08-04-2012, 01:36 PM
#196 |
Oddometer: 13
1150GS
Another foot for the jiffy: ![]() ![]() Foldable brake pedal: ![]() ![]() ![]() Steering stops: ![]() ![]() Lowered and shortened exhaust: ![]() Handguard spoilers and shortened touratech offroad mirrors: ![]() Handlebar from R1150R: ![]() Theft protection on ignition switch: ![]() ![]() Rack exstension: ![]() Beak and screen amputation, mounted led indicators: ![]() ![]() Grtz: dxamet dxamet screwed with this post 08-04-2012 at 03:48 PM Reason: show pictures |
08-05-2012, 07:55 AM
#197 |
("lets go!")
Oddometer: 853
GS Slim Down
Nice job at slimming down the rather porky GS. I did as you, stick with the system luggage and went to an RT sized Left. The system luggage is much lighter than the pricy aluminum affairs that everyone gravitates towards. I think another advantage too, not as likely to ensue sub-frame damage in a low-side.
"A good traveller has no fixed plans and is not intent on arriving" Lao Tzu (570-490 BC) ![]() Current: 02' GS1150R 06' 650 Vstrom |
08-11-2012, 07:23 PM
#198 |
Oddometer: 9
![]() These make great toolboxes. They are durable, the perfect size, and watertight. Covered with Truck Bed liner. ![]() ![]()
08-13-2012, 06:32 PM
#199 |
Oddometer: 9
Hockey puck side stand extension. Keeps the bike from leaning too far and keeps the drivewaygarage from getting scratched.
08-15-2012, 06:44 PM
#200 |
Oddometer: 102
Modified rear rack
I bought my '02 R1150GS this April. It had the gigantic Best Rest "Model T" rack on the back:
http://www.bestrestproducts.com/p-19...cargorest.aspx ![]() ![]() As a side note, does anyone think this rack is really a good idea? It sure would allow you to put a lot of weight way behind the rear wheel. I promptly took the rack off and set it aside, with no plans of using it. I also took of the Best Rest back rest as shown in the second picture above. A few months later, my wife started ridding pillion with me. She commented about not having anything behind her and it felt insecure. I got to thinking about the back rest I removed and found out it can be used as a pillion back rest when using one of the Best Rest (gigantic) rear cargo racks. I looked and Best Rest didn't make a smaller rack, so I had the "Model T" modified by a local metal fab shop, as I was never going to use it in it's original size. I got the rack back from the fab shop and painted it a silver that is very close to the sliver used on the trim and factory cargo rack. I got it installed today and here's the final result: ![]() ![]() ![]() So, while i didn't "make" it myself, I did have it modified and I did paint it myself.
- Eric 2002 BMW R1150GS |
08-16-2012, 05:38 AM
#201 | |
("lets go!")
Oddometer: 853
Looks like you have enough leverage to lift the front wheel off the ground w/one hand! I'd say you'll definitely have a negative affect on handling even w/20lbs hanging on that thing.
08-16-2012, 10:21 AM
#202 |
Oddometer: 102
Which is why I took it off in the first place...
08-19-2012, 09:38 PM
#203 |
supern00b
Oddometer: 119
Probably Been Invented Before...
This has probably been invented a thousand times before, but I thought I'd share.
I did my first valve job and plug change today on my 02 GSA and I wanted a way to properly torque the plugs. The only problem was that I didn't have a socket thin enough to go down the well. The author of the Oilhead Maintenance Manual in Wisdom said that he welded a nut onto his BMW plug removal tool, but not having a welder or knowing how to weld made that option hard. I'd seen some people had machine milled down sockets to have very thin walls, but since I didn't have a nice lathe, I started work on my bench grinder trying to thin the walls of an old 5/8" socket I had lying around to see if I could get it to fit. It was taking forever (that steel is hard!) and doing it on a grinding wheel was making it look pretty ghetto, but then I came up with another idea. ![]() I had an old 13/16th socket laying around that fit just perfectly around the BMW tool (though a little larger should work too). So I put it in a vice: ![]() Then I added one of these: ![]() To make one of these: ![]() Which slips onto the plug wrench from the BMW toolkit like this: ![]() And which let me put the spark plug in like this: ![]() And BTW, all I can say is WOW to the awesome sound of a new valve job and new plugs. The engine sounds so much tighter now. Tomorrow, I'll dip it in Harmonizer butter. :) |
10-19-2012, 09:57 AM
#204 |
Oddometer: 46
I ordered custom top case for my R 1150 GS. The top case dimensions are based on original aluminum top case from BMW R1200GS Adventure (approx. 365x310x315mm) because I like the proportions but since my helmet is little bit bigger I enlarged it to 400x340x340mm (still can be used on R1200GS and it fits between the side cases) that is much better for my purposes but still seems reasonably small.
Another thing that I wanted from the manufacturer (BEGR) was the padded upper edge to avoid damaging of my helmet when inserting to/removing from the topcase. The producer did that really nicely with some rubber gasket. Since I want to use the topcase basicly only for the helmet I decided to pad the interior with heavy duty carpet. I bought all the necessary stuff and started with padding (for the first time in my life): ![]() ![]() ![]() ![]()
my blog: http://GSrider.net/ |
10-19-2012, 10:01 AM
#205 | |
Oddometer: 2,416
Too many days in ADVertising/Marketing:
I see KITS selling like hot cakes...get to it! ![]() Better yet...sell the TEMPLATES! Do once...rake in the dough!
10-19-2012, 10:10 AM
#206 | |
Oddometer: 2,940
![]() ![]() To be honest..I bought it when I rode two up everywhere..it worked out great!! Now..I really don't need it..just have never taken off...
Insert witty sig line here.. |
10-19-2012, 11:25 AM
#207 |
Oddometer: 501
I made a shorty sport screen for my bike. I had an old ADV screen that the previous owner scratched up. I cut 6 " off and sanded the edge. Then painted the inside with Plastidip.
GO SHARKS! Dave '02 R1150GS ADV "The Tank" "I fire up the willing engine,responding with a roar. Tires spitting gravel, I commit my weekly crime." "Red Barchetta" By RUSH |
10-19-2012, 06:49 PM
#208 |
2up Adventurer
Oddometer: 39
Great thread, innovation rules! The short windscreen is marvelous.
Success is the ability to go from one failure to another with no loss of enthusiasm - W. Churchill
11-14-2012, 05:49 PM
#209 |
Oddometer: 6
At it's heart, my RT thinks its a GS. And that, my fellow adventurers, is all is takes for me to allow myself to post my pix in this thread
The custom welded rack took me about an hour to knock out from cheap steel tubing and is a great for holding my gear.And before you chase me away, my new to me 2006 R1200GSA is awaiting my custom 30mm ammocan-toolbox for behind the Micatech panniers. I just need for the darn box to arrive so I can customize it then post pix :-) phubner screwed with this post 11-14-2012 at 05:55 PM Reason: photo size reduced. |
11-15-2012, 02:38 PM
#210 |
Oddometer: 21,551
