Old 04-07-2012, 04:52 AM   #46
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 837
Originally Posted by davorallyfan View Post
Runs the BM shop - makes things like injected turbo 90S's etc. Gets out and does miles when he can too, a regular at the WA border run.
No not the BM Shop, Ray Peake runs RJ's BMW out at Canungra. 07-5543 5962. He has been working on my bikes for over 20 years.
Bulldust is offline   Reply With Quote
Old 04-07-2012, 04:53 AM   #47
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 837
Wow ...any frame mods?
None to date, not really necessary as I don't anticipate using it for rough dirt work.
Old 04-07-2012, 08:24 AM   #48
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,210
Originally Posted by Bulldust View Post
I understand that, and clearly spending over $20,000 on a GSPD is a little excessive, but it will run with Ducati's in the mountains and still is comfortabe for 1,200 kilometre days. I purchased the GS to make sure the GSPD was not totalled on the cape.
1070 Seibenrock kit, long rods, cam, etc.
Nippondenso starter
450 watt alternator.
Upgraded diode board with solid mounts.
HID Headlight.
LED Driving Lights.
Ohlins Shock.
Aftermarket Sidestand.
Twin Plugged.
1982 "S" Heads with large valves.
38 mm header pipes and 2into1 Y peice
14.2 volt voltage regulator.
Custom single seat & rack.
Overhauled gearbox with relocated curclip, 5% lower 1st gear, 5% higher top gear.
Seibenrock oil proof clutch
Heated grips.
4 pot front brake caliper & braded line.
90 hp at the rear wheel.
Pulls well over 200kph (125 mph).
I just began twitching involuntarily
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 04-07-2012, 03:21 PM   #49
gsd4me OP
90% bluff
gsd4me's Avatar
Oddometer: 7,661
Pommie John; maybe you should tell us about the airhead racer that you have listed on your profile.
I think Ray is doing some subframe reinforcing on my bike, but nothng major. We only need to look at the pounding Stagehand`s bike has taken to know how strong those things are.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me screwed with this post 04-07-2012 at 11:19 PM
gsd4me is offline   Reply With Quote
Old 06-23-2012, 01:08 AM   #50
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,393
Progress update?
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 06-23-2012, 01:34 AM   #51
adventure950
Anglo-Saxon
Oddometer: 572
'A tourist sees what he went to see,
a traveller sees what he sees'
adventure950 is offline   Reply With Quote
Old 06-23-2012, 02:54 AM   #52
gsd4me OP
90% bluff
gsd4me's Avatar
Oddometer: 7,661
Originally Posted by adventure950 View Post
Ray has been clearing the decks of other work before he can get fully involved with my build. I`m not going to push him, as I`m certain that once he gets the bit between his teeth things will happen very quickly, It`s not like this is the first special he`s built.
The frame, subframe, battery box and fork sliders are off being powder coated by a bloke that "Bulldust" discovered; he`s not cheap, but I believe his work is excellent. Blue frame, subframe, crash bars and sliders, with white guard(s), R80GSPD tank and Britannia Composites fairing.
Gearbox has been rebuilt, as has the drive shaft, heads have been sitting on the shelf for some time.
Final engine specs have been decided: Siebenrock 1000cc barrels and pistons, 800cc twin plugged heads, with 32mm carbies. Ray remembered he has an engine out of an R100RT stashed away, with a good crank and near new timing chain, so looks like we`ll be using that block to attach the Siebenrock stuff to.
It will also have some of the good stuff that "Bulldust" has on his bike.
Ray just has to chase up a front rim, get it laced up, then he can assemble a rolling chassis and it`s game on.
Things come to those who wait (or something like that), I`m happy to wait.
David Hunn:
Old 06-23-2012, 02:41 PM   #53
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,393
Sure you don't want to go with a worked R65 motor? 853?
Box'a'bits screwed with this post 06-23-2012 at 03:59 PM
Old 06-23-2012, 03:00 PM   #54
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,210
That really sounds like its going to be awesome.
Old 06-24-2012, 01:32 AM   #55
gsd4me OP
90% bluff
gsd4me's Avatar
Oddometer: 7,661
It will be, but it won`t look it. Ray`s bikes usually look pretty ordinary until a closer look is taken; heaps of little stuff and great attention to detail.
David Hunn:
gsd4me screwed with this post 11-03-2012 at 04:32 AM
Old 06-24-2012, 01:33 AM   #56
gsd4me OP
90% bluff
gsd4me's Avatar
Oddometer: 7,661
No, she`ll be right; I think Ray thought I was nuts suggesting that.
David Hunn:
Old 06-24-2012, 01:49 AM   #57
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 837
Picking up your frame from the Powder Coaters on Friday, will drop it out to Ray's place Saturday morning.
Old 06-24-2012, 02:23 AM   #58
gsd4me OP
90% bluff
gsd4me's Avatar
Oddometer: 7,661
Ta.
David Hunn:
Old 10-29-2012, 04:02 PM   #59
ms-oz
Mike
ms-oz's Avatar
Oddometer: 69
GSD4ME project progress
ms-oz is offline   Reply With Quote
Old 10-29-2012, 09:16 PM   #60
gsd4me OP
90% bluff
gsd4me's Avatar
Oddometer: 7,661
Thanks for that, Mike, I certainly did get a surprise when I saw the pics here. As can be seen, the build has finally begun; many hours or work getting the fairing set up, with the instruments and idiot lights having to be put into a custom made surround to get the correct angle.
The Britannia composites fairing is a bit of a disappointment considering how much it cost. If you look at the front-on pic you will see that the left side sticks out further than the right, so consequently there is a gap between the dash and the fairing if looked at from the riders side. The fairing and dash also wobble badly, so Ray will have to tether them together and make other adjustments to get a good solid fit. He excels at attention to detail stuff like this, but it is time that could be better used elsewhere. There will be a bank of daytime running lights mounted crossways under the front of the fairing.
Front guard will be a genuine low mount R100GS, painted white. We have a second hand rear guard bought for a good price winging its way from the UK. If it is injection moulded black and in good nick it will be going on as is. If it needs painting it will be done in white.
I was originally going to fit a 32 litre R80 GSPD tank, which IMO opinion looks much nicer than the R100GSPD tank, but I wanted as much capacity as I could get. I can always change things around later if I don`t like the look of the finished product.
If anyone has any questions..........
David Hunn:
gsd4me screwed with this post 10-30-2012 at 01:38 AM
Times are GMT -7.   It's 05:52 AM.
