Old 02-18-2012, 05:56 PM   #46
elsalvadorklr
Oddometer: 3,967
thanks guys!
Im assuming they are similar in weight yet come on the conventional weigh a ton!!!!!!!! well see
I had the rsw brace and stock xr wheel with and excel black rim.
Oversize stainless spokes though string again weigh more than stock.
I also gained a bit going oversize and excel on the rear of my xr600...unfortunately I dont know how much I gained...
what I do know is my wheels are stronger! and at least the weight is down low...but rotational mass once again.
Also going to usds you have less unladden weight going up and down...right?
well
again Im eager to see the numbers...
I wish I could help. I have a ton of old crappy stuff and new stuff still to put on or weighable...at least...
I changed my frint fender to a crf fender and did the vent mods...
maybe shaved some there...
but I gained putting on some cycra pro bars, and risers...
lost a bit though going to aluminum fatbars. jajaja
it GOES BOTH ways as we all can see now!
elsalvadorklr is offline   Reply With Quote
Old 02-18-2012, 06:02 PM   #47
therealbigman
bout a dollar 3.98
therealbigman's Avatar
Oddometer: 3,071
Originally Posted by Brtp4 View Post
And directional changes, which the L sucks at.
BTW, I read somewhere that CW removed 1.9 pounds from the flywheel. I can't find the post, an anyone confirm this?
Marko, do you have the snorkel?
Thanks,
BP
Yep , I get the snorkel tomorrow .
Marko
08 xr650l 99 xr650l 84atc200s 85atc200s 80ct110 99xr70 04xr50 85atc70 87trx70
Dumb ass people do dumb ass things
therealbigman is online now   Reply With Quote
Old 02-18-2012, 06:04 PM   #48
therealbigman
bout a dollar 3.98
Oddometer: 3,071
Originally Posted by elsalvadorklr View Post
thanks guys!
well
I've got the pics of both sets of legs , gotta load em up ,
and some other stuff .
Marko
Old 02-18-2012, 06:13 PM   #49
elsalvadorklr
Oddometer: 3,967
I eagerly await!
are they crf250 or 450?
mine will be 2003 cr250r...
thanks again
p.s happen to know the difference in weight between an xrl/xr600 front wheel(with spacers and axle) compared to a crfx?
The xrl rim BTW is thicker than the xr600 for those that wanted to know.
I did not know however that the crf axle and spacer were aluminum! thats a siginificant chunk to save there...
cheers
Old 02-18-2012, 06:18 PM   #50
therealbigman
bout a dollar 3.98
Oddometer: 3,071
I eagerly await!
thanks again
cheers
I do have this ,
This is an OEM XRL front hoop
and here is the Takasago hoop , same size .
I'm wondering if the OEM would be stronger , the edge is quite a bit thicker .
Marko
Old 02-18-2012, 06:25 PM   #51
elsalvadorklr
Oddometer: 3,967
interesting!
I was under the impression that excels were actually heavier than stock.
hmm I need to weigh my stock xr600 rim(should be lighter than the xrl, the xrl is stronger than the xr...its designed to hold a passenger, and is thicker...also has less holes! jajaja)
wish I had a good scale like you have
Old 02-18-2012, 06:34 PM   #52
therealbigman
bout a dollar 3.98
Oddometer: 3,071
Lets not forget an add-on that almost all of us do ,
a set of Cycra Guards , seems like alot of weight to be adding at the highest point on the machine ,
but they are fuctional, and good looking to boot.
Marko
Old 02-18-2012, 06:45 PM   #53
Pthurman
gunga galunga
Pthurman's Avatar
Oddometer: 66
I sure would love to have an excel sheet created with weights. Anybody up for it?
"I'm going to give you a little advice. There's a force in the universe that makes things happen. And all you have to do is get in touch with it, stop thinking, let things happen, and be the ball."
Pthurman is offline   Reply With Quote
Old 02-18-2012, 06:52 PM   #54
therealbigman
bout a dollar 3.98
Oddometer: 3,071
Get yourself almost 5 oz with the difference between the OEM front hub w/bearings compared to a Talon hub w/bearings
Bunch of $$$$$$$$$$$$$$$$ for 5 oz,
Marko
Old 02-18-2012, 06:57 PM   #55
therealbigman
bout a dollar 3.98
Oddometer: 3,071
I would think that Excel wheels would be within an ounce of each other for same application ,
meaning a 21 x 1.6 Takasago , or the A60 , or whichever other model they make in that size would be so close , 32 hole , 36 hole , diff or shavings for 4 holes .
Thats just me thinking , I could be completely wrong .
Marko
Old 02-19-2012, 09:21 AM   #56
bomber1965
Duel
bomber1965's Avatar
Oddometer: 2,198
someone did this with an xr250l....
http://justxr.com/jh_info/xr250ldoc.html
"If you can't be a Professional, at least look like one."
bomber1965 is offline   Reply With Quote
Old 02-19-2012, 11:36 AM   #57
therealbigman
bout a dollar 3.98
Oddometer: 3,071
Marko
Old 02-19-2012, 11:39 AM   #58
Brtp4 OP
Yea, its a friggin L
Brtp4's Avatar
Oddometer: 1,759
Well THAT wasn't really worth it....sorry...
I am heading off to get these:
OEM CRF-X Forks 20.03
Rox Bar risers .8
OEM Crf rim 3.28
BRP Lower triple w/o stem 1.64
Emig stem .7
Acerbis 5.8 tank 8.34
Baja designs headlight
BP
BP
Atomic Moto.com
Bend, OR
Brtp4 screwed with this post 02-19-2012 at 12:57 PM
Brtp4 is offline   Reply With Quote
Old 02-19-2012, 11:46 AM   #59
therealbigman
bout a dollar 3.98
Oddometer: 3,071
OEM CRF-X Forks
Rox Bar risers
OEM Crf rim
BRP Lower triple
Emig stem
Acerbis 5.8 tank
BP
Damn , I have a bunch of that stuff , why you going after that stuff , Just to weigh them , or you gonna do some swapping ?
Marko
Old 02-19-2012, 11:59 AM   #60
Brtp4 OP
Brtp4's Avatar
Oddometer: 1,759
To weigh them. I have a CRF front end on it now, but I have another set of forks for my XR250R. Same goes for the BRP lower and the Emig stem. The Acerbis has not yet been put on, and the rim is an extra.
Pic:
BP
BP
Atomic Moto.com
Bend, OR
Brtp4 screwed with this post 02-19-2012 at 12:05 PM
Times are GMT -7.   It's 02:45 PM.
