Old 02-26-2012, 12:23 AM   #1
Hunsta OP
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,458
2 stroke electrics
OK this may sound like a stupid question, but for someone who`s as auto electrically retarded as me, its one I have to ask.
Ive got a DT250 project going and Im trying to thin out the wiring down to a bare minimum. Seeing that the bike has no battery or lights to run, do I need have the voltage regulator hooked up?
Basicly all I can see is that theres wiring from the CDI to the coil and into the motor. Ive disconnected everything else that just ran to the head of the wiring loom that would have powered the lights and such. I turned the bike over an there was still spark to the plug.
So......am I right to proceed?
Cheers
Craig
I REALLY AM A NICE GUY. JUST ASK ANYONE WHO HASN`T MET ME.
Hunsta is offline   Reply With Quote
Old 02-26-2012, 01:38 AM   #2
Shocktower
Shocktower's Avatar
Oddometer: 9,480
You don't need a battery if your not running lights the rectifier I think IIRC is battery charging/lights
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 02-26-2012, 04:05 AM   #3
Hunsta OP
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,458
I assume thats a no to my question.
Old 02-26-2012, 06:10 AM   #4
Euromad
Oddometer: 305
I second the no need for a voltage regulator.
Euromad is online now   Reply With Quote
Old 02-26-2012, 06:30 AM   #5
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,270
stator to cdi to coil. nothing else is needed.
current bikes
stainlesscycle is offline   Reply With Quote
Old 02-26-2012, 12:16 PM   #6
Duck_Pilot
Retired Roadracer
Oddometer: 6,013
Well..........ya MIGHT wanna have a kill-switch in there someplace..........
" A man that can have patience, can have what he will." - Benjamin Franklin
"Man cannot imagine how life could be more difficult or complex. But Congress can." - Cullen Hightower
Honestly, I *do* like Socialists. They just need a little tartar sauce.
Duck_Pilot is offline   Reply With Quote
Old 02-26-2012, 02:17 PM   #7
stainlesscycle
Oddometer: 2,270
hah, yeah. maybe..
current bikes
Old 02-26-2012, 04:32 PM   #8
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,751
Well if it is going to stuff something, it would have stuffed it by now because I ran it with only the bare essentials the whole time I had it.
I only started putting the full wiring harness in just after the last time I rode it.
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Old 02-26-2012, 04:40 PM   #9
PSchrauber
PSchrauber's Avatar
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 863
You can mount a decompression valve, works too as a kill switch.
Pull lever for decompression then the engine should stall after two three spins.
If not actuate decompression lever, while holding rear brake and slip clutch.
(just for purists I know, ... )
PSchrauber is offline   Reply With Quote
Old 02-26-2012, 08:05 PM   #10
340hp
340hp's Avatar
Oddometer: 156
It's all OK.
Ground the black with white stripe wire from the CDI for a kill switch.
340hp is offline   Reply With Quote
Old 02-26-2012, 08:20 PM   #11
P 0 P E Y E
Bald rider
Oddometer: 113
Magneto ignition on your bike. No regulator or rectifier needed for engine to run.
But...if it ain't broke, don't fix it.
P 0 P E Y E is offline   Reply With Quote
Old 02-26-2012, 08:43 PM   #12
Stromius
Stromius's Avatar
Oddometer: 58
Just run the black wire from the engine/stator to either a kill switch, then coil or straight to the coil.
Stromius is offline   Reply With Quote
Old 02-27-2012, 01:37 AM   #13
Hunsta OP
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,458
Yeah all good. Just wanted to thin it out a little.
Great thats the info I needed.
I thought the way I ride would take care of that...........................Oh you mean a switch to turn the motor off.
Thanks for the help guys.
Cheers
Craig
Times are GMT -7.   It's 06:48 AM.
