Old 05-12-2005, 10:03 PM   #61
Loadedagain OP
making chips
Loadedagain's Avatar
Oddometer: 26,732
Originally Posted by GODSPEED
I want me one of those fancy STEALTH sprockets and the smallest they make is 44T.
fuckin bastards...... we need a 38
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 05-12-2005, 10:08 PM   #62
GODSPEED
finger lickin' good
GODSPEED's Avatar
Oddometer: 2,077
Originally Posted by Loadedagain
chains? well.... that's another story... i figure i can get all ratios combined into two or three chains. two of those coming too
What kind o' chains did ya get?
Godspeed
I'd rather do it than watch it.
Those of you with spouse and SO's know this already, but man give them a big hug, and don't take anything foregranted. - MACK RIP
When 51% of the grasshoppers vote, the ants are screwed.
http://godspeed.smugmug.com/Motorcycles
GODSPEED is offline   Reply With Quote
Old 05-12-2005, 10:19 PM   #63
Loadedagain OP
making chips
Oddometer: 26,732
whatever they send... it's like a lottery... o-ring ones... i'm hopin there's a snazzy gold one in there.
Old 05-12-2005, 10:26 PM   #64
GODSPEED
finger lickin' good
GODSPEED's Avatar
Oddometer: 2,077
Who is they?
Godspeed
Old 05-12-2005, 10:28 PM   #65
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,699
From what I understand they make down to a 39 or 40.
http://www.ktm-parts.com/Merchant2/m...Category_Code=
I've got a 44 hard parts stealth coming, but they're on backorder until the 25th.
potatoho is online now   Reply With Quote
Old 05-12-2005, 10:30 PM   #66
Max Power
Secret Agent
Max Power's Avatar
Oddometer: 4,526
DID NEW X2-Ring series: D.I.D has redesigned the shape of the X-Ring to maximize wear resistance of the new 520ZVM2 and 525ZVM2 chains. These two models have also been beefed up in tensile strength to make them the ultimate chains for today's high performance sport and sport touring motorcycles. The new X2-Ring retains all the low friction, high performance characteristics of the standard X-Ring while providing a significant increase in wear resistance and overall life of the chain.
This is the shizzle.
Hi Ho Silver... Away!
Max Power is offline   Reply With Quote
Old 05-12-2005, 10:36 PM   #67
GODSPEED
finger lickin' good
GODSPEED's Avatar
Oddometer: 2,077
This is good to know.
Whatcha gonna run up front with that 44T rear?
Godspeed
Old 05-13-2005, 07:11 AM   #68
Loadedagain OP
making chips
Oddometer: 26,732
Who is they?
el dealero
Old 05-13-2005, 07:26 AM   #69
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,699
Currently I run a 45T stealth with either a 16 or 15 front with a chain 2 links longer than stock. I like the wheel positioned as far forward as possible, and this doesn't work so well with this combo. So I ordered a 44T rear such that 44/15 would barely fit with a stock length chain. What is it, 110 links, I think.
That's my goal anyhow, to get between 2.75 and 3.00 ratio and with the wheel as far forward as possible. Wish it were easy to calculate. Not sure all LC4 swingarms are the same length. On mine, I know that 45/15 was just shy of working comfortably with a stock chain.
Old 05-13-2005, 08:15 AM   #70
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,236
on the way into work today i checked some gear rpm speeds for ya; i need to try again on the way home as they seemed to slip out of my brain... so this is a placemarker for later:
stock gearing and chain/sprokets
IMO set to 21"
modified breathing/carb (this should matter right? - HP changes this eh? )
rear tire a 25% or more used Michelin Desert/ front a MT17 (15% or more used)
no i don't have a measure on the rear circumference...
anything else pertinent? flat ground? no wind? bonneville salt flats?
4000 rpm
1st - ~20+
2nd - ~30+
3rd - ~ um...
5000 rpm
4th - ~60-65
5th - ~70-75
6th - (I wish)
what is your desire loaded?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is online now   Reply With Quote
Old 05-13-2005, 08:20 AM   #71
Loadedagain OP
making chips
Oddometer: 26,732
Old 05-13-2005, 08:23 AM   #72
meat popsicle
Ignostic
Oddometer: 14,236
do you need some field verification?
Old 05-13-2005, 08:27 AM   #73
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Be very careful when asking Loaded a question that's this open ended....
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 05-13-2005, 08:36 AM   #74
meat popsicle
Ignostic
Oddometer: 14,236
he must be slippin' - he balked at first take.
Old 05-13-2005, 08:48 AM   #75
Loadedagain OP
making chips
Oddometer: 26,732
workin on the car all night.... i'm fuckin tired today.
Times are GMT -7.   It's 06:58 AM.
