Thread Tools Rating: Thread Rating: 30 votes, 4.73 average. Display Modes
Old 03-17-2012, 08:09 AM   #91
mmitchell57 OP
Vulcan Halfbreed
mmitchell57's Avatar
Oddometer: 2,193
Another hsot of the interior.
This isn't the best shot, its kind of fuzzy. I took these with my cell phone.
The stock jack and other equipment are all w/ the car.
More...
Not the best shot of the dash, but you get the idea. I found the original stereo in the trunk with the face plate. I cleaned it up and re-installed it. The plan is to get it restore and functional. Additionally, get a new stereo installed in a stealth location and have the capability to switch between the 2. It'd be really cool if when restored I can get it converted over to FM.
A low shot....
Another fuzzy picture... It gives you a better idea of the interior.
Last thing. Is this the original spare?
Projects - www.Goomra.com
1969 CB350 - Restoration Project
1962 Ford Fairlane 500 - Restoration / DD project
mmitchell57 screwed with this post 03-17-2012 at 08:25 AM
mmitchell57 is offline   Reply With Quote
Old 03-17-2012, 08:15 AM   #92
mmitchell57 OP
Vulcan Halfbreed
Oddometer: 2,193
Originally Posted by vtwin View Post
Everytime I see an old project Ford, I think about this video.
I enjoyed that video. That's where i am heading for now. Fix it and drive the hell out of it.
Old 03-17-2012, 08:18 AM   #93
mmitchell57 OP
Vulcan Halfbreed
Oddometer: 2,193
Here's the beast we've been talking about for a several pages...
I like it... I haven't seen an engine bay like this in my own driveway for close to 10 years. It's nice to see again. Now I just need to get it running.
The cross braces are out right now so that I can get to the rear spark plugs a bit easily. once I get the engine going I'll clean them up and put them back in.
Old 03-17-2012, 08:30 AM   #94
mmitchell57 OP
Vulcan Halfbreed
Oddometer: 2,193
Last picture...
I like this...
Now off to do some other small things before I head out to work.
Old 03-17-2012, 09:03 AM   #95
mmitchell57 OP
Vulcan Halfbreed
Oddometer: 2,193
ok, engine is at TDC, distributor cap is on and rotated so that point 1 is lined up with the contact on the rotor. Based on the location of the vacuum advance, I'm going to guess that I'm a tooth off. From what I understand, it shouldn't matter as long as point 1 is lined up proper. The only issue I'll run into is rotating the distributor to advance the timing. I'm going to go see if I can get it started.
Old 03-17-2012, 09:30 AM   #96
Hughlysses
Hughlysses's Avatar
Oddometer: 3,401
My guess is you'll rotate the distributor clockwise to advance the timing, so you should be OK with it as shown.
Good luck!
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses is online now   Reply With Quote
Old 03-17-2012, 09:59 AM   #97
mmitchell57 OP
Vulcan Halfbreed
Oddometer: 2,193
Well, gave the firing another shot. After trying to turn it over, no love. Shot come carb cleaner into the carb and tried again... I turned over one or twice like it wanted to fire up. I'm guessing I'm good on timing for now. My problem is related to getting fuel to the cylinders. I'm goiing to start on the carb to make sure all the ports are clean. I have a rebuild kit, so I'll pull it off, tear it down and soak it before work tonight. I'll get it back together tomorrow and try again. Hopefully I don't run into any issue w/ tearing and rebuilding it.
Old 03-17-2012, 10:09 AM   #98
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,618
Maybe pour a little gas down the carb to see if it will at least backfire or burp. I started my sleeping Willys after it sat for 10 years like that. Runs pretty sweet now.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 03-17-2012, 10:31 AM   #99
Joz
What could go wrong?
Joz's Avatar
Oddometer: 1,894
Be careful changing too many things before getting it running. At least right now you know the only thing you've messed with is the distributor. It was running (ish). I'd suggest trying to get it back to that point before tearing apart too many other things.
Like VTwin suggested: pour a little gas down the carb. It should try to do something.
Africa Twin, CRM250-AR, TLM220R, CT90, SY250
Death is more universal than life; everyone dies but not everyone lives. -A. Sachs
"Get on with living or get on with dying" Paul Rodden 71 years old
Joz is offline   Reply With Quote
Old 03-17-2012, 10:52 AM   #100
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,720
Stick the gas in a spray bottle, easier if it is misted a bit first. Also less chance of a puddle and carburator fire.
Have tools, will travel!
Old 03-17-2012, 11:38 AM   #101
Hughlysses
Hughlysses's Avatar
Oddometer: 3,401
+1 on the pouring/spraying gas in the carb to get it running. With a mechanical fuel pump, it can take a LONG time for fuel to pump from the tank to the carburetor.
I have an old 85 Chrysler 5th Avenue that was the last car my dad owned that I'm just trying to keep running. If I let it sit for a couple of months, I have to pour gas down the carb to get it to fire and sometimes repeatedly do that until fresh gas makes it up to the carburetor and it will run on it's own.
Old 03-17-2012, 04:11 PM   #102
mark883
Holding up Michoagán
Oddometer: 1,612
Absolutely +1.
You only need about a shot dumped down the throught of the carb. When those mechanical pumps lose their prime, and there's no gas in the carb bowls, and the accelerator pump is likely shot, there's no other way to really start the car.
just be careful feeding a carb with a cup of gas. If it backfires, there will be fireworks, and you'll be part of it.
I'm betting you just need gas in there now. you're close!
mark883 is offline   Reply With Quote
Old 03-17-2012, 04:47 PM   #103
ttpete
Oddometer: 6,039
If the car sat for a long time, the sock filter on the fuel pickup in the tank sometimes varnishes up and clogs. Easiest way to fix it is to blow the line out from the front. If the sock is clogged, it'll blow off the end of the line and fuel will then flow OK. Saves dropping the tank.
Old 03-17-2012, 06:09 PM   #104
Ducky 149
Oddometer: 344
O doG......... Can you get your money back???
"I can't believe I threw up in front of Dean Wormer!!!! Kent, You threw up on Dean Wormer"
Ducky 149 is offline   Reply With Quote
Old 03-17-2012, 06:57 PM   #105
mmitchell57 OP
Vulcan Halfbreed
Oddometer: 2,193
So quick to give up?
Thread Tools
Times are GMT -7.   It's 05:43 PM.
