06-09-2012, 11:22 PM
#31 |
Oddometer: 2,171
Hook up TuneEcu with your bike when it is warm. After your TPS is adjusted mark the throttle housing and grip to coincide with TPS readings of 5,10,15,25,50, and 75%. Ride bike and note the rpm at which the flat spot is and the TPS position. Add fuel in F1/F2 at this location until flat spot goes away.
06-10-2012, 10:21 AM
#32 | |
Oddometer: 60
"I don't mean to sound bitter, cold, or cruel, but I am, so that's how it comes out." Bill Hicks
06-15-2012, 05:59 PM
#33 |
Oddometer: 60
Ok, I adjusted the tps and changed the plugs again. They don't look bad. I took it to a tuner. He does not have any KTM or tuneecu experience, but said he would give it a shot. According to the dyno, it is getting off the chart rich between 4 and 5k. Right at 5k it opens up like a light switch and runs perfect. He worked with software a bit and told me to come back tomorrow as he wants to read up on the bike and software. Here is the dyno run about 10 % throttle. Look at that sinkhole.
06-16-2012, 10:26 PM
#34 |
Oddometer: 60
The tuner worked three hours on the dyno with no improvement. I unfortunately don't have the money to let someone learn the bike and software. To be fair, he was very diligent, and only charged me for 1 hour. He said tuneecu is very different than the dynojet system he works with normally. It is very rich at 10% throttle between 4k and 5k rpm. You can see the hp sinkhole on the dyno. Any tips on curing this in Tuneecu? I know some of you are experts on this topic. I can't figure out what would cause such a rich condition in only a specific range of rpm and throttle %. The bike and map are 100% stock.
