09-08-2012, 08:44 AM
#466 | |
Thrifty not cheap
Oddometer: 782
http://www.fordification.com/tech/engineID-V8.htm
'04 Wee Strom '89 KLR 650 (sold) KLR Chronicles, list of my Ride Reports in PA/MD: http://www.advrider.com/forums/showt...2#post18782262 |
09-08-2012, 08:46 AM
#467 | |
Careening forward
Oddometer: 5,662
KLX 400 dual sport Tune in, turn on, drop out. |
09-08-2012, 09:20 AM
#468 |
Oddometer: 1,949
>"I've got a 351 windsor motor lined up."
If you want a bigger motor just put a 289 or 302 in it... don't need to mess with the frame then, should be plenty of engines available. Those were great engines.
Whales were everywhere. On the beach, on the hillsides. One crossed the road in front of us… it was a big beluga! |
09-08-2012, 10:53 AM
#469 |
Oddometer: 7,672
RE: 3000rpm
If the original engine and drivetrain has lasted 50 years, I'm guessing it will last a while longer with proper maintenance. The speed limits back in the 60's were higher than they are now many places. It's probably worth more the closer to original it is.
Solve the World's problems with your spare CPU cycles. http://www.worldcommunitygrid.org |
09-08-2012, 11:47 AM
#470 |
Oddometer: 4,546
the 221 has tiny pistons and short stroke. It does not mind revving. You do have old tired valve springs, they will be fine at 3K but float will occur early.
You will never recoup the cost of the conversions in fuel savings. You can justify based on the joy of more horsepower, just do not fool yourself that it is cost effective. Maybe when gas is 10.00 a gallon. These cars are not aerodynamic, they will not ever get good mileage. Convert to a alternator so you have more amps and go to a good electric fan, that will help a lot. The early fans ate a lot of power for the air they move. Alternator as stated runs longer between service. Keep the gen and reg. A good core will be valuable someday as the last automotive commutator maker went out of business, and someday restorers will want yours. An efficient well balanced intake, very small 4 BBl , and new valve springs, can help a bit, might pay for its self if jetted correctly. A 221 does not need duals, but a good 2 1/4 dia single exhaust system with free flow muffler will help and can be cost effective, you will lose a bit off the line though. Rod |
09-10-2012, 06:16 PM
#471 | |
Oddometer: 87
09-10-2012, 06:47 PM
#472 | ||
Oddometer: 2,486
But I'm looking up options to hot-rod the 221 and not seeing much since it was such a limited run. In the hands of someone with too much money I've got to wonder just how high a balanced and blueprinted 221 V8 could rev (making it like an old-time Formula 1 engine for upper-RPM power), but I see the limitations he is facing. In that bit of studying, though, it does seem that the weight of the motors go up even though they are only small blocks. As they get larger, stronger front springs will be in order, too. I thought this was an interesting post for options if E85 is available locally: Re: 221 V8 Quote:
That is correct. They also had small valve 45cc chambers in the heads. Put them on a 289 with an RV cam and you have a high compression E85 fuel vehicle. The future of hot rods....oh yea my small block gets better mileage than yours. http://www.fordmuscleforums.com/gara...22-221-v8.html Mambo Dave screwed with this post 09-11-2012 at 05:53 AM |
11-22-2012, 05:21 AM
#473 |
Thrifty not cheap
Oddometer: 782
Too long without an update.
11-29-2012, 10:58 AM
#474 |
Careening forward
Oddometer: 5,662
Strayed from the path of simplicity?
11-29-2012, 01:17 PM
#475 |
Oddometer: 87
| Thread Tools | |
