Old 06-24-2013, 02:43 PM   #1126
reenmachine
Rain or Shine
Oddometer: 549
Originally Posted by impalla62ss View Post
Hello All,
I have two questions on my 2011 G650GS.
Twice recently the bike will start, but as soon as put it in first gear the bike will die. The bike will start normally about ten minutes after that. Once this happened after a two hour ride and the second time it was the morning after a 300 mile ride. Has this happened to anyone else? I don't think this is the hot start issue since it has happened cold and the bike starts fine after a long ride.
Are there any components I should avoid if I use a coin-op pressure washer to clean the bike?
Well, if the bike starts, then it's not the hot start issue
So the bike's running in neutral, you plonk it into gear to ride off, and immediately dies? Hmmm, it's a long shot but there's a switch at the kickstand that kills the engine if you put it in gear with the kickstand down. There have been a couple times where, for some reason, I went for 1st without flipping the stand up and got the same result as you. Any chance that's what you did?
As for the power washer, just be careful in general. Mind your air inlet at the front right behind the headlight area and the seal where the sprocket shaft exits the gearbox. I wash mine this way occasionally when it's extra muddy but I keep my distance out of caution.
'14 KTM 1190 Adventure
'11 BMW G650GS
'02 Yamaha FZ1
reenmachine is offline   Reply With Quote
Old 06-25-2013, 05:41 PM   #1127
Nickcamera
Oddometer: 73
Check out my awesome g650gs y'all
thought you guys might be interested in seeing what I've done with the 09 g650gs. I got it pretty stock, who says this is a wifes bike!!
Most recently I put dakar forks and rear suspension on it. also a rear lifting link. gives me so much more clearance, I now have to tippy toe the thing and I'm 6'1. I added all the farkle I considered logical. I changed out the front sprocket and also added a booster plug which gives a whole new feel. feels like the xchallenge, I swear.
I love the bike.
check out the pics in the link.
https://plus.google.com/photos/11595...CLK6w7aZitPYWQ
Nickcamera is offline   Reply With Quote
Old 06-26-2013, 03:37 AM   #1128
Murphy Slaw
Murphy Slaw's Avatar
Oddometer: 1,663
Looks great.
You do, however, need to break out the weed whacker........
The Murph Channel
Acoustic Originals and some Double Aught
http://www.youtube.com/channel/UCkomGsMJXH9qn-xLKCv4WOg
Murphy Slaw is offline   Reply With Quote
Old 06-26-2013, 04:24 AM   #1129
Nickcamera
Oddometer: 73
Wink
Ill get one of my 12 full time landscapers on it. Whoever missed that spot is in big trouble!
Originally Posted by Murphy Slaw View Post
Looks great.
Old 06-26-2013, 04:47 AM   #1130
ctoldie
ctoldie's Avatar
Oddometer: 270
I love the bike.
Love it. Where did you pick up those mirrors?
ctoldie is offline   Reply With Quote
Old 06-26-2013, 01:09 PM   #1131
Trykart
Trykart's Avatar
Oddometer: 31
Originally Posted by mramosc View Post
Hi Trykart, nice bike!,
Those tires are the TKC80, right? How do you like them? I've thinking of getting those tires but I wonder how they perform on paved roads, twisties and at +75mph. How about braking distance on paved roads?
Hey mramosc,
Yup those are tkc80's. I've had them for about 1500 miles and like them a lot so far. Took some time getting use to, they felt more "squirly" on the pavement especially in the turns, but now I feel very comfortable with them. I recently have felt a front wheel wobble around 80mph, but that might be due to low tire pressure? Haven't really felt a difference in stopping distance.
Trykart is offline   Reply With Quote
Old 06-26-2013, 05:25 PM   #1132
Nickcamera
Oddometer: 73
they are Double take mirrors. I busted both stock mirror mounts on one off road trip and began searching for a nice set that I could tuck away while off road. they work great. if ordering make sure to specify you need the 8mm ball mount screw. they use RAM mounts. check out the link below.
http://www.doubletakemirror.com/
Old 06-26-2013, 05:41 PM   #1133
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,264
lowered centerstand?
My GF just picked up a factory lowered 2011 G650GS. It did not come with a centerstand. I was told that Touratech makes a lowered one, but I don't see it on their web page. Anyone know if there is a lowered centerstand available that fits this bike?
huzar is offline   Reply With Quote
Old 06-26-2013, 05:44 PM   #1134
psychopompos
Oddometer: 113
I think BMW makes one as well. Talk to the dealer, and perhaps consider letting them install it, it can be a real pain if you don't have the know-how, as evidenced a few posts ago.
psychopompos is offline   Reply With Quote
Old 06-26-2013, 05:48 PM   #1135
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,264
If you're referring to the centerstand, the dealer (RideWest@Seattle) told me there is no lowered centerstand for the 2011 G650GS, hence my question to you fine folks. If there is one, got a part #?
Old 06-26-2013, 06:16 PM   #1136
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,264
Never mind... DoG bless the Max BMW parts fiche:
FOR VEHICLES WITH LOWERING (CODE: X499A) :
01 46 52 7 686 769 CENTER STAND 2.82 1 $181.36
Old 06-26-2013, 08:04 PM   #1137
guavadude
de-composer
guavadude's Avatar
Oddometer: 891
axle diameter?
anyone know the axle diameters? I'm ordering one of the Kaurit tire tools and want to be sure. Is it 17mm?
thx
it's 17mm in case anyone else needs to know.
guavadude screwed with this post 06-26-2013 at 08:24 PM
guavadude is offline   Reply With Quote
Old 06-26-2013, 08:22 PM   #1138
DomEOD
'murica
DomEOD's Avatar
Oddometer: 2,466
Edited
'14 F800GS
Initial Success or Total Failure.
DomEOD is offline   Reply With Quote
Old 06-27-2013, 04:42 AM   #1139
ctoldie
ctoldie's Avatar
Oddometer: 270
Thanks.
Old 06-27-2013, 10:53 AM   #1140
jonmbakermd
Oddometer: 37
Sertao set up
www.youtube.com/watch?v=MCisslwhPmw
jonmbakermd is offline   Reply With Quote
Times are GMT -7.   It's 07:50 PM.
