Old 06-16-2012, 03:20 PM   #106
SLACKER
SLACKER's Avatar
Oddometer: 184
Slacked off at Slacker!!!
Slackadoodledoo!!!!!!!!!!!!!!!!!
SLACKER screwed with this post 11-14-2013 at 03:14 AM
SLACKER is offline   Reply With Quote
Old 06-16-2012, 04:04 PM   #107
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
In all honesty SLACKER, go ahead and blame it on MARYLAND. I used to live there too. When I was there I pissed off people every effin day. I took pride in it.
Then I moved back to California, and eventually to the desert where there's not so many people around.
I'm much mellower now and I don't have any stress anymore.
For you though, maybe Montana would be good..................
Anyway, thanks for mannin' up and doing the right thing. It makes us all feel just a little bit "mellower".
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 10-25-2012, 10:36 AM   #108
mennleo
Oddometer: 131
head
Originally Posted by Airhead Wrangler View Post
Uhh...
I'd have those plates bracing the steering head welded to the down tubes, not to the steering head. They won't do much good where they are.
I agree! this is how i did it. http://www.advrider.com/forums/showt...1#post19892361
mennleo is offline   Reply With Quote
Old 12-30-2012, 04:57 PM   #109
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,612
Altus breaks his top tube.
Apologies if this is 205. I had not seen it and thought I had watched all his videos. Soundtrack is dreadful, but the break happens around, or is discovered at 11.00. Watch the whole thing as there is some good riding. I think that's Michael with him, who now owns HPN 663. Guess the brace for the top tube is important
hardwaregrrl is online now   Reply With Quote
Old 12-30-2012, 05:07 PM   #110
Phreaky Phil
Oddometer: 1,930
I have watched this before and studied it and the break appears to be rearward of any HPN bracing.
Phreaky Phil is offline   Reply With Quote
Old 12-30-2012, 05:11 PM   #111
hardwaregrrl
ignore list
Oddometer: 7,612
Uhmmmm...wasn't being serious, PHil. Hence the smiley.
Old 12-30-2012, 05:39 PM   #112
Phreaky Phil
Oddometer: 1,930
Opps , kinda buggered that frame though. Handling like the Rubber Cow
Old 12-30-2012, 06:08 PM   #113
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,040
I've never seen a fatigue crack at right angles to the tube before. Could there have been a previous weld or seam at that location?
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 12-30-2012, 06:21 PM   #114
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,609
I've seen that exact same crack in the spine of a stock G/S that's done about 500,000 miles, most of it fully loaded and two up. It got repaired in a rural garage in India and has held for at least 150,000 miles.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler is online now   Reply With Quote
Old 12-30-2012, 06:33 PM   #115
supershaft
because I can
Oddometer: 9,116
I watched about five minutes? I have never seen anybody stand up on perfectly smooth surface until having heard of people spending hundreds if not thousands of dollars basically learning to do just that. What a waste of perfect sit down and haul ass time. It saves your energy and gets you there faster doing it! But I guess it isn't trendy!
Old 12-30-2012, 06:58 PM   #116
Phreaky Phil
Oddometer: 1,930
Best part of the video is of the 2up LOADED Beemer at minute 12.48.
Priceless
Old 12-30-2012, 09:26 PM   #117
supershaft
because I can
Oddometer: 9,116
Priceless
I washed that and I simply do not care. Not impressed but that was why I stopped watching it at around five minutes. Nein danka!
I caught him welding the frame. That is the weakest part of our frame. I have seen fatigue cracks at right angles to the tube many times over RRS. Not on beemer frames but. Where that frame broke does not surprise me in the least.
Old 12-30-2012, 09:33 PM   #118
robtg
Oddometer: 710
Priceless
You would need overload springs for your 1/2 ton pickup to carry all that crap. And people are surprised when their frames break.
robtg is offline   Reply With Quote
Old 12-30-2012, 10:05 PM   #119
mennleo
Oddometer: 131
welding
welding on a frame causes the base metal grain to change and causes stress risers in that area. the tube is going to tend to crack at a weld. as an aircraft mechanic i have done a lot of welding on tube aircraft fuselages. reinforcements and repairs need to be done as diamond type patches with long longitudinal welds. Look at AC 43.13 for some ideas.
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/list/AC%2043.13-1B/$FILE/Chapter%2004.pdf
enjoyed the video! on field temparary repairs are a bit crude some times!!
Old 12-30-2012, 10:36 PM   #120
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,223
I read up to page 36 and so far its been riveting!
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Times are GMT -7.   It's 05:45 PM.
