Old 08-11-2012, 11:16 AM   #76
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,125
Originally Posted by Hodgo View Post
Forget that.. the 640 ADV is 70 / 260 as opposed to 140/215 on the SE.
But in laymans terms.. whats the difference ?
Anyone ?
Not sure exactly what you're asking. . . . but the first number is the spring rate (7.0 kg/mm vs. 14.0 kg/mm), the second number is uncompressed length in mm. The spring rates are so different because the 640 has a linkage rear suspension, the SE does not.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 08-11-2012, 02:29 PM   #77
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,590
Thanks Slacks... Thats exactly what I was wanting to know. Explains why such a big difference in rates.
Hodgo Spot
My North America Trip
RD07 Africa Twin, KTM 950 Super Enduro
www.facebook.com/KTM950SE
Retired.. CR500E & lots more
Hodgo is offline   Reply With Quote
Old 07-23-2013, 06:13 PM   #78
trent74
Oddometer: 77
Hey everyone,
Great thread!
I bought a SE last summer that was well setup except stock suspension. It has the Safari tank and FMF pipes with a BDCW rack and side bag mounts that work with the KTM soft bags. I weigh 185lbs without gear lower A-level dirt rider (have 2011 KTM 250XC currently) and decent track-day experience. The stock suepension felt like I was riding a plank so I had my local dealer (Carl's Cycle) (who does good valving work) revalve and ended up going to .7kg fork springs and got a custom Cannon Racecraft 9.5-11.5 Progressive spring (they build to order with specs given with about a two-week turnaround).
The front feels good and I don't dive under braking or bottom (running 1/2 turn preload). The rear is a little soft for my fully-loaded weight of probably 220. For normal riding feels pretty good but want to balance the bike better front/rear. I am currently running 12-13mm preload with static/rider sags of 46mm and 86mm without gear.
I measured without gear on a buddy's SE with an 11-13kg spring and got 39/80 at 9mm of preload (6 turns). I think I will be 45/87 with one less turn of preload (7mm) and with an 11.5-13.5 I should get 35/76 at 9mm and 40/83 at 7mm. Any thoughts between these rates? I did try a straight rate 11.5kg spring for a ride and it still felt harsh so I am leaning towards the 11-13kg. Any reason to run less than 8mm preload when using a progressive spring to keep higher in the plusher initial stroke? If any one is interested I will have my less than 1000 mile 9.5-11.5kg spring for sale in the coming weeks as well.
Thanks,
Trent
2005 DL1000
2008 KTM 950 Super Enduro
2011 KTM 250 XC
2009 Gas Gas Raga 250 Trials
trent74 is offline   Reply With Quote
Times are GMT -7.   It's 05:58 PM.
