Go Back   ADVrider > Riding > Mapping & Navigation > GPS 101 - Which GPS For Me
Thread Tools Search this Thread Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
Old 03-21-2013, 08:23 PM   #106
ghostryder
made it
ghostryder's Avatar
Oddometer: 5,955
Originally Posted by F650Dakar_Norway View Post
Yup. The City Navigator Europe 2013.10 2D ( not 3D).
I got nothing afterthat....I had the same problem but I didnt have the correct map selected.
ghostryder is offline   Reply With Quote
Old 03-24-2013, 08:36 PM   #107
F650Dakar_Norway
What off-season?
F650Dakar_Norway's Avatar
Oddometer: 960
It appears that Basecamp Mac OS is simply schemed as a basic main route, highway-style user interface. It displays the City Navigator 2013.10 details like backroads and dirt roads at poorer zoom range ( max 1.5 kilometres ) than its PC equivalent.
Any alternative map planning tools out there for us Mac users? Basecamp Mac is just crap and totally useless for dual-sport planning.
Norway
Current stable:
2010 BMW F800GS
2008 KTM 690 RFR
1994 Honda ST1100
F650Dakar_Norway is offline   Reply With Quote
Old 04-13-2013, 05:20 AM   #108
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,202
Since this seems to be the biggest BaseCamp vs. Mapsource thread, here's my question.
When creating routes in MapSource, my habit had been to let it autoroute between my start and end points, then using the arrow tool, click on the route and drag it (rubber band it) to the road I wanted it to be on. This gave me excellent control of where the route ran.
Now, trying to do the same with BaseCamp, the only thing I have found that is roughly equivalent, is the "pencil with the plus sign next to it". However, if I first create the route with start and end points and then use the pencil+ tool, it seems to want to add all sorts of stupid loops and crazy double-back sections to the route, in short, it makes a total mess of it. If I have only a start point and no end point, I can use the pencil+ tool to touch each point along the way and lay out the route that way, but frankly this is more time-consuming than allowing an autoroute between two points then only changing sections you don't like.
So, is there a way in BaseCamp to have it autoroute between a start and end point then drag the route in various places onto where you want it to be? The arrow tool in BaseCamp just wants to draw a box on the map.
Old 04-13-2013, 06:15 AM   #109
ghostryder
made it
ghostryder's Avatar
Oddometer: 5,955
I have a mac, and If I hold the "option" button using the arrow I can drag the route. Now what I found is that there are certain "way points" that are created in the route ( little black dots along the way). I will sometimes have to go into the route and delete those points, or move them along the route to keep it from going nuts. And for the record....I hate the way base camp works with routing now. It was so much easier the other way.
Old 04-13-2013, 06:44 AM   #110
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,202
Thanks for the info!
Old 04-13-2013, 08:32 AM   #111
Steve W
Old Grouch
Steve W's Avatar
Oddometer: 670
There's a way to change this so the route editing works like MapSource in the Mac version of BaseCamp.
1. Run 'Terminal'
2. Enter the following command exactly as shown.
defaults write com.garmin.BaseCamp NoOptKeyToMoveUserDataKey -bool true
3. Run BaseCamp to verify that the drag behavior has changed.
Note: to revert BaseCamp to its previous state enter the same command as above, but change the 'true' to 'false'.
This resulted from This Thread that I initiated on the Garmin forum.
SW
The Weather in my Backyard
Steve W is offline   Reply With Quote
Old 04-13-2013, 09:03 AM   #112
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,202
1. Run 'Terminal'
Hmm. Is that a Mac-specific instruction? I read your linked thread and it appears thaty it is. Would it work when entered from a Windows DOS (command) prompt?
Old 04-13-2013, 09:08 AM   #113
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 6,130
Watch the "Video Tutorial" all the way through. I'm amazed at how few folks actually watch these and/or read the Help files (all found under Help) when they can't figure it out - I read the complete Help doc and watched all of the Vid's.
Cheers,
Dan - All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is online now   Reply With Quote
Old 04-13-2013, 09:16 AM   #114
Steve W
Old Grouch
Steve W's Avatar
Oddometer: 670
Mac specific I'm afraid. The post I quoted was from a Mac user. The only real similarity between the Windows and Mac versions is the name.
SW
Old 04-13-2013, 09:26 AM   #115
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,202
Cheers,
Oh, I did, and I tried what it said. The problem there is that the Move Point Tool does not work on a section of route where there is no point of any kind, at least as far as I could tell. It does not allow one to "grab" the route anywhere you like and rubber-band it to where you want. It may allow you to grab a way point or some other kind of point, but what do you do if there are none near the section you want to rubber-band?
Old 04-13-2013, 09:28 AM   #116
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,202
Thanks. I've now posted the question over there under the Windows branch and will report it here if someone offers a solution.
Old 04-13-2013, 09:30 AM   #117
DRTBYK
DRTBYK's Avatar
Oddometer: 6,130
Okay, if you use the linky in the Help pull down on your Windows PC it will take you to the Garmin Learning Center for BaseCamp and there is a set of Vid's for your PC.
Cheers,
Old 04-13-2013, 10:27 AM   #118
DRTBYK
DRTBYK's Avatar
Oddometer: 6,130
The Route Edit workflow is much less intuitive on Windows. You must use the Point Insert Tool.
Cheers,
Old 04-13-2013, 11:47 AM   #119
JSolo
Oddometer: 9
I'm a very keyboard oriented person. Could whip up a route in mapsource in minutes. Basecamp takes longer.
The rubberband function still works in basecamp similar to mapsource.
You need to select the route with the Select tool (S), then use the Insert (I) tool to get the rubber band. Select tool looks like a regular cursor, Insert sort of like a pencil.
JSolo is offline   Reply With Quote
Old 04-13-2013, 01:54 PM   #120
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,202
Thanks for the info guys, I'll give it another go. Perhaps my technique is just flawed.
HTML code is Off
Times are GMT -7.   It's 01:19 PM.
