Old 01-24-2012, 02:26 PM   #16
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,493
Originally Posted by Carl View Post
The innermost bead, at best, out of the three in the pic might take some patience. A better pic, or better eyes for me, would show which direction the torch traveled. The glare and blue is a bit tricky to focus on to get a good read on their process.
Carl
I think we're talking about different beads. I'm talking about the ones WAY up in there. Not the three separate colinear beads closer to the camera. Here's another photo minus the paint:
Here's another one. Take a look at the discoloration here. See that little additional triangle above the existing gusset? I think they doubled that whole gusset by adding another plate to the back. The stitches all along the edges seem to confirm that.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 01-24-2012 at 02:38 PM
Old 01-24-2012, 03:12 PM   #17
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,486
According to an HPN build I've read they do double up on those plates. Think we could talk to the guy that's making these to make the other braces? Who is he anyways? If I'm going have my frame bead blasted and re-powder coated I want to add as many gussets as I can.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 01-24-2012, 03:17 PM   #18
Airhead Wrangler
Adios Mexico
Oddometer: 6,493
Judging by the photos Solo posted, I'd say they're coming from Paul Rooney in Oz. Call the man. I PMed you his contacts info.
Airhead Wrangler screwed with this post 01-24-2012 at 03:25 PM
Old 01-24-2012, 03:51 PM   #19
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,804
These plates are being cut by a guy in CA, not OZ..... and are based on a Paul Rooney kit that another CA member has. Is this kit complete? I don't know...
I stepped out of this because I don't have the time and $$ to front a purchase...
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 01-24-2012, 04:00 PM   #20
walkingbear OP
walkingbear's Avatar
Oddometer: 3,498
the order
Should I contact him about adding another piece or is everybody ok with this?
I'm have my frame blasted and then repaired and adding the reinforcements.
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 01-24-2012, 04:05 PM   #21
Airhead Wrangler
Adios Mexico
Oddometer: 6,493
Solo-
Those bikes in the photos were very recognizably "Rooneyish". If you can wait a bit, I might let you touch my frame with a pair of calipers. Houseoffubar could probably take care of the rest. Just saying...
Old 01-24-2012, 04:20 PM   #22
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,804
Solo-
Please define "a bit"
No doubt houseo' could do the job....
R65LazaruS
Old 01-24-2012, 08:11 PM   #23
ontic
Oddometer: 1,070
If these are an accurite copy of Rooneys gussets then I imagine that you guys would be getting all the gussets pictured earlier, except you would be getting two of these ones- at least you should be getting two of these ones
I feel a little funny posting photos of Pauls work in a thread about buying copies of his gussets. But, he is a great and helpful guy and has been so helpful and free with his knowledge and experience with me so I am guessing it might be OK. They are just a few bits of metal after all.
anyway,
here is some shots of his work, which I hope are detailed enough to speak for themselves,
Originally I was looking into buying a set of gussets from Paul. Despite being happy to unleash my awesome () tig welding on my subframe and luggage racks I have banned myself from welding on the mainframe. I think I have found a couple of welders down here who would have the skills required to do the welding. However none of them have actually done this before (to an airhead frame), Paul has done a lot of these and he also has the ability to check if the frame is straight. I don't want someone to learn how to do it on my frame.
For myself, I am just going to bite the bullet and send my frame to Paul to do his work on. The price for the work, including a powdercoat is actually very reasonable IMO. (probably only suitable to Aus and NZ)
And just a note about Paul's work and gusseting from what I have pieced together over a few conversations- with the disclaimer that these are my thoughts and impressions not Pauls words.
Paul is not (partially or fully) copying HPN's work. Paul does and has done his own work and has some different ideas about airhead builds than HPN do (check out the headtube extension and Pauls use of smaller offset triple clamps for an example). This is not to talk either HPN or Paul up or down. Pauls gussets are all in place due to particular failures in particular places on particular bikes he has built in the past. The gussets are there to fix actual issues that have occurred with built-up and ridden (very) hard airheads. This isn't looking at the frame and saying 'what I can reinforce next'... it is more 'why did that happen and what needs to be done to stop it happening again'.
In a good way I see this as kind of a trial and error process- which frankly having done a little reading into the engineering required for gusseting properly I am happy with compared to blindly over-gusseting and reinforcing (not saying HPN do this, just saying it)- with the advantage that I can sit here and benefit from many years of trials.
If Paul gets some more funky frame failures in the future then his gusset kit may grow to accommodate this (if a gusset/reinforcement would fix the failure) but at present, and with a lot of builds and hard riding to test it, this kit seems to work very well for him and his customers.
For instance he doesn't replace the upper shock mount with a beefier bit of metal and welds like HPN do (or sometimes do?), because well, he's never had a problem there- and this is with ridden hard RTW and rallye bikes with 50-100mm rear end extensions and big front ends.
I've only talked to Paul on the phone so far, but I really like his attitude and approach to this stuff. It makes sense to me. If anything that is what I am trying to translate here- the way he has thought about but more importantly practically figured this all out for himself- with obviously different outcomes than HPN (and really, most often a different purpose in mind).
Personally I wouldn't be worried about one of Pauls actual gusset kits being sufficient for how I will ever use my G/S, I'd just be worried about finding the right welder to do the work.
finally, just a little bit of eye candy,
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 01-24-2012, 08:18 PM   #24
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,804
Problem solved, thanks ontic!
Clearly this kit needs two of those braes, one for each side of the steering head tube.
R65LazaruS
Old 01-24-2012, 08:26 PM   #25
_cy_
Oddometer: 6,177
I'm in for a set.. don't when it will be TIG on, since my frame is freshly done.
Old 01-24-2012, 09:13 PM   #26
Carl
Carl's Avatar
Oddometer: 767
You weren't specific about which weld(s) and the ones you describe as being WAY up in there weren't very visible in the first posted pic. Still, there are plenty of welders that can 'handle' this weld task. That includes physically doing the welding and having the understanding of 'how' to weld it.
Carl
http://www.flyingtpot.com/
Carl is offline   Reply With Quote
Old 01-25-2012, 11:33 AM   #27
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,486
I can't believe there isn't somebody in the US that does this. Has anyone reached out to Houseoffubar about welding their's in? If not, I likely will.
Old 01-25-2012, 11:35 AM   #28
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,804
He is going to weld mine in (at least we discussed it)... getting the pieces is what 'bear is doing for us
R65LazaruS
Old 01-25-2012, 04:47 PM   #29
walkingbear OP
Oddometer: 3,498
Next step
I've emailed Tad the cutter. I sent him pics of the braces on the bike and will need to get new pricing.
So, the price set is not the price. Will let everyone know when I do.
TIA ...
Old 01-25-2012, 06:03 PM   #30
igormortis
igormortis's Avatar
Oddometer: 1,351
What ever happened here? Apparently a lot of hard work was put in by a very generous inmate with the promise to share freely.
Maybe inappropriate to post here, but it does seem a shame not to follow this up.
igormortis is offline   Reply With Quote
Times are GMT -7.   It's 06:29 AM.
