Old 03-26-2012, 08:23 AM   #61
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,978
Originally Posted by One Less Harley View Post
I would have hoped the fabricator would have cut the "hole" on for the pivot area with a hole saw to follow the radius more closely. Did he have to open to hole up to get it to fit? IF the opening was cut with a cutoff wheel but be careful for any straight cuts radiating from the "circle" as that gives a good place for a stress fracture.
Same question from me.... those cut look really sloppy and not what I expected at all....
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 03-26-2012, 08:25 AM   #62
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,978
Originally Posted by Airhead Wrangler View Post
Also, that plate completely blocks off where your stock wiring harness is supposed to run.
In the Rooney pictures, that one is in the middle of that area, allowing for the wire runs.
R65LazaruS
Old 03-26-2012, 09:15 AM   #63
walkingbear OP
walkingbear's Avatar
Oddometer: 3,582
cuts made
The cuts were done on a CNC machine. I watched as they being cut.
You will have to mold the pieces to the pivot of the frame.
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 03-26-2012, 09:31 AM   #64
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,978
Ok, so on your frame the cuts were enlarged to fit the pivot points?
R65LazaruS
Old 03-26-2012, 09:35 AM   #65
walkingbear OP
Oddometer: 3,582
pivot
yes, I just sent him a note to enlarge the pivot area
Old 03-26-2012, 09:50 AM   #66
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,548
You should be able to just hug them up tight to the pivot. Maybe the factory weld requires some grinding to fit them up tight.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 03-26-2012, 09:56 AM   #67
Airhead Wrangler
Adios Mexico
Oddometer: 6,548
Same w/ HPN
Old 03-26-2012, 01:36 PM   #68
_cy_
Oddometer: 6,326
_cy_ is online now   Reply With Quote
Old 03-26-2012, 01:47 PM   #69
Carl
Carl's Avatar
Oddometer: 768
Those MIG splatter welds are going to negate the idea and intent of using frame reinforcements.
Carl
http://www.flyingtpot.com/
Carl is offline   Reply With Quote
Old 03-29-2012, 09:25 AM   #70
LoJack
LoJack's Avatar
Oddometer: 1,605
Sent payment finally, pheww! Looking forward to it. Lojack
LoJack is offline   Reply With Quote
Old 03-29-2012, 02:00 PM   #71
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
explain???
Yeah, right.
We will get very old waiting.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 03-29-2012, 03:20 PM   #72
walkingbear OP
Oddometer: 3,582
Cuts off the CNC machine
Old 03-29-2012, 03:35 PM   #73
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,743
If someone wants the set I bought shoot me a PM. Really doubt I'll ever weld them onto my frame, kind of a knee jerk purchase for me. Same price ($52) if you're in the USA.
ps- my decision to sell is for financial reasons. It'd be nice to do this, but not wise at this point.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 03-29-2012 at 10:41 PM
Old 03-29-2012, 08:57 PM   #74
Carl
Carl's Avatar
Oddometer: 768
Monstrous difference between peddling parts and welding frame braces/reinforcements.....
The explanation is rooted in reviewing those welds and how they look versus factory and HPN (or equivalent type) beads. Hints: review weld bead start and stop, thickness, width, height, etc....
Carl
Old 03-29-2012, 09:21 PM   #75
supershaft
because I can
Oddometer: 9,116
Aren't BMW frames MIG welded to start with? Those aren't the neatest welds I have seen but I bet they are stronger in practice than some welds I have seen praised to the moon here on ADVR. That weld by I guess HPN with the zinc primer. It has a text book cold weld on the frame side of the bottom weld (our view).
Times are GMT -7.   It's 08:58 AM.
