02-07-2012, 10:25 AM
#61 |
Oddometer: 4,474
Amusing At Best
Well, this thread indeed generates wry smiles....same old, same old..."no problem, they all do that" and "you should have bought"...reminds me of Monty's "A mere flesh wound!".
At the end of the day I agree with GB...lots of hope and promise but BMW is Teflon coated and this too will fade. The above request to specify if your FD has a gear oil leak does make for a pause...since many failed FDs did not leak any lubricant...Hmmmmm. Will any of us ever know for certain why the FDs have failed? For example does anyone out there know for certain why the ignition antennae [multi versions] failed and generated the dreaded EWS? The weaknesses in these components will go to the grave with some BMW engineer...assuming that even they have a clue. What BMW does know is the true percentage of FDs that have failed; not surprisingly that is a corporate secret. Nothing but WAGs for now and probably forever from the rest of us. Oh yes, I dearly love my '07 GSA and when, not if, it breaks I will fix it and dirt ravage another set of TKCs! An old western phrase: "Ride for the Brand" doesn't apply to BMW for me, I ride because the bike is so damn much fun and inspite of BMW's marketing mentality.
"In Wallowas" ==================== 2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!"
02-07-2012, 10:33 AM
#62 |
"Cool" Aid!
Oddometer: 41,923
And MANY leaked but never failed!
![]() Amazing how many think a seal leak is a FD failure! ![]() Jim
02-07-2012, 10:42 AM
#63 |
Oddometer: 9,446
Sounds like the government concern is leaking oil on the rear tire leading to a loss of control issue. Is that commonly a factor in failures? I've had a seal failure that was limited to some seepage on the hub, but no gushing oil. I have not had a FD failure in 75,000 miles on BMW shafts.
Does a failure ever lead to the rear wheel locking up and control loss? Out riding once I did meet a guy on a BMW with oil all over his wheel and some on the tire.
Rob '07 White (the coolest color) GSA rider '13 Husky Strada & '05 Honda 400XR
02-07-2012, 10:49 AM
#64 | |
Tuscan rider
![]() Quote:
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here. Renting out motorbikes in Toscana, Italy Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index. IBA: 33616 |
02-07-2012, 02:27 PM
#65 |
Oddometer: 1,525
You're kidding right? For one thing, "chudder" wouldn't strand you by the side of the road. IF your DL clutch parts weren't covered under warranty, baskets are cheap and could be fixed by any moderately skilled shade-tree mechanic, with no special tools.
02-07-2012, 03:18 PM
#66 | |
Homebrew Guru
Oddometer: 1,469
BTW, 36K on an '04 1150RT with too many problems to mention.
sparkyairracing.com |
02-07-2012, 03:24 PM
#67 |
Oddometer: 181
What's a noob? Is it something accidentally brewed by a Home Master Brewer?
02-07-2012, 04:42 PM
#68 | |
Oddometer: 3,921
I think there are a percentage of problems due to unrealistic expectations about the durability of any system in nasty conditions as well. So many kool aid drinkers I have read going on like BMW have invented some magic metal unknown to the rest of the world. They didn't, and service must be done just like any other bike and probably more so than the recommended intervals if the environment is tough.. I don't think the basic design, lends itself to tough conditions though. For most road only users, properly serviced it SHOULD be OK, but OK is all it is. See how the Triumph and Honda go. At least that will give an idea about how other SS swing arm shaft systems go in the real world. No that was a sub frame failure.
"It's better to ride a boring bike than push an interesting one" ... Canuman "I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten GrahamD screwed with this post 02-07-2012 at 04:56 PM |
02-07-2012, 04:48 PM
#69 | |
Oddometer: 356
02-07-2012, 04:54 PM
#70 | |
Oilhead convert
Oddometer: 930
Regards, Mark 2003 BMW R1150GS |
02-07-2012, 04:59 PM
#71 | |
Oddometer: 3,921
People seem to like to pay a lot of money for fragile things with nice coatings.
"It's better to ride a boring bike than push an interesting one" ... Canuman "I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten |
02-07-2012, 05:06 PM
#72 | |
Oddometer: 1,036
02-07-2012, 05:11 PM
#73 | |
Oddometer: 1,036
02-07-2012, 05:19 PM
#74 | |
Oddometer: 356
02-07-2012, 05:26 PM
#75 | |
Oddometer: 4,474
Maybe....But
Then and perhaps now, the failed FDs were not rebuilt by BMW dealers but were replaced and the failed FDs were shipped back to BMW. Independent of that, BMW dealers know of the FD issue and most certainly get some type of support from BMW for FDs replaced under a warranty. I could be wrong, but BMW counts beans and FDs are big beans! ![]() All that aside I would love to eventually find out why they are failing...no guess work but actual engineering reports.
