Old 12-23-2012, 10:03 PM   #241
TXjames
High Sider
TXjames's Avatar
Oddometer: 1,095
Originally Posted by cjack View Post
Max BMW has a fiche on line to look up parts. The part # is 16147675547 and costs $144.
There's much to be said for the warranty on this issue. It has been a defective part causing this issue, no matter what full moon BMW blames it on. The break is right at the place where the connector connects to the strip encased in an epoxy block. The strips I have replaced were perfect except for the break that couldn't be accessed.
Where exactly is this break? Can you use the diagram in my previous post to describe? Thanks cjack
Roll The Bones V - No premature incinerations. Oct 24-26, 2014.
http://www.rollthebonesrally.com/
TXjames is offline   Reply With Quote
Old 12-24-2012, 06:11 AM   #242
GSAragazzi
GSAragazzi's Avatar
Oddometer: 1,596
First off thanks for the info. I take it that vibration is what breaks it. Well, I think I'm going to have the dealership "fix" it. I have no idea where this part connects. And I think I rather pay for it once and have them deal with the issue afterwards.
Kinda weird that thisis not a recall issue
"The Only Easy Day Was Yesterday"
GSAragazzi is offline   Reply With Quote
Old 12-24-2012, 09:14 AM   #243
JStancampiano
PhotoJoe
JStancampiano's Avatar
Oddometer: 395
They won't recall broken fuel line fittings spraying gas all over hot engine, no recall on cracking fuel flanges leaking fuel, no recall on failing abs units, none either on fuel pump failing And you think it's weird that a faulty fuel gauge is not recalled. This all on one 07 GSA with 56k miles on it. It's not that I don't agree with you, but at least you didn't have to get a trailer ride home. It seems that there are different standards for auto recalls than motorcycles (most likely due to numbers)
Sorry for the rant, my abs just went out and it set me off
Joe
2007 R1200GS ADV, 1978 R100T, 2009 FJR
JStancampiano is offline   Reply With Quote
Old 12-24-2012, 09:36 AM   #244
GSAragazzi
GSAragazzi's Avatar
Oddometer: 1,596
Joe
Wow! Have you seen my thread?
http://advrider.com/forums/showthread.php?t=850715
I guess I have tons of more "issues" to look fwd to and befriend my stealership?
And you have at least one (fuel strip) to look fwd to.
Hey Merry Xmas right?
Old 12-24-2012, 01:46 PM   #245
JStancampiano
PhotoJoe
Oddometer: 395
It makes me crazy because of all the great BMWs I have had in the past with no problems...I guess I got spoiled.
Joe
Old 12-25-2012, 03:32 PM   #246
GSAragazzi
GSAragazzi's Avatar
Oddometer: 1,596
Joe
I think the solution is to buy the most basic GS possible. When I was shopping for my GSA I wanted -everything- ESA, Abs,tpms etc. Now I get it, I should have bought a non ESA and added Ohlins, no tpms or even the factory fog lights (i run Piaas now) less to worry about you know. Not that I am but less electronics the better.
Stiill love Olga (my bike) best bike I've ever had regardless.....
Old 12-27-2012, 08:35 PM   #247
rgb2cmyk
rgb2cmyk's Avatar
Oddometer: 255
My issues with the fuel strip have been slightly different than others. This on an 09 GSA:
AT 1,200 miles on the clock the bike would crank but wouldn't start. I got it started a couple times, then finally it just wouldn't start. Had it towed to the dealership. They replaced the strip, and all was well for about 10,000miles.
11,000 miles the strip dies and I get the blinking triangle.
Strip replaced again. Now the strip works, but at about 200 miles on the tank, it drops to 30 miles of fuel left. By 230 miles it says 0 miles left, and at 300 miles I run out of gas. Yet when I fill up the tank I only put in 7 gallons.
The same issue of consistent inconsistency persists through 3 more fuel strips, and two more times at the dealer for 'reprogramming' and the problem was still not resolved.
I never did solve the problem, Sandy totalled the bike and I replaced it with a 2012. I figure with a 2012, I don't have to deal with the fuel strip so I'll have more time to focus on the FD and other issues.
_
14 R1200 GSA (Hopefully lasts longer than 2yrs)
12 R1200 GSA ("Sandy") (Hit by DUI)
09 R1200 GSA (Totaled by SS Sandy)
06 Husky TE450, 04 R1100s BCR, 03 F650CS
rgb2cmyk is offline   Reply With Quote
Old 12-27-2012, 09:24 PM   #248
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 4,959
My guess too. Mine started having intermittent problems after my GS took a nap, after a few days of intermittent problems it failed permanently.
A drunk driver killed someone I love
WeazyBuddha is offline   Reply With Quote
Old 03-03-2013, 04:22 PM   #249
JayElDee
not saying what I mean
JayElDee's Avatar
Oddometer: 615
resurrecting this.
the problem is still there.
Recently there seems to be renewed interest in filing complaints about the fuel strips that work for some and never for others, and sometimes sort of work maybe.
Coming from an 1150, with its totally reliable low fuel light coupled with using my odometer, the difficulty of getting a reading of fuel remaining on the 12 is more than an annoyance. It's distracting and as such can be a safety issue, especially if you run out of gas at an inopportune time.
It is easy to file a complaint with the US DOT NHTSA. go to this link https://www-odi.nhtsa.dot.gov/ivoq/index.cfm and follow the prompts.
Say it is the "fuel/propulsion system." Those who have filed on other forums hav entered a file for every failure.
The New YorK Times reports that R series bikes are already being investigated for fuel leaks.
http://wheels.blogs.nytimes.com/2012/11 ... torcycles/
and that was after only 28 complaints.
If you have or have had the problem please report. There are many many of us that still are dealing with it and your input will help us. We are a community.
I am enjoying the bike, but I would enjoy it more if I could forget about running out of gas. But, there is no way to not think of it as it has happened twice in three months of ownership and two fuel strips. My third goes in next Saturday.
The "gauge" is unreliable.
The low fuel light is integrated into the fuel strip, so consequently it is unreliable, and may not even illuminate even when the tank is dry.
Using the odometer can be marginal help as it seems the fuel consumption varies pretty widely depending on conditions, like headwind, or speed. I have had a tankful last as few as 180 miles and as many as 222 miles with some gas left. And those numbers were highway miles, do I need to think in different terms when in the city? Probably. Or, I suppose you can spend your time at the gas station, filling every hundred miles or so to be sure you don't run out.
Interestingly enough, there was a immediate recall of the 5 series BMW car when their gas gauges were faulty and the national highway safety agency called it a safety issue. Is it any less so for a motorcycle? Could argue that it is more of one.
This bad/faulty design is complained about on all bmw forums, it's all over. There are those who say to use the odometer, but that does not work for me. I do use the odometer. I now carry extra gas
So, please consider filing a complaint with the DOT.
John
JayElDee is offline   Reply With Quote
Old 03-03-2013, 05:27 PM   #250
Juggernaut
Juggernaut's Avatar
Oddometer: 143
So I finally train myself to just use my odometer to gauge my fuel, then the 60K service reminder won't turn off to read it, so I have to pay $60 at the dealership to have it reset. Boy, BMW sure has us by the balls.
Juggernaut is offline   Reply With Quote
Old 03-03-2013, 05:35 PM   #251
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,127
Find someone with a GS 911 and pay them for a serial # use to reset.
Or better yet buy one yourself.
Old enough to know better....
Young enough to try it again
GS Addict is online now   Reply With Quote
Old 03-03-2013, 06:17 PM   #252
Juggernaut
Juggernaut's Avatar
Oddometer: 143
Talked to a few GS riders this weekend. None of them owned one, but the search continues. I still haven't found any reason to justify the $300 cost of getting one for myself.
Old 04-25-2013, 03:20 PM   #253
Kr3w
Oddometer: 13
Fuel Level Sensor Strip Repair Tool
Greetings!
I suffered the expected Fuel Level Sensor Strip failure last weekend, and after reading through this thread, I found inspiration for a fix.
I want to give a 'shout out' to JoelWisman, Old_Don, TXjames and jzeiler for their contributions--unknowingly--to me in this thread!
After reading Joel's fix using a megger and a picofarad capacitor to drop the high voltage (HV) across the broken strip, I was already thinking...piezoelectric component. We use them in aviation. So, I decided to use a very common one. A fireplace lighter. Below are the steps I took to construct the 'device'. I used common hardware found in aviation repairs, but you can substitute as needed.
This is the original fault, a bad fuel level sensor strip. Verified with a multi-meter showing an 'open' circuit between pins #2 & #3.
1. The very common fireplace lighter being disassembled. Slide the black cap forward (not shown) and remove the one screw. Note yellow arrows.
2. Splice in additional wire. I used 18 gauge wire and covered with heat shrink tubing.
3. I applied additional heat shrink tubing for added strength.
4. First yellow arrow is high voltage or self healing tape to insure a better fit. Second yellow arrow is reinstallation of the safety switch.
5. Slide the black cap back on and reinstall the screw.
6. I used some connector pins flatten out with a vice. You could use smaller automobile blade type connectors too. (check the fit before crimping to the wire)
7. Be sure to cover the pins with heat shrink tubing to prevent electrical arcing between the two pins.
8. The completed fuel level strip repair...err...device.
9. Gas tank almost full (fill it up if you can) and battery disconnected. Install the 'device' between pins #2 and #3, order does not matter. UPDATE: Pull the trigger 4 to 6 times (feedback from other ADV members suggest this is the average) and remove. Since your here go ahead and install the 'device' on pins #1 and #4 (the heater strips). Again, pull the trigger 4 to 6 times and remove. Reconnect the fuel level strip connector and battery. (I always disconnect the battery when performing electrical work, but it is not required for this fix)
10. Success!! Result after using the 'device'. The bike should be on the center stand and the side stand MUST be up. You must start the bike and let it cycle through the preprogramed 90 second fuel sample for the fault light to extinguish.
Congratulate yourself on saving $142.00 for this repair! Use the money saved by taking your mates out for a pint!
The 'device' can emit a small HV charge. Please use responsibly around children and small animals!
'09 GSA
'92 K75s
"If loud pipes save lives...imagine what learning to ride could do!"
Kr3w screwed with this post 06-12-2013 at 12:13 PM Reason: Feedback from you guys. Thanks!
Kr3w is offline   Reply With Quote
Old 04-25-2013, 03:39 PM   #254
teomannaskali
teomannaskali's Avatar
Oddometer: 772
I have a 2005 gs, and luckily i have not had the fuel strip fail yet. Thanks for the device info, now i know what to do if indeed it does fail.
I am curious on one thing though, what is the algorithm that tells me how many km i can do with the remaining fuel. Is it just a guess with a fixed consumption rate or does the ecu actually measure how much my consumption is and decide according to that?
Teoman
teomannaskali is offline   Reply With Quote
Old 04-25-2013, 07:36 PM   #255
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
Fantastic k3rw! A piezo igniter hadn't occurred to me, but of course it would provide a high voltage to jump the break and enough current to weld or carbonize it just like the electronic meggar would. Oficer thinking!
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Times are GMT -7.   It's 05:27 PM.
