Old 04-09-2012, 11:58 PM   #106
EdGear
Edventurer
EdGear's Avatar
Oddometer: 536
I'm pretty impressed with the Rottweiler and what a foam air filter has to offer as an improvement over the stock air box. The stock air box looks like a small submarine and is very well protected.
Its my knee jerk reaction to want to protect the Rottweiler. I can't really say a shield is needed, heat and splash may not be a problem.
My reason for the shield is partly from reading this thread and what Tahoeacr discovered insulating the stock air box then putting similar shielding in place with all the air filters he tried. Threads from Cyborg, BillyD and others show the value of insulating the undersides of the 9xx fuels tanks. When you work a 9xx is gets hot under those tanks, hot enough to boil fuel. You don't want hot air going in the intakes.
For the street, removing the stock air box and putting on the Rottweiler allows for a lot more cooling, especially at speed. No problem.
For off road, look at any dirt bike, they have foam filters and air boxes to make it difficult for dust and water to get into the intakes. The tanks and fairing of the 9xx create an air box like enclosure that may work for most. The foam filter on the Rottweiler will keep the dust out and breath better longer. Filter skins will help those who truly spend all their time riding in the dust.
The shield seems like a simple thing to do, try to extend the Rottweiler base plate to the frame. The first one I made out of flashing took about 20 minutes. With that as a template the nicer looking one I posted took about 30 minutes.
If I really had my act together I would have already bought my Tune ECU cable and loaded a proper map so that I would have already tested the shield.
The shield seems like a reasonable thing to do, reassured me that there is heat and splash protection. I'll let you know how it goes. (after I load the proper map)
2010 KTM 690 Enduro R
2006 KTM 950 Adventure S
2002 KTM 400/453 EXC
EdGear is offline   Reply With Quote
Old 04-10-2012, 11:31 AM   #107
BillyD
BillyD's Avatar
Oddometer: 635
Nothing But a Bunch of Hot Air...
For naturally aspirated engines, few operational variables can have more impact on engine performance (i.e., power and torque) than altitude and intake air temperature.
Thanks to Boyle’s Law, increasing altitude or air temperature results in less air density. Less air density means less fuel going into the motor. Less fuel means less power.
As a general rule of thumb, an intake air temperature increase of 10 F has the same effect as going up 1,000 Feet in altitude.
As such, sucking hot air from between the tanks and above the engine means less power. Hot Rodders have known for decades that lowering intake air temperature results in “free” horsepower and, as Tahoeacr reported with his insulated airbox, an increase in torque as well.
I can see why the SD guys might not bother with any heat shielding on the Rotweiller set-up because their road speeds and resulting airflows are generally higher than one might expect to maintain off-pavement with an Adventure bike that is also more shrouded in its layout. In slower conditions, I would expect the space above the motor and between the tanks to become very hot on an Adventure bike.
If I were to install a Rotweiller on an Adventure, I would take great care to isolate the intake air as much as possible from engine heat and the relatively stagnant hot air between the tanks.
Doing so is simply good air flow and heat management.
Bill
KTM '08 690 RFR, '08 990Adv S (carbs), '07 640Adv, '03 540EXC, Ducati 851, Moto Guzzi 850 Lemans, Ercole & 2VT and Yamaha RD350.
BillyD is offline   Reply With Quote
Old 04-10-2012, 12:33 PM   #108
amazed
amazed's Avatar
Oddometer: 37
New air box
Billy D
Your comment has much meaning. I'm living in Denver, 5280 feet above sea and going up from there. I will be now be trying to reduce heat into the rotweiler....great information
amazed is offline   Reply With Quote
Old 04-10-2012, 07:47 PM   #109
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Was able to convert my SE to the new CPR filter set up and the results were pretty amazing. I can change the filter in 3 minutes, which makes life easier After jetting the SE for the filter, I took it for a day long trail ride and put it through it's paces. The throttle response was amazing and it seemed to pull harder also. I was concerned that the filter hanging out in the open would be a problem in dusty conditions but the filter held up well all day. looking forward to more testing in Mexico in a few weeks.
Big Thanks to Ken from ADVmachines for the jetting help and of course big thanks to CJ for hooking a brother up!
Just say'IN
crankshaft is offline   Reply With Quote
Old 04-10-2012, 07:50 PM   #110
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,063
What kind of jetting changes did you make??
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 04-10-2012, 09:06 PM   #111
emuooz
Emu
emuooz's Avatar
Oddometer: 412
So you can get the filter out of your super enduro without taking the fuel tank off ??
It's NOT a race I just want to get there First
Full Member......Quorn Schnitzel Club
http://share.findmespot.com/shared/f...mUP17SaZA5QYc5
emuooz is offline   Reply With Quote
Old 04-10-2012, 09:08 PM   #112
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
+1
Originally Posted by billyd View Post
for naturally aspirated engines, few operational variables can have more impact on engine performance (i.e., power and torque) than altitude and intake air temperature.
Thanks to boyle’s law, increasing altitude or air temperature results in less air density. Less air density means less fuel going into the motor. Less fuel means less power.
As a general rule of thumb, an intake air temperature increase of 10 f has the same effect as going up 1,000 feet in altitude.
As such, sucking hot air from between the tanks and above the engine means less power. Hot rodders have known for decades that lowering intake air temperature results in “free” horsepower and, as tahoeacr reported with his insulated airbox, an increase in torque as well.
I can see why the sd guys might not bother with any heat shielding on the rotweiller set-up because their road speeds and resulting airflows are generally higher than one might expect to maintain off-pavement with an adventure bike that is also more shrouded in its layout. In slower conditions, i would expect the space above the motor and between the tanks to become very hot on an adventure bike.
If i were to install a rotweiller on an adventure, i would take great care to isolate the intake air as much as possible from engine heat and the relatively stagnant hot air between the tanks.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 04-11-2012, 04:43 AM   #113
crankshaft
crankshaft's Avatar
Oddometer: 14,004
All I need to do is remove the tank bolts and lift the tank enough to get my hand on the Dzues in the front and the filter pops right out. Nothing needs to be disconnected, it's easy. Still working with Ken to do more jetting tweaks but so far the results have been good.
Just say'IN
Old 04-11-2012, 05:55 AM   #114
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Hi Ken,
How soon do you think it'll be before you've determined the final jetting for this air filter and can supply a jetting kit?
ktm950se
ktm950se is offline   Reply With Quote
Old 04-12-2012, 09:20 AM   #115
mousitsas
mousitsas's Avatar
Oddometer: 2,772
Riding impressions on a (properly jetted) MotoHooligan airbox on the carbed bikes were that it had about +5hp over the H2W but much reduced throttle response. I can't see why this airbox would be any different...
Old 04-12-2012, 01:39 PM   #116
Balsta
Oddometer: 400
Originally Posted by K2m View Post
I would not advise this if you are running the standard CV carbies. Restriction in the airbox plays a major roll in the working of the vacuum slide, it also determines how much fuel your jets produce. The results would be a slow throttle response, and lean jetting. Even with a wideband I would not recommend this. An FCR set up changes everything.
Then, how come the vacuum slides opens very fast even without any air filter? I just watched them with the air filter removed.
Why can't I tell any difference whatsoever in the throttle response now (with a K&N oval) compared with the OEM?
Yes, I have totally rejetted the 43 mm dia OEM carbs to fit my new setup with the 990SDR motor and the K&N.
Anyway, thinking about FCR's but I dont like the 41 mm diameter when I already had to make 43/53 mm nozzles between the carbs and the huge intakes on the SDR. I just dont like the alternative choice,,,FI neither. Any suggestions apprieciated
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Old 04-12-2012, 02:19 PM   #117
mousitsas
mousitsas's Avatar
Oddometer: 2,772
maybe its because what you noticed is response with no load?
Old 04-12-2012, 02:25 PM   #118
crankshaft
crankshaft's Avatar
Oddometer: 14,004
My experience was better throttle response... I have zero experience with the motohooligan set up, never even seen one, so not sure how to respond. I will say that my CPR filter is properly oiled, which might create some restriction for better response. I'll be on the Dyno next Tuesday, so I'll see what the numbers look like.
Just say'IN
Old 04-12-2012, 02:34 PM   #119
crankshaft
crankshaft's Avatar
Oddometer: 14,004
Just say'IN
Old 04-12-2012, 02:35 PM   #120
mousitsas
mousitsas's Avatar
Oddometer: 2,772
Point taken and dyno eagerly awaited.
Times are GMT -7.   It's 01:15 PM.
