Old 04-12-2012, 02:34 PM   #121
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
Just say'IN
crankshaft is offline   Reply With Quote
Old 04-12-2012, 02:35 PM   #122
mousitsas
Oddometer: 2,148
Originally Posted by crankshaft View Post
My experience was better throttle response... I have zero experience with the motohooligan set up, never even seen one, so not sure how to respond. I will say that my CPR filter is properly oiled, which might create some restriction for better response. I'll be on the Dyno next Tuesday, so I'll see what the numbers look like.
Point taken and dyno eagerly awaited.
mousitsas is online now   Reply With Quote
Old 04-12-2012, 08:38 PM   #123
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,159
I need to spend time with it beyond what we have done so far before I can offer a jetting package. I am hoping for something in the next 30-45 days, race testing to happen at the MX1000. I want to verify that the needle profile is right for the application.
Originally Posted by ktm950se View Post
Hi Ken,
How soon do you think it'll be before you've determined the final jetting for this air filter and can supply a jetting kit?
ktm950se
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is online now   Reply With Quote
Old 04-12-2012, 10:23 PM   #124
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Originally Posted by Balsta View Post
Then, how come the vacuum slides opens very fast even without any air filter? I just watched them with the air filter removed.
There is no load on the engine!!! You are just reving it. Things change when you put it into gear (I hope )
Anyway, thinking about FCR's but I dont like the 41 mm diameter when I already had to make 43/53 mm nozzles between the carbs and the huge intakes on the SDR. I just dont like the alternative choice,,,FI neither. Any suggestions apprieciated
Get the 39mm FCR's Remember those 43mm CV's have got a big axial through the center. So they are not 43mm. Powercell says don't get the 41's. He used both when he worked with Sutco to set up these kits. Things might be different if you were putting 41's on a SD converted for carbs.
If you fit FCR's you can "Trumpet" to the air box connection. Experiment with the runner length. HOW COOL WILL THAT LOOK AND HP TO BE FOUND CV's are shit carbs
I can not comment on your K&N's as it is your impression and goes against the general thinking.
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 04-12-2012, 11:17 PM   #125
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Gentlemen Do not waist time insulating your air boxes. Who cares about the ambient temperature at a set of lights or in crawling traffic. (Apologies to air box insulators )
There "is" a great rush of cool/normal air traveling through the steering stem area that feeds your engine. To stop swallowing hot "less dense air into your motor put something behind the radiator to divert hot air away from your intake. I got a old rear inner tube, cut a square, and cable tied it on............... To simple
In 2005 I was doing this......... look at how new the bike is. You can see the impregnated foam between the air box and the frame tube. The best solution is to divert the radiator air with a simple inner tube. Movement does the rest.
This is all you need
Old 04-13-2012, 06:33 AM   #126
BillyD
BillyD's Avatar
Oddometer: 598
Hey, who are you calling a "gentleman"? ;-)
I put this in the simple but effective category of air flow and heat management.
I do, however, tend to refrain from using my rubbers more than once...
Bill
KTM '08 690 RFR, '08 990Adv S (carbs), '07 640Adv, '03 540EXC, Honda XR650R, Ducati 851, Moto Guzzi 850 Lemans & 2VT and Yamaha RD350.
BillyD is offline   Reply With Quote
Old 04-13-2012, 07:14 AM   #127
EdGear
Edventurer
EdGear's Avatar
Oddometer: 493
No air box to insulate with the Rottweiler.
Get out and ride
2007 KTM 990 Adventure
2006 KTM 640 Adventure
2002 KTM 400/453 EXC
EdGear is offline   Reply With Quote
Old 04-13-2012, 04:58 PM   #128
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Drrrrr good point I must try to slow down
But we have found a plentiful supply of rubbers as Billy only uses his once and so he should be good for supplying a copious amount of slightly soiled new condition S/H rubbers........ Lucky guy
Old 04-13-2012, 05:38 PM   #129
crankshaft
crankshaft's Avatar
Oddometer: 13,783
I have a thermocouple temp tester that I can use to see what the temps are in the intake area during the dyno test if you guys are interested?
Just say'IN
Old 04-13-2012, 05:49 PM   #130
BillyD
BillyD's Avatar
Oddometer: 598
I don't know about that...
I've been carrying the same one in my wallet for years. I keep hoping for that lucky night.
BTW, with so much time to kill, my air box is insulated.
Bill
Old 04-13-2012, 07:45 PM   #131
K2m
....58....
K2m's Avatar
Oddometer: 2,238
How accurate will those temperature be without the bike moving. A fan will be no substitute. If you set your jetting on a dyno it will be way rich for the street. It will need a wideband follow up on the street. Dyno operator's do not worry about this as rich is safe and people do not come back with blown engines............ And I mean customer goes off and fits a new air intake and ends up blowing it then blames the dyno. Maximum power is one step away from destruction.
I know what you mean............. Youth is wasted on the young
Old 04-14-2012, 10:31 AM   #132
crankshaft
crankshaft's Avatar
Oddometer: 13,783
The assumption you're making is that I'm doing the dyno work with some fly by night outfit that does pulls for peak HP for bragging rights. Is that what I'm gathering? I do plan on riding the bike in an 1100 mile desert race at the end of this month, so fuel economy is important. I'm also interested in reliability, which means proper fueling is important. I guess I'm interested in something between full rich and full on lean right? I can leave the T-couple sensors on the bike and data log the temps during the race also. I was meaning to do that anyway.
I also own one of these.......
Just say'IN
Old 04-14-2012, 01:38 PM   #133
Balsta
Oddometer: 341
....CV's are shit carbs
I figured out that my CV's actually were shit carbs about 4,5 years and 75000 kms from new. Running the motor with airbox removed evidenced one slide opened much faster than the other. Replaced the slower one by a new and hoppla! the new opened much faster than the remaining best of the two old. Then replaced the second old slide and what do you think occured? Yes Yes Yes!! Both sharp equal and really fast. Conclusion: The rubber diagrams stiffens with time and the slides need to be replaced to avoid poor responding CV's. They are neither any reinvestment of significance.
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Old 04-14-2012, 01:50 PM   #134
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 415
Interesting
690R & 990Adv
Old 04-15-2012, 01:30 PM   #135
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Originally Posted by Gustavo.Ramos View Post
Interesting
Very
Times are GMT -7.   It's 10:04 PM.
