Old 01-17-2013, 09:14 AM   #286
BFG
BFG's Avatar
Oddometer: 33
Originally Posted by GZPainter View Post
I really like the following idea. Did the capacity of the box reduced with the addition of the pad?
and if yes by how much? keep the patrons...I believe that some people from over here they will need them..
Have a look at this, post 384 and follow SmugMug link to pictures. Lined the panniers hardly any reduction in size. Think they are better for it as well les chance of marking helmet etc.
http://advrider.com/forums/showthrea...836894&page=26
Or on UKGSer. From post 12
http://ukgser.com/forums/showthread.php?t=136812
Money isn't everything. But it keeps the kids intouch
BFG is offline   Reply With Quote
Old 01-17-2013, 09:38 AM   #287
LaurelPerryOnLand
Oddometer: 2,423
Originally Posted by ElMartillo View Post
Well, I like making money as much as the next guy, I enjoy fabrication and problem-solving. I could price it reasonably I'm sure.
You have a broken one you could send me? Ideally I'd need the piece(s) that broke off, ultimately ideally the bike for fitment, but we could get around that if necessary.
Cheers!
PM sent with pictures.
LaurelPerryOnLand is online now   Reply With Quote
Old 01-17-2013, 10:56 AM   #288
Panzerkampfwagen
Panzerkampfwagen's Avatar
Oddometer: 9
A Humble contribution to this thread. Led daytime light, just beneath the beak.
Nothing to deal with those great works above, but I tried to do my best.
Panzerkampfwagen screwed with this post 01-17-2013 at 11:13 AM
Panzerkampfwagen is offline   Reply With Quote
Old 01-17-2013, 11:21 AM   #289
Panzerkampfwagen
Oddometer: 9
Sorry. Wrong post.
Old 01-18-2013, 03:26 PM   #290
everycredit
everycredit's Avatar
Oddometer: 267
I made a tail pipe extension for my 1150GS with Jesse bags.
I know there are a lot of threads out there on this, but I decided to do it myself after being annoyed by this:
I got 1 3/4" ID exhaust pipe and used some throttle return springs and nuts that I had.
I removed the silencer end, using 8mm socket.
Then cut the pipe so it fits under my left turn light.
Dry fit
Measured the springs so I know where to weld the nuts to hold the springs.
Welded the nuts using a cheap harbor freight welder I've owned for several years. Does the job, but not weld (please don't judge my welds--I know they suck, but they hold).
Here it is fitted
With my pannier back on. Need to cut the end for fit.
Used an angle grinder to sharpen the edge, so in a pinch it can be used as a weapon
Went for a ride, doesn't rattle or leak. Hopefully it will keep all (if not most) of the hot exhaust gasses off my pannier.
everycredit is offline   Reply With Quote
Old 01-18-2013, 07:22 PM   #291
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,487
Dry fit
Here it is fitted
Looks good! The only change I would make is possibly heavier springs not stretched so much. Otherwise very nice!
Jim
JimVonBaden is online now   Reply With Quote
Old 01-18-2013, 08:06 PM   #292
everycredit
Oddometer: 267
Jim
I'll have to look for some. They aren't good springs and will probably be unsprung by the heat.
Times are GMT -7.   It's 08:47 AM.
