Old 03-13-2012, 02:08 AM   #31
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,063
Could you list #numbers please?
If possible?
Thnx.
gefr is online now   Reply With Quote
Old 03-13-2012, 04:18 AM   #32
Orangecicle OP
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,100
Originally Posted by gefr View Post
If possible?
Thnx.
Sure. http://advrider.com/forums/showpost....2&postcount=23
Orangecicle is offline   Reply With Quote
Old 04-03-2013, 11:34 AM   #33
keener
Speed changes you.
keener's Avatar
Oddometer: 978
worked!
Originally Posted by Orangecicle View Post
Here's the list of what is needed:
http://www.advrider.com/forums/showp...60&postcount=8
  • 6011301200033 -- the front line (1)
  • 60101078000 -- the triple bracket (1)
  • 0603100141 -- banjo washers (6)
  • 50213025000 - new banjo bolts. (2)
  • 60101077000 - brake line guide for triples. (1)
  • 60101079000 - another guide (1)
  • 0012060164 - screws to mount the plastic guides (3)
You may or may not need the triples bracket. I bought one separate, and then the line came with a bracket attached. You really only need one new banjo bolt because you can reuse all but one of the old ones.
Also, notice that I moved my speedo cable as well. I cut off the hard plastic from the wire and then taped the wire to one of the brake lines.
I followed Orangecicle's list and everything worked just find for my 04 950 ADV which is supposed to be the tallest year as far as I know. Even with my one inch bar raiser I had no issue with the length of the line (almost no slack left).
I was surprised my lower and upper triple clamps had all the needed holes pre drilled and tapped.
My new brake line came with a triple bracket (#60101078000) too. It seems they always include it. I would order more copper washers as they have a tendency to get lose, how would I know.
Stock 2004 950 ADV brake line length is 48 5/8"
New brake line (#60101077000)
overall length: 49 1/2"
From reservoir to triple bracket: 17" (see the photos)
thank you Orangecicle
I didn't The new guide is smaller. The stock older model is bigger with an extra hole for speedo. I installed the other smaller new guide (not the one shown) on the other side of and sent the brake line through that. There was a tapped hole under the top clamp already!
This is not a KTM fender in case you were wondering. Its made by Polisport http://www.polisport.com/motorbikes/produtos.php?ID=554
I must send the lines to the inside of the forks after I install the fork protectors and a new hose guide on the right side just like the one on the left. I was just nervous with the line getting caught by the tire knobs.
04 ADV 950
keener is offline   Reply With Quote
Old 04-03-2013, 01:18 PM   #34
Orangecicle OP
On a "Quest"
Oddometer: 3,100
Awesome. Glad it worked for you
Old 04-03-2013, 01:27 PM   #35
DirtyADV
DirtyADV's Avatar
Oddometer: 2,358
Would anyone else want to do this I have a brake line from a 2005 S model, 245mm suspension travel.
Brake line some plastic holder, just secured it to the old style fender with some zip ties.
Since I got the Pyndon 320mm travel I wont work anymore so have to go custom just need to sort out the fork protection since the stock low fender isnt covering as it should anymore.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is online now   Reply With Quote
Old 04-03-2013, 03:55 PM   #36
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,052
I would be interested in it. I have a 03 Aventure with a high guard and need the 1 into 2 line. Would your line be too long?
Could you PM me how much you want for it?
Cheers.
rossguzzi is offline   Reply With Quote
Old 01-07-2015, 05:12 AM   #37
Mattithyahu
Mattithyahu's Avatar
Oddometer: 41
Do I see this right? Is upper brake hose that leads to reservoir on the right side??
Any tensions when turning handlebar?
Mattithyahu is offline   Reply With Quote
Old 01-07-2015, 05:18 AM   #38
rinho
Rinho Féroce
rinho's Avatar
Location: back in France but Soul still in North America
Oddometer: 1,146
Yes, on the right side and no tension (all the line turn with the handlebar/fork)
Sans un sou mais plus riche qu'avant
rinho is offline   Reply With Quote
Old 01-07-2015, 05:37 AM   #39
Mattithyahu
Oddometer: 41
Oh, yes it does! I'm stupid! Had old line route in my mind... Thank you =)
Old 01-16-2015, 10:00 AM   #40
Mattithyahu
Oddometer: 41
Would it be too much trouble for a few zoomed in pictures? Triple bracket on top and fender on bottom of my triple clamp just dont work... Do you have some sort of spacers installed?
Old 01-16-2015, 03:36 PM   #41
rinho
Rinho Féroce
rinho's Avatar
Oddometer: 1,146
Close enough?
This is a 2010 690 fender
I had to cut the 2 "horns" on the top of the fender.
Not sure but I think using a 950SE fender would have been more difficult, because of the shape.
IIRC a friend put spacer between triple clamp and fender and/or between the bracket and triple clamp
I put nothing else than the oem parts
Old 01-17-2015, 11:54 AM   #42
Mattithyahu
Oddometer: 41
Close enough?
Yes, sir, thank you! I'll just put some spacers above my fender. I was just wondering if u managed to do it without spacers.
Old 01-17-2015, 02:26 PM   #43
rinho
Rinho Féroce
rinho's Avatar
Oddometer: 1,146
what's the lenght of your spacer?
Old 01-17-2015, 03:22 PM   #44
Mattithyahu
Oddometer: 41
I'll make 16 mm spacers. I have 5030801030030 fender
Old 01-18-2015, 12:50 AM   #45
rinho
Rinho Féroce
rinho's Avatar
Oddometer: 1,146
This one front end looks higher than mine
16 mm looks a lot
Can you put the spacer under the line bracket instead?
Or split it half/half.
Just to be sure the wheel won't hit the fender
Times are GMT -7.   It's 12:37 AM.
