Old 02-06-2012, 10:29 AM   #1
GAGARIN OP
GAGARIN's Avatar
Oddometer: 18
hyperpro preload adjuster
have send mail at the hyperpro's what about the remote preload adjuster for the rear shock for the 1150 GSA '03..........
and they answer me.....
''The BM11-1AC can be build in two ways: either in such a way, that you can fit the original BMW pre-load adjuster, OR it can be delivered with our own Hyperpro Preload adjuster..''
have anyone use the stock BMW proload adjuster to the hyperpo rear shock ?
work ok or?
photos please ?
GAGARIN is offline   Reply With Quote
Old 02-06-2012, 10:53 AM   #2
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,521
Here's a 1200 for viewing
http://www.advrider.com/forums/showthread.php?t=326277
HyperPro Shocks 2004 R1150 GS ADV
http://www.advrider.com/forums/showthread.php?t=277180
I put Wilbers on my 2003 GSA and got original style reservoir.
scooteraug02 screwed with this post 02-06-2012 at 11:03 AM
scooteraug02 is offline   Reply With Quote
Old 02-06-2012, 09:00 PM   #3
waddyp
Quite Content
waddyp's Avatar
Oddometer: 474
Yup. Bought HyperPro front and rear for my '07 12GS (in '07). Pull rear shock, send it to Klaus, he'll swap out your pre-load adjuster and send you your new and old shocks. I prefer the stock look, and have approx. 25k miles of satisfaction behind me now.
Ed in Michigan MOA 32687
'07 R1200GS
'03 Honda XR400
waddyp is offline   Reply With Quote
Old 02-07-2012, 07:39 AM   #4
Dan Căta
Dan Căta's Avatar
Oddometer: 1,648
It's just like a pump... not that hard to install the OEM adjuster. Loosen the hose to it while still installed, take it off the bike, remove the hose, unscrew the adjuster, push the piston back, fill it with the right oil and put it all back. You're done :)
Dan.
Dan Căta is offline   Reply With Quote
Old 02-11-2012, 12:10 AM   #5
GAGARIN OP
GAGARIN's Avatar
Oddometer: 18
http://www.wilddog.za.net/forum/inde...ch=99215;image
at the right is the rear shock from 1100 gs ...........at the top how can i fit the ring form oem peload adjuster?
Times are GMT -7.   It's 06:58 PM.
