02-10-2012, 02:07 PM
#16 |
Oddometer: 7,965
Transmission
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
02-10-2012, 02:25 PM
#17 | |
Sleep, Wrench, Ride
Oddometer: 4,440
Also, you might not have to split the cases for this. There is a plate outside of the cases that prevents the shift pawl from moving too far (and shifting past the intended gear). I would check that mechanism first. gear counts and ratios for the 88 NX250: 13 37 0.35 18 32 0.56 21 28 0.75 24 25 0.96 26 23 1.13 28 22 1.27
Bikes: DR350 | GR650 Street Tracker | NX650 Turbo | Catamount Cycles Events: 2013 Monkey-Butt 500 | BreckTrek 2013 Pablo83 screwed with this post 02-10-2012 at 02:47 PM |
02-10-2012, 04:59 PM
#18 | ||
www.rmariders.org
Oddometer: 2,581
This is frickin awesome.....thanks!!!!! Quote:
Awesome as well. I'll let you know. .....
John Lane - 2004 KTM 950 Adventure S, 2000 Honda XR650R Founder, Rocky Mountain Adventure Riders, a Colorado-based non-profit American Motorcycle Association Group, promoting Adventure Riding and supporting advocacy. Board of Directors: COHVCO, Supporter: TPA & NMOHVA Come join us for an amazing ride! www.rmariders.org
02-10-2012, 05:02 PM
#19 | |
www.rmariders.org
Oddometer: 2,581
Not sure yet...... I only paid $300 for this bike and honestly don't want to spend a ton of money on it. Would love to have a 'smokin' bike for $600 total. We will think it over and post as we go..... ......
02-10-2012, 10:59 PM
#20 |
www.rmariders.org
Oddometer: 2,581
blbiker56 and I spent the evening looking at pics and wondering about our colors for this bike.....
Thinking of heritage colors. ![]() On the other hand....We have the blue shock boots.....so maybe this color......
02-11-2012, 03:55 AM
#21 |
Oddometer: 168
Hi John......I have owned quite a few XRs over the years and am familiar with their pros and cons. 1st of all, ditch the K&N filter, it doesn't seal well on the XR airbox and as you have seen, will allow dust and dirt particles to pass. UNI and Twinair are good choices. The '84 RFVC twin carb engines tend to run hot in the top end and cam and rocker failures are not uncommon. Jetting just on the rich side will help keep things cooler. Third gear is also a problem with the 350s and 600s, it is weak and if it lets loose major damage can result. These bikes are a blast to ride, I had two '85s and had plenty of fun with them. Good luck with the resto.
'98 BMW F650 '92 Honda 750 Nighthawk '85 Honda VF500F Interceptor '96 XR400 "Once you go over the hill, you start picking up speed!" |
02-11-2012, 12:46 PM
#22 | |
www.rmariders.org
Oddometer: 2,581
The top end of this one was complete rebuilt by a bike shop 2 years ago....and we hope it is still in good shape. This coming week, we will pull off the top end and split the lower in half to check out the tranny. Pics coming on that.
02-15-2012, 12:22 PM
#23 |
Oddometer: 50
Suspension link
Well i spent a couple of hours tearing apart the suspension linkage. The whole linkage is metal bushings, which is awesome, because all i had to do was clean, polish, and throw some grease on the thing and its good to go. And the bearings inside of the rear suspension arm were in great shape, so i just cleaned those up. Also i decided to make the linkage look pretty and went ahead and polished it all up.
02-15-2012, 06:56 PM
#24 |
Thumper Crusader
Oddometer: 1,008
The roost boost was not only for 2 strokes; as a matter of fact, if I recall, it was made for several years specifically for the XR models (common on the 250s too). It added an additional pulse of electricity, kind of giving it a "pre-spark" if you will. Kind of like a turbo charger for your coil. They did add some power, around 2-3hp in the peak range. Noticeable? Eh, probably not. But, I think it will make starting a little easier in some situations.
"Living just to keep going, goin' just to be sane." - The Black Keys I prefer kick starters, air-cooling, and carburetors over anything. |
02-15-2012, 07:35 PM
#25 |
Oddometer: 1,368
why strip the frame? The paint looks like it's in pretty decent shape.
2009 Kawasaki KLX250S 2001 Yamaha TTR125 (Wife's bike) 2005 Yamaha FZ6 |
02-15-2012, 07:55 PM
#26 | |
www.rmariders.org
Oddometer: 2,581
The frame and some plastics will be white. The shock boots and the seat will stay the blue color. The tank will stay red.
02-15-2012, 08:14 PM
#27 | |
looking for bionics
Oddometer: 594
![]() A capacitor on the AC CDI input probably has some frequency dependencies I would think. If it had to be tuned, its probably for the high end so that Answer could claim a larger HP gain. But if it was tunable, I would want it for the low end. It would be nice to see a circuit diagram of the Roost Boost and internal CDI components. If it worked back in the day, it should still work today ![]() Since football is over, I spent an hour looking at my parts XL350 bottom end last Sunday. The 85 XL350 is the dual carb, wet sump setup versus the 85 XR350 which is the dry sump single year wonder. Other than the neutral switch and possibly the split/spring loaded balance drive gear, I think this is the same bottom end as in the 84 XR350. Need to study the parts fiche closely to see any differences. I kept this bottom end to learn about splitting Honda cases. I last split a Yamaha case over 20 years ago. The job went relatively well getting things apart. I didn't have a flywheel/rotor puller so that stayed on the crank which is still in the left side case. Piston had a hole in the top. Chucks of piston pieces were in the bottom of the case. Whatever happened to this engine was pretty catastrophic. My 5mm hex adapter rounded over on the 2nd to last case bolt. I ended up having to use the impact driver on the last two bolts after making a slot with the dremel. Good news, transmission looks OK with only surface rust on the output shaft. The clutch protected the input shaft. It shifted through all six gears. I checked this after removing the clutch and primary drive components. Some of the other parts may still be usable. I didn't spend any additional time cleaning up these parts, I had used enough propane to heat the garage and wanted to save some in the tank for other jobs later Photos: ![]() ![]() ![]()
02-17-2012, 08:13 PM
#28 |
www.rmariders.org
Oddometer: 2,581
Bryce worked a ton today.....
Well.....the news isn't as good as we had hoped.... "Houston, we have some problems." This appears to be a 'weld'. ![]() There appears to be some scaring on these parts..... ![]() Some more pics of the engine...... ![]() ![]() ![]() ![]()
02-17-2012, 08:20 PM
#29 |
www.rmariders.org
Oddometer: 2,581
some more pics.....
02-18-2012, 09:11 AM
#30 |
looking for bionics
Oddometer: 594
Did you guys check the cam chain for stretch before removing? There was only one supplier of a new cam chain that I could find when I did my XR5 engine rebuilds. The piston pin to rod clearance is something else to check.
Other than the marks on the crank, those parts look good to me. No hole in the piston
