Old 02-22-2012, 01:42 PM   #1
RWAZ OP
Oddometer: 49
Springs for sidecar
I have been doing research about shocks and spring rates for a side car rig. I have a 1150 GS with a DMC sidecar. I have read on this site that it is best to increase the spring rate on the spring, have read that it helps the handling quite a bit. My bike has a Works Shock on the back and a Ohlins on the front. I have not checked the rear spring yet but the front one is the standard set up for the GS. What have you guys done with your spring rates, what did you increase them to if any.
Thanks in advance,
Roger
RWAZ is offline   Reply With Quote
Old 02-22-2012, 02:18 PM   #2
DirtyDR
Dana
DirtyDR's Avatar
Oddometer: 2,484
I only have 90,000 miles on my 1150 GS so I still have the factory shocks, sorry.
06 Ural Patrol
03 R1150 GS Sport/ Friendship II
94 R1100RS
99 Rokon Ranger
71 Rokon RT140
Hack'n the TLH
http://www.advrider.com/forums/showthread.php?t=592860
http://dirtydr.smugmug.com/
Proud Member of the Patrol Patrol
DirtyDR is offline   Reply With Quote
Old 02-23-2012, 06:35 PM   #3
DavePave
DavePave's Avatar
Oddometer: 298
See:
http://www.advrider.com/forums/showt...ght=SUSPENSION
http://www.advrider.com/forums/showp...&postcount=134
http://advrider.com/forums/showthread.php?t=712286
Good luck Hope it helps.............
DavePave is offline   Reply With Quote
Old 02-24-2012, 03:58 AM   #4
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,309
Top 2 links don't work, but the third one has some great information.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Times are GMT -7.   It's 02:47 AM.
