Old 07-22-2013, 07:05 AM   #271
Prmurat
Prmurat's Avatar
Oddometer: 1,042
Great KZ400... Looks a little bit like Fenouil's one in the Cote-Cote (pre Paris Dakar race).
Prmurat is offline   Reply With Quote
Old 07-22-2013, 08:16 PM   #272
TroopThrowback
TroopThrowback's Avatar
Oddometer: 463
Originally Posted by MightyChosen1 View Post
Thats pretty cool. I have been thinking about seperating mine from the car and going solo with it. Its been fun with this combo but all the dirt riding is beating the 30 year old sidecar to death.
Are you using the stock front forks? I have been thinking about upgrading to something else. YZ-250? or something like that.
Mighty chosen, what seat is that on your side hack rig? I really like that setup, though minus the sidecar...
You running late model Bonneville shocks, too?
TroopThrowback is offline   Reply With Quote
Old 07-22-2013, 09:11 PM   #273
TroopThrowback
Oddometer: 463
Originally Posted by TomServo View Post
Here's my Scrambler project bike when I first got her a few months ago:
Not in too bad shape but the tank was beat up and had not clear coat left on it. Plus the PO had sealed the tank and let the stuff run over the outside so the tank needed to be stripped and re-painted.
Also she was missing side covers, air filters, and a petcock. The laundry list of things I've done are as follows (If I remember everything I'll be surprised)
Stripped and repainted tank and newly acquired side covers.
stripped and painted tach and speedo housings
replaced stock handlebars for new MSR dirt bike bars
replaced switch gear with modern bits
replaced throttle and brake cables
new brake shoes front and rear
new battery
new headlight bucket and 35watt H4 bulb (that's about all she can handle electric-wise)
painted wheels using rustoleum appliance paint (epoxy)
painted turn signal stalks black
chopped and painted front fender
new shinko 241 tires
rebuilt forks and cleaned up rear shocks
installed uni filters
new motion-pro brake and clutch perches and levers
Install new electronic flasher relay (old one was dead)
new points installed (tried electronic ignition but destroyed the rotor)
bar-end mirrors off Amazon.com
Here's what she looks like right now:
A few things are left to button her up. I need to replace the oil seal for the tach cable and also the countershaft seal. also need to clean up the carbs as the slides seem a little sticky at times.
What's your thoughts on the shinko 241 tires? Are they a solid 50/50 dirt/street tire? How do they wear? Deciding between 705 and 241 for my 1978 xs650 Yambler. I like the classic "trials universal" look of the 241 but haven't heard from anyone that runs them.
Troop
Throwbacks
Old 07-23-2013, 12:12 AM   #274
snorske
snorske's Avatar
Oddometer: 104
Originally Posted by Prmurat View Post
There is already a Ducati new scrambler:
http://www.bikeexif.com/ducati-terra-mostro
they are out of business
snorske is offline   Reply With Quote
Old 07-23-2013, 12:17 AM   #275
snorske
snorske's Avatar
Oddometer: 104
still one of my favorites...
Old 07-23-2013, 07:15 AM   #276
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,531
Sweet, did you pop that up on the Airhead Scrambler thread?
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 07-23-2013, 10:42 AM   #277
Wkendwrench
Wkendwrench's Avatar
Oddometer: 6
Re: Shinko 241's
Currently running 241's on my '73 CL 350.
Pro's - inexpensive, decent grip on street and dirt roads, looks period correct
Con's - wears quickly (softer compound?), noisy on road (typical knobby whine).
I will looking for a road bias dual sport replacement after the 241's wear out, doubt I'll get 1200 miles out of them in total.
Good Luck!
Some Assembly Required
Wkendwrench is offline   Reply With Quote
Old 07-23-2013, 11:33 PM   #278
KaaJa
KaaJa's Avatar
Oddometer: 47
Good Luck!
What size shinkos are you running?
Sim Salabim Bamba Saladu Saladim
KaaJa is offline   Reply With Quote
Old 07-24-2013, 06:00 AM   #279
Wkendwrench
Oddometer: 6
Re: Shinko 241's
4.00 - 18 Rear
3.50 - 19 Front
Old 07-24-2013, 08:57 AM   #280
MightyChosen1
I wanna be sedated
MightyChosen1's Avatar
Oddometer: 1,374
Seat is off a AT 1 or other early Yamaha. I,m not sure it was a swap meet find for ten bucks but it needs replaced. The pan is pretty rusty and I want to find a seat a little longer so that I can haul a passenger.
Shocks and bars are off my Scrambler. When I separate it from the car I want to upgrade the front forks as well. Maybe a set from a YZ or something like that. I rode it solo for a month this year and it was a hoot blasting thru the trails but found it a handful on the jumps.
Formally known as Furious D, I'm getting to old to be furious.
MightyChosen1 screwed with this post 07-24-2013 at 04:17 PM
MightyChosen1 is offline   Reply With Quote
Old 07-24-2013, 07:57 PM   #281
TroopThrowback
Oddometer: 463
I've got thruxtons on mine, and I picked up an early dt1 seat pan to someday work with. I've never done upholstery or foam so that will be new territory for me. It's tough because my stock seat (78 standard xs650) is in utterly terrific shape. It's just stock, not my style. I've also got a 1971 yz125 fork and front wheel, thoug the stem is about an inch short to drop in. Good thing it's remove able and the stock XS stems are too, somewhat. Ill drop the stem from the XS donor into the light, alloy yz trees. That'll double the front travel (hopefully avoiding two pitfalls: 1, bottoming the frame on the ground and 2, keeping my toes from touching!) an get the bike back more level. That's all long term plans. I just want to slap it together and play for now!
Old 07-24-2013, 07:59 PM   #282
TroopThrowback
Oddometer: 463
For tires in pretty sold in shinko 705s, just wish they had a more traditional look. Oh well, guess a MacBook Pro shouldn't look like a commodore, should it?
Old 07-25-2013, 04:01 AM   #283
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 8,438
Posted up by one of the inmates over on the Aussie thread site, droolin' material
Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - 2015], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' x2 [for sale], DT175 [new projects] x 2
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is offline   Reply With Quote
Old 07-25-2013, 04:54 AM   #284
MartinPetren
Swedish Adventurer
MartinPetren's Avatar
Oddometer: 372
Cheers
Baza
Is there a build thread or more info/pictures?
Martin Petrén
WallStreetBikes
MartinPetren is offline   Reply With Quote
Old 07-25-2013, 05:36 AM   #285
ThomasVolomitz
New Old Stock
ThomasVolomitz's Avatar
Oddometer: 4,409
Excellent build there.
https://m.facebook.com/dualsportdelinquents
Still Riff Raff
ThomasVolomitz is offline   Reply With Quote
Times are GMT -7.   It's 03:56 AM.
