Old 01-25-2012, 03:11 AM   #1
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,031
Early 90s KDX200 won't start
Hi all,
My mate just bought a KDX200, early 90s. The guy we bought it off started it after two kicks. We got it home and went to ride it the next day and it wouldnt start, so we pulled it all down, cleaned it up and ended up having to tow start it to get it going. Rode it for about 15mins then put it away.
Later that day, wanted to ride again, so kicked it and started it no real problems, he was riding it and it died after about 5mins of riding, then we couldn't kick it over at all. Any ideas on what might have caused it?
Joe Watson is offline   Reply With Quote
Old 01-25-2012, 03:54 AM   #2
peter650
Oddometer: 422
Do you mean the motors locked up,or it will turn over but not start.
peter650 is offline   Reply With Quote
Old 01-25-2012, 05:23 AM   #3
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,031
Sorry, it will still kick over, but it won't start. The problem is not so much the not starting, as we will look over it tomorrow and probably get it started again, but more so why it stopped suddenly.
Old 01-25-2012, 05:47 AM   #4
peter650
Oddometer: 422
Have you checked the spark plug? You want a blue spark. Is your air filter clean? Pipe/muffler not blocked?
Old 01-25-2012, 06:25 AM   #5
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,031
We checked the plug originally when we couldnt get it going and it was like new, we just cleaned the filter too. We might take the exhaust off and check that out.
Old 01-25-2012, 02:32 PM   #6
peter650
Oddometer: 422
Make sure you check the color of the spark. Kick the bike over with the spark plug out {it helps if it's dark}. When it stops does it go BRRRRRRR BRRRRRRRRRRRRRR then stop, backfire and fart and stop, or just cut out dead like you hit the kill switch {kill switches can can cause break downs}
Old 01-25-2012, 02:35 PM   #7
peter650
Oddometer: 422
BTW kdx200s are great bikes get this sorted and your mate is
Old 01-25-2012, 03:32 PM   #8
MarylandStrom
Oddometer: 338
As others have said, checking spark is your first concern. If it gets good spark, then the next thing to check is if it's getting fuel. Though if it ran ok, fuel doesn't seem to be an issue. You might still clean the carb since it probably needs it anyway.
When those bikes have worn piston rings, it can cause hard starting issues. You can usually tell if compression is low by pushing the kickstarter down with your hand and feeling how much resistance there is. Replacing piston and rings on that bike is very easy!
MarylandStrom is offline   Reply With Quote
Old 01-25-2012, 06:39 PM   #9
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,676
No idea about the problem, but if you are going to pull the head off, service the power valve.
When I went to get parts for mine, I could only get a new left side cylinder thingy, and that was the second last in Australia they said, the right was no longer avalable...
I think I have the manual for it on my other computer (which is in Brisbane with my wife), I'll see if I have it when I go down there next week.
Great bikes though, if I didn't buy my 200EXC I would have keept the KDX, and in some situations the KDX was better...
Oh, and my PM about the CR was serious, I just added the working on an oil rig thing for a laugh.
(And I am pretty sure the CR is an 89... Just what I need for racing until I can get my KX down there.)
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Old 01-25-2012, 10:21 PM   #10
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,031
Ok, so to update, my mate came over so we decided to just give it a few kicks to see what would happen before pulling it apart. He tried and got tired, so I gave it a couple of kicks, bit of choke, then no choke and and a tiny bit of throttle and it started!!
We rode for a bit in the front paddock, he stalled a few times, but each time it only took two or three kicks to get it going (He is very new to bikes and is still learning how to kick properly)
So we thought it would be fine to go ride the big track, he then stalled it right down the bottom corner of the farm and no matter what we did, we couldn't get it started again.
It was bloody hard pushing it all the way back up to the house!!! Man I love my WR250R with its trouble free riding and electric start!
Old 01-25-2012, 10:40 PM   #11
peter650
Oddometer: 422
Heaps of rain is your spark plug cap good. Bad cap and it will stop when it gets wet.
Old 01-25-2012, 10:50 PM   #12
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,031
Very interesting, cause there is a small creek crossing that we went through, but the bike ran fine for a few minutes after that and it was only when the bike was stalled that it wouldnt start again, I could only assume that it would have kept running......?
Are we talking about the spark plug lead that goes from the ignition unit to the spark plug? As he said last time he took it off that it didnt seem to click onto the spark plug very well.
Old 01-25-2012, 10:52 PM   #13
peter650
Oddometer: 422
Have a close look at your HT lead from the coil
Old 01-25-2012, 11:22 PM   #14
PistonPants
Crankcase Scavenger
PistonPants's Avatar
Oddometer: 438
Clean and dielectric grease every electrical connection on the bike especially the spark plug cap.
Piston
PistonPants is offline   Reply With Quote
Old 01-25-2012, 11:55 PM   #15
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,031
I think before our next attempt we are going to throw a new plug, new lead, totally strip and clean the carby and look at what gaskets need replacing as it leaks a heap from different spots on the motor.
Times are GMT -7.   It's 06:33 AM.
