Old 02-05-2012, 01:30 PM   #1
Orangecicle OP
Orangecicle's Avatar
Oddometer: 2,572
Best H4 bulb replacement alternatives?
My low beam on the headlight is out (US headlight). I read other threads about good H4 bulb replacements. There were many recommendations for one of the PIAA alternatives, but which one???
Orangecicle is online now   Reply With Quote
Old 02-05-2012, 01:40 PM   #2
KC-10ENG
KC-10ENG's Avatar
Oddometer: 110
http://www.rallylights.com/Hella_H4_Bulbs.aspx
Here is a good place to do some research and buy bulbs.
2014 KTM-350EXC
2008 KTM-690e
1971 Rupp Hustler
KC-10ENG is offline   Reply With Quote
Old 02-05-2012, 03:06 PM   #3
Orangecicle OP
Oddometer: 2,572
I hadn't thought about the Hellas. Thanks. What is the correct bulb, the H4 or the 9003??? Or, is there a difference?
Old 02-06-2012, 11:09 AM   #4
Off Road Ryder
Off Road Ryder's Avatar
Oddometer: 2,541
you might be surprised that many are all the same.. private labeled.. I prefer Sylvania Super whites..
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 02-06-2012, 02:10 PM   #5
RoundOz
Plenty of seasoning
Oddometer: 1,004
In my experience...
...the Silverstar Ultras are the only commonly available replacements for factory lamps that are worth trying, and at $28 or so they oughta be. On other bikes they have made some difference, more with filling in holes than getting extra distance. With the Adventure, it is almost, but not quite, a waste of time. The best benefit of buying one is that you get to keep the factory lamp as a spare...spares are good! The reflector is just crap. I am still running it but with a bi-xenon HID. Its 35 W, about $40 delivered, quite an improvement, whiter light, less amps, about 4 hours to fit if you try to do it neatly and hide your ballast in the side fairing like I did...but still, I would have hit a deer a long while back if I didnt supplement it with some LED driving lights. A 55 W HID might be better, the Euro light better again.
One thing I used to do to all my bikes in Australia was fit a 100/80W halogen bulb. I havent tried it here because you cannot generally buy them at Autozone, but they are available online at least. I put a 130/90 in the KLR600 I rode around Oz. It was a little yellow (probably taxing the OEM harness and dropping the voltage) but enough for me to see a dingo and a cow in time to avoid collisions (both on the same night! And the cow almost wiped its nose on my shoulder!)
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 02-06-2012, 02:13 PM   #6
RoundOz
Plenty of seasoning
Oddometer: 1,004
...yes I said nose...
2009 KTM Adventure
Old 02-06-2012, 04:58 PM   #7
KC-10ENG
KC-10ENG's Avatar
Oddometer: 110
http://store.candlepower.com/h4hb29003bulbs.html
Here is another location to buy bulbs from.
2014 KTM-350EXC
2008 KTM-690e
1971 Rupp Hustler
Old 02-08-2012, 09:49 AM   #8
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,474
The best H4 bulbs I have used to date in any vehicle are the IPF Fatboy II Super Clear bulbs. They cost about $80 for a pair and they put out a lot of nice clean light. The bulbs are beefy and each set has lasted about a year of use in my car in Vermont.
"The Super Clear bulbs perform at an optically equivalent level of a 195/150 watt bulb even though it has a low beam draw of only 80 watts and high beam draw of 60 watts. "
They put out more light on low beam which is where you need it since you are already cutting the beam down. They do not put as much of a load on the small wires that feed the bulb. While a 100w hella bulb will put out a lot of light it will also lead to wiring harness issues.
Seth S
Seth S is offline   Reply With Quote
Old 02-08-2012, 03:59 PM   #9
RoundOz
Plenty of seasoning
Oddometer: 1,004
Thats true - if going up substantially in watts it is worthwhile going fatter on the wire - from a light output prspective as well as safety.
2009 KTM Adventure
Old 01-05-2014, 12:47 PM   #10
RaggedClaws
Oddometer: 6
H4 LED from Electricalconnection.com
This item was shown on pg. 60 of Feb. 2014 Motorcyclist magazine.
I have no affiliation with the vendor, nor I have I tried these, however, I am keenly interested. $80 each.
same page linked here: http://bit.ly/19KA6IM
It is my understanding that the fan and heat sink are required to keep the LED emitter cool. LEDs have about 13% efficiency [at most] right now, so 7/8 of the output will be heat, and LEDs don't work well at high temperatures. As I understand it, the emitters are cooled by an aluminum heat sink, which is, in turn, cooled by the fan.
These require 25 watts of power, and I assume have workable high and low beams.
The rated output is 1800 lumens, Vs. 1050 for a std. 55/60 watt H4 bulb [according to the vendor].
Here's a link to the vendor's photo: http://electricalconnection.com/images/hl-led-h4.jpg
RaggedClaws is offline   Reply With Quote
Times are GMT -7.   It's 05:39 AM.
