Old 07-12-2014, 08:00 PM   #331
Ricardo Kuhn OP
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,402
I'm been working on a Tiny bike rack
Keep looking on the link some evolution is coming soon.
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 07-12-2014, 08:07 PM   #332
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,135
Originally Posted by Suburban78 View Post
Here's the thread I posted on how to do this. http://www.advrider.com/forums/showthread.php?t=993463
Good how to and ideas.
Trusting double side adhesives to hold everything is dodgey, and the surface is curved to make contact area even less.
Sooner or later they will let go, I have worked with them for years in industry.
IMO they are a temporary solution, especially when higher temperatures in summer are involved.
How does the wind act on the assy. at 70+ mph?
Old enough to know better....
Young enough to try it again
GS Addict is online now   Reply With Quote
Old 07-12-2014, 08:34 PM   #333
Suburban78
Oddometer: 148
I'm looking into the Go Pro handle bar mount as well to see if it's a viable option. As far as wind, I didn't have any issue for the short highway run today. The position is just inside of the air flow coming off the wind screen.
Suburban78 is offline   Reply With Quote
Old 07-12-2014, 08:52 PM   #334
Ricardo Kuhn OP
Oddometer: 12,402
nice range of mobility
I do have to agree not only the "Bonding" is weak but is not sufficient surface area to deal with such a big object, plus wind, vibration, etc, I will suggest to bolt a aluminum (phenolic, plastic or something) plate to the go pro mount to increase the contact area..
Ps: many years ago somebody was making brake/clutch reservoir caps with "Hears" for the ram mount balls, maybe something you can bolt to is the solution..
PsII: for now I will suggest you to run a tether wire just in case..
Old 07-13-2014, 05:29 AM   #335
PackRat
Huey Guns
PackRat's Avatar
Oddometer: 1,455
Put a lanyard on it......it will fly!!
"Packrat" IBA# 11205, AARP, ATP, CFI, A&P, USMC
__________________________________________
Rigor Mortis will be the first indication that I've grown up!!
Yungas Rd.-Bolivia, Alaska '08 - Labrador '10 -
PackRat is offline   Reply With Quote
Old 07-13-2014, 10:38 AM   #336
DesertTortoise
Freedom Fighter
DesertTortoise's Avatar
Oddometer: 150
What about this stuff...
3m VHB tape... Apparently it tests stronger than rivets and is used on the glass facade of skyscrapers ?
http://solutions.3m.com/wps/portal/3...s/3M-VHB-Tape/
Any experiences?
http://img.banggood.com/thumb/view/u...7.10%20676.jpg
DesertTortoise is offline   Reply With Quote
Old 07-13-2014, 11:33 AM   #337
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,135
Any experiences?
Pretty well the best there is, but you need a good flat to flat surface area.
No curved surface and no paint - it's only as strong as the paint adhesion to the mother surface.
Old 07-13-2014, 11:34 AM   #338
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,135
I did exactly that with a Ram ball. Very strong.
Old 07-13-2014, 01:47 PM   #339
Ricardo Kuhn OP
Oddometer: 12,402
Did you drill and tap that your self...!?
The ones I'm taking about had 2 "hears" (taps) coming out of the sides of the cap (outside the 4 bolts) but I was always worry the taps will break taking on of the corners with them, your look a lot more secure even if I don't think is much material under the cap..
Old 07-13-2014, 01:50 PM   #340
Monsignore
Plunger Boy
Monsignore's Avatar
Oddometer: 933
I made this to prevent piddle puddles from appearing on my rear rim & 'possum scraper.
Ewig war ich.
IBA # 55612
Monsignore is offline   Reply With Quote
Old 07-13-2014, 04:17 PM   #341
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,135
There is enough material to support but not to thread.
The one I showed was a 3/8-24 stud and I have a threaded plate under. You can also use a pal nut.
You can use both types, I have. If you use the ear type you should put in the matching curve (I use a belt sander).
GS Addict screwed with this post 07-13-2014 at 04:28 PM
Old 07-31-2014, 06:40 AM   #342
67siia
67siia's Avatar
Oddometer: 161
Subscribing
67siia - CA 91381
12 BMW F800GS - 79 BMW R65 - 13 Honda CB500X - 79 Yamaha DT175 - 07 Yamaha TTR125L
67siia is offline   Reply With Quote
Old 08-01-2014, 12:21 PM   #343
Jtoper
Adventurerer
Jtoper's Avatar
Oddometer: 62
Fuel line protectors
I've been thinking of making these for a while and finally got around to it. Fortunate, I had a friend with a plasma table and he was able to cut the front piece for me.
There was a lot of test fitting and tweeking involved, but the final product turned out pretty good. I enjoyed the project and saved some $$$$!
Jtoper is online now   Reply With Quote
Old 08-02-2014, 08:56 AM   #344
LVGS
LVGS's Avatar
Oddometer: 478
Great job, you would be hard pressed to tell the difference from the Touratech ones!
LVGS is offline   Reply With Quote
Old 08-02-2014, 09:36 AM   #345
Jtoper
Adventurerer
Jtoper's Avatar
Oddometer: 62
Thank you! The big difference between the two is that I spent about $8 making these.
Times are GMT -7.   It's 08:19 AM.
