Old 03-28-2012, 09:48 PM   #196
Brtp4 OP
Yea, its a friggin L
Brtp4's Avatar
Oddometer: 1,759
Originally Posted by oregoncoast View Post
Hey BP, why not just get a lighter bike to start with? Be a lot easier. What a Maroon.
"2012 Mexican 1000 on a 1972 SL350"
Ahem.
BP
BP
Atomic Moto.com
Bend, OR
Brtp4 is offline   Reply With Quote
Old 04-21-2012, 03:20 AM   #197
xr650lwolf
xr650lwolf's Avatar
Oddometer: 1
Newby
Great thread and post.
2005 XR650L Dyno Jets, FMF Q4, Battery Relocated, Eline Batt, weight 310# with gas, two sets of wheels (knobbies/dual sport)
2011 KX450F
2006 WR250F
2000 KX250
xr650lwolf is offline   Reply With Quote
Old 04-21-2012, 10:11 PM   #198
beechum1
beechum1's Avatar
Oddometer: 4,818
Send a message via AIM to beechum1 Send a message via MSN to beechum1 Send a message via Yahoo to beechum1
Originally Posted by Brtp4 View Post
Mmm, what he said.....
www.bajastarz.com \\\ 94 XR650L, 85 GL1200A
Rally Moto Kit /// Vendor Thread
Old 06-17-2012, 09:02 AM   #199
530phil
Oddometer: 9
What was the final weight on the XR?
Sent from my SCH-I500 using Tapatalk 2
530phil is online now   Reply With Quote
Old 06-17-2012, 10:06 AM   #200
Brtp4 OP
Brtp4's Avatar
Oddometer: 1,759
It is still in process, but getting close. Motor has been rebuilt, head ported, new cam, etc. Frame is being modified, tank mounts changed to XR600 style, oil cooler mounts added, and subframe is being braced. These details will actually add weight, but they will make the bike better overall and are thus worth it. I am going to do a full build thread when done, but for now, here are some pics on The Blue Hole (Facebook):
http://www.facebook.com/media/set/?s...6344858&type=3
FWIW, I still think I will be able to get to the 300 lb mark.
BP
BP
Atomic Moto.com
Bend, OR
Old 06-21-2012, 04:14 PM   #201
RonZacapa
RonZacapa's Avatar
Oddometer: 28
Great thread this! Have been beevering away at my own South African weight loss program with the 650L over the last year or so. Down to 141kg dry now (no gas) - 310 lb and happy for it.
The 650L was introduced to SA for the first time in Nov. 2010 - 20 years late!. What has HONDA been thinking all these years?
As far as XR's are concerned we have had them all over the last 30 years in SA, from XR200R to XR600R but just not the 650L.
My view on things XR650L related: Great bike, can go real gnarly places with relative ease. Shedding a few pounds helps and the bike is a pleasure to ride for the low to upper midrange torque it has, and plenty of it too. Will be watching this thread closely.
One area of weight loss: Cutting all bolt threads that are too long (as in protruding)
A step up from this would be to replace all bolt fasteners (non structural areas mostly) with lightweight aluminium alloy or titanium fasteners. If that proves to be a tad too expensive consider drilling out the centre of the bolt. Since tensile stresses on any bolt (or axle) are transmitted along the outside perimeter of bolt i guess that an M8 bolt should be able to have a 3.6mm hole going through the middle
RonZacapa is offline   Reply With Quote
Old 06-23-2012, 07:37 AM   #202
daveyondrugs
Oddometer: 2
How about an aluminum muffler?
daveyondrugs is offline   Reply With Quote
Old 10-04-2012, 11:18 AM   #203
Brtp4 OP
Brtp4's Avatar
Oddometer: 1,759
After a busy summer, I am finally getting back on track with this. I had stripped the frame down, and weighed it at 26.68 lbs.:
After adding steering stops, XR400 oil cooler mounts, XR600R style tank mounts, and powdercoating, it has added .68/lb.
BP
BP
Atomic Moto.com
Bend, OR
Brtp4 screwed with this post 10-04-2012 at 11:26 AM
Old 02-07-2013, 01:30 AM   #204
DQook
Hawaii NX125
Oddometer: 32
Wicked
Moar!!!!
DQook is offline   Reply With Quote
Old 02-07-2013, 04:39 AM   #205
Sierra Thumper
Oddometer: 641
Laugh De-evolve it
BP
I haven't read through the whole thread, or even know if you've already done it, but removing the starter and associated bits like the battery box, relays, excess wiring etc and replacing it with a kickstart and a tiny lightweight lithium battery under the seat would dump a good portion of the weight gain the L has over the xr600.
If you swap out the huge flyweel's mass for a 600 flywheel you'd be even closer to the xr6. The L is just a xr6 with electric start and a big-ass heavy crank and flywheel for more torque.
But honestly it would be easier to just dual sport an xr600, I did an 84 xr500 and it was easy....had a real dirt bike for the street with trick USD forks and rear shock, big bore high comp cammed motor with worked head, lightweight for a thumper, and fast as hell.
I do understand your goal tho is to get the L as light as you can, and getting it closer to the xr600 its based off of would be the route to take I would think. Just reverse the process honda used to turn an xr600 into a dual sport and you should have an ass-hauling dirt bike for the street
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 02-07-2013, 09:08 AM   #206
Brtp4 OP
Brtp4's Avatar
Oddometer: 1,759
I agree. While I had the motor apart, I thought really hard about that. Came close to buying an XR600 bottom end a couple times on EBay. I figure it would shave about 20 - 25 more lbs off and really improve the throttle response. I may still do it at some point. But for now I really want to keep the e-start. Plus, at some later point I am going to turn this thing into a street tracker.
Also, pretty sure you can't switch flywheels. IIRC crank end is different, and ignition system also.
BP
BP
Atomic Moto.com
Bend, OR
Old 02-07-2013, 09:22 PM   #207
Sierra Thumper
Oddometer: 641
BP
I agree, it might be a bit more complicated then it sounds.....but imagine the difference in handling you'd get dumping that much gyroscopic weight off the bike, it would transition way quicker, and feel like you lost alot more than 25lbs I bet, and spin up a lot faster as well
Thats one reason that even tho the gsxr-600 is only a couple lbs lighter than the 750......every test rider says the 600 handles substantially better....less gyroscopic rotating mass in the engine to slow down handling
Old 03-17-2013, 08:57 AM   #208
flatfender
flatfender's Avatar
Oddometer: 769
I put mine on a diet also. It was getting pretty porky with all the unnecessary long range type stuff added. I cannot get near the numbers talked about in this thread.
If starting with the lighter 600R frame for measurement purposes minus its 98 pound engine (so start at 189 pounds), add the 650L engine (114) an oversize tank holding 4 gallons of fuel (24) and a Shorai battery (1.5) the sum is 328.5 and will still need a few more things to make it street legal.
Then add things that make it better, oil cooler, steering damper, 650R Ricochet skid plate, on mine heated grips too. I have also cut the wiring harness in half and am using only the bare legal limit of lighting compliance. I have calculated weight is ~340 wet.
I really applaud you for your weight savings, this will be a top tier build when done, I would really like to see more pictures, thanks.
1998 XR650L Dualsport
flatfender is offline   Reply With Quote
Old 03-17-2013, 09:05 AM   #209
joexr
joexr's Avatar
Oddometer: 750
Mine is 320 full of gas. Stock tank and battery. Has Harley oil cooler , 320mm rotor and Acerbis bark busters adding to weight.
Old 03-17-2013, 11:17 AM   #210
flatfender
flatfender's Avatar
Oddometer: 769
Wow, 320, by my calculations 320 is about what a stock XR600R with the Acerbis tank would weigh full of fuel. I'm guess you have supermoto tires? Are they that much lighter? What are you using to measure the weight?
Times are GMT -7.   It's 02:55 PM.
