Old 03-08-2012, 10:44 PM   #16
vade
Oddometer: 7
Used a couple of layers of electric tape on mine, worked well.
vade is offline   Reply With Quote
Old 03-10-2012, 07:52 AM   #17
matey peeps
Bead Buddy
matey peeps's Avatar
Oddometer: 3,287
If you've got a Ski-Doo shop nearby you can get really nice self adhesive cork bar insulators.
Edit: d'oh...what he said.
Sent from my DROID X2 using Tapatalk
Your $5 ticket to the buttery goodness that is Smugmug - t7Ut8i5M4CRzY
matey peeps is offline   Reply With Quote
Old 03-11-2012, 09:06 AM   #18
Motomedic
Motomedic's Avatar
Oddometer: 1,846
I use a old throttle tube, with the cable part cut off and a slit down the middle, glued and wired to the bar. When replacing grips I buy two pair and use two throttle sides, leaving the the two unused (left) grips for my bicycle.
Feike
Said James to Red Molly, Now Nortons and Greeves and Indians won't do- they don't have a soul like a Vincent '52
Motomedic is online now   Reply With Quote
Old 04-04-2012, 06:01 AM   #19
D.T. OP
One wheel wonder...
D.T.'s Avatar
Oddometer: 6,301
I put the cheapo heated grips on my new V strom. Used electrical tape on the LH side, BUT. The heat is uneven due to the LH grip being much THICKER that the right side throttle tube. Looks like I need a thinner grip for the clutch side grip to remedy this problem.
"Tough times don't last, but tough people do." Robert A. Schuler
D.T. is online now   Reply With Quote
Old 11-08-2012, 05:58 PM   #20
Splatman
ADVrider wannabe
Splatman's Avatar
Oddometer: 21
For the clutch side I used a "Lock-On Grip System by ODI Grips".. Once you remove the grip (a pain cause it's bonded on really well)
it's just like a throttle tube.. You then install the grip heater & grip to this pseudo throttle tube and install this unit to your bike with
Aluminum Lock Jaw Clamps..
Lock-On Grip System by ODI Grips: New ~ $30.00.. Available at bicycle stores.. Or.. Since you do not need the grips buy used from
Ebay for ~ $10.00.. Bought the 130mm length (115mm grip plus 2 clamps = 130mm).. One set will do two motorcycles.. Make sure
the set includes the Aluminum Lock Jaw Clamps..
Grip Heaters: I use Symtec Brand.. Complete kit (one clutch, one throttle, switch and misc) available from California Sport Touring..
If done this way the clutch side can get too hot so I prefer to use "both sides throttle" and buy replacement heaters from Symtec..
Grips: I use Scott Hurricane.. To do this properly you will need two throttle side grips (I use the other two on my mountain bike)..
Grip Glue: Install my grips with: Three Bond Griplock.. And then lightly safety wired.. Doing it this way since 2008 never a problem..
Splatman is offline   Reply With Quote
Old 11-27-2012, 08:03 PM   #21
nick2ny
nick2ny's Avatar
Oddometer: 489
Howdy all--
I got this Moose Racing grip heater kit and I got a roll of Rescue Tape too.
Do I just wrap the left bar in Rescue Tape and then stick on the heater, and put the grip over that? the instructions mention JB Weld but that seems weird.
speed limit zero
nick2ny is offline   Reply With Quote
Old 11-29-2012, 02:41 AM   #22
greer
Oddometer: 3,503
That's it. We use a shot of hairspray inside the grips as a lube/glue. Never had any need for JB Weld.
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 11-30-2012, 10:07 AM   #23
MrBob
Careening forward
MrBob's Avatar
Oddometer: 5,662
Originally Posted by nick2ny View Post
Howdy all--
There's a thread on heated grip glue floating around here. Lots of different results with hair spray and other types of glue due to heat expansion and contraction, etc.
The instructions with my Hot Grips listed a two-part, slow cure, heat resistant epoxy, which I got at Ace for 8 bucks and has withstood the test of time. Removing the grip will require trashing it but it usually does anyway.
KLX 400 dual sport
Tune in, turn on, drop out.
MrBob is offline   Reply With Quote
Times are GMT -7.   It's 07:54 PM.
