01-22-2012, 11:35 PM
#1 |
Iron toocus
Oddometer: 935
Multicylinder 2 stroke into one expansion chamber?
Has this ever been done? Every performance exhaust for 2 stroke multi's has an expansion chamber for each cylinder.
Just curious.
2009 Aprilia SR50 R Factory 2012 Bont Vaypor Custom 2pt My drivel \/ http://chillislives.blogspot.com/ |
01-23-2012, 12:00 AM
#2 | |
Oddometer: 1,594
Two cylinders into a common pipe should work, as long as they're both in synch as the TZs were. |
01-23-2012, 12:37 AM
#3 |
Crankcase Scavenger
Oddometer: 296
Snowmobiles do it all the time.
Piston |
01-23-2012, 03:33 AM
#4 |
turd polisher
Oddometer: 772
I've seen 3 into 1 pipes offered for GT750's. What I understand is that they run great, but give a strong midrange, not a top end hit.
I wouldn't bring her home to Mama, but Mama ain't home tonight. |
01-23-2012, 07:02 AM
#5 |
MACDADDY!
Oddometer: 395
01-23-2012, 07:48 AM
#6 |
Oddometer: 4,314
An associate will build these for RZ350 Yamahas.
When injustice becomes law,resistance becomes duty. Thomas Jefferson |
01-23-2012, 07:58 AM
#7 |
One wheel wonder...
Oddometer: 6,310
Yep, my old Yamaha Phazer does. That pipe above is quite a piece of work!
"Tough times don't last, but tough people do." Robert A. Schuler
01-23-2012, 09:24 AM
#8 |
Iron toocus
Oddometer: 935
I didn't think to look at the snowmobile market.
That pipe above looks great!
01-23-2012, 02:10 PM
#9 |
Oddometer: 8,233
Rediculous how on earth will your GF burn both calfs with out twin pipes
![]() BTW that 2-1 is sexy looking
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby '08 KTM 530 EXC 79 RD 400 Daytona |
01-23-2012, 03:12 PM
#10 |
Oddometer: 4,314
If anyone is interested I've asked Glyn (the guy who built the 2:1 pipe) for permission to put some contact information up here. Here's a set of pipes he makes for +4MM stroked RZ350's-$550 CAD. He does all sorts of engine work for road going 2 strokes.
01-23-2012, 03:53 PM
#11 |
Oddometer: 818
I rode one, 25 or so years go. Good mid range, good top end, much faster than a stock GT 750. Probably not as good on top as three separate pipes would have been, but I never rode one like that, so I don't really know..
01-23-2012, 08:40 PM
#12 |
Oddometer: 105
2 strokes will always make the most horsepower with ONE individual expansion chamber per cylinder.
As soon as you add 1 or 2 more cylinders to the mix, the soundwaves (for lack of a better explaination) begin to collide in a way that disrupts the whole purpose of an expansion chamber.... Cramming unburnt mixture back into the cylinder before the port closes. There is a guy working on a 3 into 1 for a Kawasaki Triple that will have interchangeable "chambers".. all made to work at different RPM's. It will be pretty cool to see how it all turns out. Ive had a few different old-school brands of 3 into 1's on H1's and H2's and they all work the same... Good low end and midrange grunt......but at 6 grand or so, absolutely shut off like you are hitting the kill switch. 6 grand on a triple is where the fun is supposed to start, not stop. Ive also ridden a buffalo with one of Omar's 3 into 1's and it ran well. Buffalo's were never high revving, so you didn't really miss that last 1000 revs.
Electric start? |
01-24-2012, 09:51 AM
#13 | |
Oddometer: 29
This is still in the very early stages of development, but has shown some goos results. With the post quoted your are right to a point about the pulses getting confused. But the way the crank is phased plays a huge role in the end result. As this is going onto a parallel twin that is phased at 180* this is in my favour. The first one was dyno'd last week in Germany, a different design to the one shown here but the same principle. It did quite well for it's first run only 4hp down on the 2-2 set up he was running and it peaked at 9400k against his 9700k with the 2-2. I will agree that a 3-1 is asking for trouble and will never be able to give you any top end power to speak of, but the 2-1 with a 180* can be made to work really quite well. How fare I'll take this I don't know as I am time limited at the mo, but I know that it will be as good as any after market off the shelf pipe currently out there. Glyn |
01-24-2012, 11:36 AM
#14 |
Oddometer: 4,314
Welcome to the Jungle Glyn.
01-24-2012, 06:12 PM
#15 | |
Oddometer: 105
Cool Glyn...and I do agree that with 180 phasing, if the 2 into 1 is designed well enough (and it sounds like you are definately on the right track!), you will not have nearly the "problems" with soundwave turbulence that one would have with a 3 cylinder.
How was low end grunt compared to the 2 into 2? Thats actually quite impressive that it was only 4hp and 300 revs down on peak. Quote:
Electric start? |
