not oil !
If you need anything translated during this build let me know, I could use the practice.
Kai Ju is offline   Reply With Quote
Old 02-19-2012, 04:46 PM   #71
Renner OP
combustophile
Renner's Avatar
Oddometer: 1,559
Thanks. Will do.
So many times I've kicked myself for not continuing past German 101.
Old 10-22-2012, 02:13 AM   #72
R27warrior
Oddometer: 17
R27 info
Hi Scott,
Thanks for your e-mail and found your (actually: this) thread.
Yes, you´re right, I have an R27 since 1989 and still have a lot of fun with ´her´.
In the Netherlands we have an active club of BMW Mono owners, the BMW Mono Club, with 550 members (yes: as some members have more than one mono, you now know how many BMW thumpers are still here!).
Incredible restoration! I only have some doubt about a lighter flywheel. The R27 is famous compared with its predecessors (R25/.., R26) because of its smoothness to ride. I can ride for hours because of the ergos and just because its lack of vibrations (rubber mounted engine; be very carefull using the OEM rubber shocks). Most members don´t enjoy nor expect acceleration from a mono. Matter of taste, ultimately.
Two years ago we had a club meeting in the middle of France (Langres). In one week my mate and I rode 1.300 troublefree kilometers.
Concerning the documentation you have: that´s probably all what you can get. The BMW Mono Club has issued a book with all kinds of specialty subjects, but it is written in dutch. If you still want that book I can arrange that for you.
Please, feel free to ask about the R27, but as far as I can notice you probably know more than I about it!
Rob
R27warrior is offline   Reply With Quote
Times are GMT -7.   It's 01:51 PM.
