Old 03-01-2012, 01:09 PM   #31
supershaft
because I can
Oddometer: 9,116
Thanks wirewrker! I forgot that it was an '81!
Old 03-01-2012, 01:15 PM   #32
supershaft
because I can
Oddometer: 9,116
Originally Posted by 00_Green View Post
Believe it or not I did think about that. I don't know their physical size is the same or even similar but i would have checked part numbers and compaired primary and secondary resistance values before swapping.
What is the combined dual coil primary resistance as wired on the electronic bikes? I can't remember right now.
Keep the primary as high or a little higher than stock and I still think swapping components is the only real test for ignition.
supershaft screwed with this post 03-01-2012 at 01:25 PM
Old 03-01-2012, 02:54 PM   #33
kaput13
kaput13's Avatar
Oddometer: 539
Another possibility you might want to double check (info courtesy of the Bum here by the way!) is to check whether the enrichener parts are on backwards. I know you say the carbs were carefully rebuilt but this is easy to do. In fact I was experiencing similar issues recently that you are describing until I found my mistake. At any rate, good luck, hope you solve it.
kaput13 is offline   Reply With Quote
Old 03-03-2012, 08:32 AM   #34
bereahorn
Oddometer: 1,070
bereahorn is offline   Reply With Quote
Old 03-03-2012, 06:11 PM   #35
00_Green OP
00_Green's Avatar
Oddometer: 92
I'm familiar with the enrichener info on Bums site. I had to read it a few (or more) times before I completely understood it. The enricheners were inspected and verified to be assembled properly while taking the carbs apart. They were inspected and reinspected after replacing the shaft orings to verify they were re-assembled right.
I'm still working out of town but hope to get home tomorrow and back on it.
00_Green is offline   Reply With Quote
Old 03-03-2012, 07:34 PM   #36
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,607
Your location says Atlanta & Memphis, is the bike in Atlanta? It sounds like you've got a handle on this, and I'm no expert, but maybe another set of eyes would be helpful. If nothing else, I've got a coil and plug wires we could swap out to eliminate that from the equation. Gimme a call, 678.469.3298.
-Brad
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 03-03-2012, 11:51 PM   #37
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 626
If the bike is in Memphis I'd be happy to offer another set of eyeballs/ears, etc.
I agree with Wirespokes that dormant bikes will take some miles to "relax" again. Just went through that with my 93 GS (and previously my 83 RT).
Current: 93 R100GS, 03 XR650R
Prior: 73 CB350, 77 R100/7, 83 R100RT, 04 XR650L
I love every motorcycle I've owned and even some that I haven't.
ignatz72 is offline   Reply With Quote
Old 03-04-2012, 04:29 AM   #38
00_Green OP
00_Green's Avatar
Oddometer: 92
Gents, Thanks for the generous offers to assit. Brad, the bike is in Atlanta. I live in Fayette County but work in Memphis. I may take you up on the offer Brad, I'll look at it again today and will probably be in touch.
Thanks again!!
Times are GMT -7.   It's 02:44 AM.
