Old 04-03-2007, 09:36 AM   #91
magli
knaetsch
magli's Avatar
Oddometer: 172
Conclusion?
Hey Loaded, did you ever put that 38 on? What was the result?
Now that it has been a while, and you have had time to test the various sizes out, what is the conclusion? Would love to here your take on the various ratios... I am looking for a second gear ratio for highway cruising, when I want to go long distance... is 17-38 too radical?
Cheers.
magli is offline   Reply With Quote
Old 04-03-2007, 11:17 AM   #92
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,865
Cheers.
I'm not Loaded, but maybe I can provide some info:
I ran 17/38 on my '02 640 Adv with a set of motard wheels. Even with the much smaller diameter 17" rear, 17/38 was just about too tall. It really takes a lot of snap out of the performance, and makes uphill twisties a strain. You really have to wring its neck.
The math says 17/42 with the 18" rear (140/80-18) would be comparable to 17/38 with the 17" rear (150/60-17). In my experience, I wouldn't go any taller than that, but I haven't actually tried 17/42 yet.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 04-03-2007, 11:32 AM   #93
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,705
17/42
See post #9, etc.
PS, Holy ancient thread revival!
Arch
Arch is offline   Reply With Quote
Old 04-03-2007, 11:51 AM   #94
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,865
Originally Posted by Arch
See post #9, etc.
Yeah, it's an oldy-goldy.
I think magli deserves a pat on the back for finding it instead of starting a new thread.
Stobie
-Albert Einstein
Old 04-03-2007, 11:54 AM   #95
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,705
Originally Posted by Stobie
Yeah, it's an oldy-goldy. I think magli deserves a pat on the back for finding it instead of starting a new thread.
Arch
Old 04-04-2007, 02:49 AM   #96
magli
knaetsch
magli's Avatar
Oddometer: 172
Hehe... cheers.
So, since I do not mind losing performance, as this would really only be a setup for covering long distance, I think that the 17-40 ratio which arch suggests in post 9 seems like a good idea, since it allows for the same chain size.
So, the only question that leaves, before I go and order these parts, is whether it is a bad idea to use the same chain: I was always told that the chain and sprockets should be changed at the same time, etc... would I skrew up my chain if I occasionally changed the sprockets?
Thanks for the replies,
Old 04-04-2007, 05:23 AM   #97
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,705
I've never worried about that on dirtbikes, where chains & sprockets are relatively (compared to easy street miles) short lived anyway.
Arch
Old 09-15-2009, 08:10 AM   #98
Bo_9
Oddometer: 191
Anyone have a copy of that handy LC4 specific spreadsheet?
Bo_9 is offline   Reply With Quote
Old 09-15-2009, 08:37 PM   #99
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,243
Yes, PM me your email address and I will send it along. That will be my penalty for not uploading this stuff to one of two nice people who have offered space on their servers...
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 09-16-2009, 12:07 AM   #100
Loadedagain OP
making chips
Loadedagain's Avatar
Oddometer: 26,735
i swear i uploaded the spreadsheet i made to my own web site... i'm sure it's in there some place... just where... shit... i''ll look tomorrow.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 09-26-2009, 08:24 AM   #101
overlandr
Dystopist
Oddometer: 5,900
Any luck Loaded - peeped on yr WS but not readily there.
overlandr is offline   Reply With Quote
Old 09-26-2009, 10:15 AM   #102
montesa_vr
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,902
KTM 640 gear ratios
gear__Primary ___ Final __ first__ second __ third __ fourth ___ fifth
ratio__ 2.55_____ 2.63 __ 2.50 __ 1.60 ___ 1.17 ____ 0.95 ____ 0.82
teeth__79/31 ___ 42/16 _ 35/14 _ 24/15 __ 21/18 ___ 19/20 ___ 18/22
overall ________________ 16.72 __ 10.70 __ 7.80 ___ 6.36 ____ 5.47
See five speed vs. six speed, some surprises
http://www.advrider.com/forums/showt...=281742&page=9
montesa_vr is offline   Reply With Quote
Old 10-21-2009, 12:00 AM   #103
hot101rod
hot101rod's Avatar
Oddometer: 12
New rear sprocket
My 640 was geared way to low for what I was doing. I ordered a custom rear sprocket from Krause Racing 37 tooth, I can now run down the hwy when I need to and do 65 at 5000 rpm. I have a 17 in front, this is the highest gearing I could find anywhere. OK not for everyone but it works for me!
Watch the chain backlash on the swing arm, it will cut it on top behind the chain slider.
Rod
hot101rod is offline   Reply With Quote
Old 03-28-2011, 06:20 PM   #104
bikepikespeak.com
bikepikespeak.com's Avatar
Oddometer: 598
17-45?
I'm trying to see if anyone has run this combo at all? I can't find anywhere that someone has so far. I have an 06 (comes stock w/ 16-42) Gearing seems pretty good all around. I think I WOULD like maybe a touch lower for my offroad stuff, but don't want to sacrifice TOO much of the hwy stuff. I was thinking that maybe this combo would do that for me? I don't understand much at all about gear ratio's...so all those numbers in the other posts don't mean anything to me. Too bad this can't be like riding a bike. You just push a trigger and get into the gear you want! hhaha.
Thanks for any input!
bikepikespeak.com is offline   Reply With Quote
Old 03-29-2011, 06:02 AM   #105
JensEskildsen
Oddometer: 1,041
www.gearingcommander.com
Type in your bike, model, year and so on, and you can play with different sprockets, to see what rpm at what speeds that gives you.
VERY helpfull tool.
JensEskildsen is offline   Reply With Quote
Times are GMT -7.   It's 02:25 AM.
