Old 04-19-2012, 06:16 AM   #16
pkboxer
Oddometer: 95
Valve Cover
This may be common knowledge, but is that a special valve cover, or some kind of add on to spread the pressure of the acorn nut to more of the cover?
Exhaust is looking nice BTW.
pkboxer is offline   Reply With Quote
Old 04-19-2012, 10:11 AM   #17
lightfighter
where does this go?
Oddometer: 2,299
noice!!!!
lightfighter is offline   Reply With Quote
Old 04-19-2012, 11:27 AM   #18
Boxer Metal OP
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,570
The valve covers a 3 piece design made by Siebenrock in Germany and around 200.00 a side. Cool but not cheap.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-19-2012, 11:32 AM   #19
pkboxer
Oddometer: 95
Valve cover
What is the improvement for $200 a side?
Old 04-19-2012, 11:48 AM   #20
lightfighter
where does this go?
Oddometer: 2,299
improvement? whats that mean?
its almost like you dont have a motorcycle.
Old 04-19-2012, 12:10 PM   #21
pkboxer
Oddometer: 95
rewroded
What's the "allure"?
Old 04-19-2012, 12:47 PM   #22
Padmei
enamoured
Oddometer: 3,761
They're spilt in half vertically (& joined under the cover thing) so if ummmm.... something happens to one side then you can either work on or replace that half that's damaged. Means you can carry 1/2 a cover when racing. Or that's my take on it anyway
Padmei is offline   Reply With Quote
Old 04-19-2012, 01:18 PM   #23
Boxer Metal OP
Mad Scientist
Oddometer: 3,570
You are are correct sir.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-19-2012, 01:20 PM   #24
Boxer Metal OP
Mad Scientist
Oddometer: 3,570
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-20-2012, 11:22 AM   #25
simonboxeproject
Oddometer: 84
fellow pipe maker
Hi looks as if i am not the only one making pipes this week. your high pipes are looking good, are you going to do the joints with springs? see you have gone for a long length of pipe, are you working to some figures, or for what looks good?
i found a site that did a pipe length calculator but you know the internet it may be way off.
i have gone for a short system, mainly as i didn't have much tube about, (most has come from cutting up my standard system) also i thought it would make getting the rear wheel on and off easy. still got to chop the can about and do some sort of baffle.
simonboxeproject is offline   Reply With Quote
Old 04-20-2012, 01:23 PM   #26
Padmei
enamoured
Oddometer: 3,761
Where do you guys get the materials for making the pipes? Did you bend them yourselves or get them bent, buy the bends as they are or cut up existing? When welding the pipes is there much 'crap' from the welds inside the pipes (as in anything that would cause the exhaust flow to be impeded)?
Good work btw.
Old 04-20-2012, 01:51 PM   #27
caponerd
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,980
Those are copies of the two peice valve covers used on BMW's up to the early 50's.
BMW probably had a pretty good reason for joining the two halves together into the one-peice covers they used from the early 50's on.
caponerd is offline   Reply With Quote
Old 04-20-2012, 01:57 PM   #28
robtg
Oddometer: 709
The 2 piece valve covers would probably seal better on severely warped heads.
robtg is online now   Reply With Quote
Old 04-20-2012, 03:53 PM   #29
simonboxeproject
Oddometer: 84
parts
Hi Padmei,
I have done mine from original pipes and some pre bent tube sections. The Mandrell bent tubes are available on line over here http://www.ospreyexhaustcomponents.c...ends/c_23.html
this is where mine came from.
i did mine as follows (see pic)
1 from old pipe cut off from down pipe first bend
2 from old pipe straight section from under pot
3 new 90 deg bend
4 made from old pipe sections from near balance pipe spliced into "y" section
5 new 2" 45 deg section
6 made from parts cut from old silencer.
the pipes that i had were s/steel 38mm and i tig weld them, there is some penetration on inside as i do not blank the pipe and back feed gas in, but i take care and experiment with some off cuts to get best setting as a result the inside is not too bad.
hope this helps
Times are GMT -7.   It's 02:18 PM.
