Old 02-23-2012, 08:28 PM   #1
ChR1s OP
Spherical Bastard
ChR1s's Avatar
Oddometer: 332
Wink Problem?
It seems the cold weather has effected the aiming of my 990's headlamp. During these cooler, shorter days, it's become most noticeable. Why is it I am better able to see the roadside tree tops illuminated rather than the roadway? Should I opt for the lower octane fuel, and run the appropriate map? Maybe add a tooth to the countershaft sprocket?
Chris
ChR1s is offline   Reply With Quote
Old 02-23-2012, 08:31 PM   #2
Dirt2007
Oddometer: 1,469
Buy a KLR, this is sure to fix your problem.
Dirt2007 is offline   Reply With Quote
Old 02-23-2012, 08:44 PM   #3
Chuckracer
More Ride, Less Google
Chuckracer's Avatar
Oddometer: 5,760
Your headlight is reflecting off the ice on the road and into the trees. It's natures way of saying, "Waddya, nuts?"
You probably need to rebuild your waterpump.
2003 Kawasaki KLR650 "Reality"
1993 Ducati 900SS "L'evento"
Chuckracer is online now   Reply With Quote
Old 02-23-2012, 08:50 PM   #4
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,166
Send a message via MSN to grinns
I vote water pump too
2012 300 EC Race
2010 690 R
2007 990 S
grinns is offline   Reply With Quote
Old 02-23-2012, 09:00 PM   #5
Iron Horse
I Make Shit Up
Iron Horse's Avatar
Oddometer: 8,460
Send a message via Yahoo to Iron Horse
Adding your own tooth the counter shaft sprocket is brilliant. Looking forward to the write up.
BTW, does anyone have the anodization map for the Austrian oil?
Oh for all those who have taken off their canisters and SAS hoses, I'd like to buy them. The two extra I've put on have worked great. Solved the vibe issues associated with the training wheels. (I'm short).
TIA.
Wandering Wapiti
Iron Horse is offline   Reply With Quote
Old 02-24-2012, 05:55 AM   #6
zedtours
zedtours's Avatar
Oddometer: 328
Hang on what happened to March.....have I come out of hibernation at beginning off April????
zedtours is offline   Reply With Quote
Old 02-24-2012, 06:32 AM   #7
dlrides
1:1.618
dlrides's Avatar
Oddometer: 4,795
Depends on the type of oil you are using.
I must work, millions of losers are depending my taxes for a check.
dlrides is offline   Reply With Quote
Old 02-24-2012, 06:34 AM   #8
Mooney 78865
Mooney 78865's Avatar
Oddometer: 124
I'm going with tire pressure..........
Mooney 78865 is offline   Reply With Quote
Old 02-25-2012, 01:31 AM   #9
Peanuts
Peanuts's Avatar
Oddometer: 1,031
You need to splice in the 4th, 5th and 6th gear limiter wires........
Peanuts is offline   Reply With Quote
Old 02-26-2012, 06:34 AM   #10
Geek
oot & aboot
Geek's Avatar
Oddometer: 25,791
Did you let any magic smoke out of the wiring?
www.motogeek.com
Old 02-26-2012, 02:13 PM   #11
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 4,397
Change the tires to something with less hookup.
cyborg is offline   Reply With Quote
Old 02-29-2012, 06:35 AM   #12
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 3,195
Smoke less crack, eat more cupcakes, check the tire pressure.
Seth S
Husaberg tank for sale: HERE
Seth S is offline   Reply With Quote
Times are GMT -7.   It's 10:20 AM.
