Old 01-29-2012, 10:54 AM   #1
LotaBikes OP
Oddometer: 81
Need some tech help for '65 YJ2
I have a '65 YJ2 that I need some technical help with. I have searched for the answers to these questions to no avail and hope someone here might be able to advise. The bike has what I beleive to be a Mikuni VM16SC carb. I need to know the correct float level height. Also, I am doing a compression and leak down test now that I have replaced the crank seals and varios o-rings that may affect air intake. What should the compression be? Lastly (for now) I need to know the correct timing and points gap. Any help on any one of these points is appreciated.
LotaBikes is offline   Reply With Quote
Old 01-29-2012, 11:07 AM   #2
Shocktower
Shocktower's Avatar
Oddometer: 9,480
Sudco will have the float height but I do believe it is 22mm- 27mm I will PM some other info on the timing
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Times are GMT -7.   It's 06:51 PM.
