Old 03-03-2012, 09:36 AM   #16
Kelly_O OP
Oddometer: 320
It doesn't seem as though the old 2T enduros are valued very highly in the U.S. I bought Tracy's for $200 and the PO was expecting to get less than that. He also has a DT400 Yamaha in about the same condition as Tracy's F7. I'm sure someone could pick that up for a song as well.
Dirt bikers seem to crave the current year stuff and they're willing to pay premium dollars for the new Fox or Thor gear, even though previous years stuff can be bought on closeout for as much as 90% off.
Kelly_O is offline   Reply With Quote
Old 03-03-2012, 03:14 PM   #17
Shocktower
Shocktower's Avatar
Oddometer: 9,480
Originally Posted by JeffS77 View Post
no you guys probably actually used your...everybody around here owns a bike but never rides them
Hey look at me in So Cal big truck never got it dirty but looks cool and look at all my dirt bikes, they stay clean too
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 03-03-2012, 06:34 PM   #18
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,166
Originally Posted by Kelly_O View Post
Thank You all very much. That's exactly the sort of banter I was hoping for. I now am armed with enough information to at least know what to shop for. We aren't quite ready to attempt to start the bike. We need to change fluids and complete our clean up. My wife (Tracy) is very involved in this bike, as it is hers. The clean up portion of this is actually much more than just cleaning. Tracy is studying her bike as progress moves along. She has been a passenger for many years, but has never owned a bike. This shall be her baptismal...
This pic was taken as soon as the bike was brought home. We've done some cleaning since then. The bike looks pretty stock. Does anyone know why there's a chain which runs from the brake pedal to the front engine mount? Enough for now. Thanks again, Kelly.
Another thing the chain, or sometimes a cable connected between the levers and the frame is to prevent weeds and sticks from getting jammed in between. Especially the brake pedal, which could cause the brake to lock.
fastdadio is offline   Reply With Quote
Old 04-02-2012, 09:35 AM   #19
mike in idaho
mike in idaho's Avatar
Oddometer: 127
We used to do that too, kept the brush out of the works.A great way to get just a little bit more use out of a broken throttle cable.
mike in idaho is offline   Reply With Quote
Old 04-02-2012, 10:02 AM   #20
MacNoob
MacNoob's Avatar
Oddometer: 1,657
I like your dog.
My '80 KE175 is a lot of fun. Regular injector oil in the reservoir. 10W30 in the transmission.
MacNoob is offline   Reply With Quote
Old 04-02-2012, 10:51 AM   #21
Tim McKittrick
Oddometer: 1,756
This may mot be exactly what you were after- but it does contain some very useful info on 2-stroke oils and how they differ.
http://www.klemmvintage.com/oils.htm
Tim McKittrick is offline   Reply With Quote
Old 04-02-2012, 07:48 PM   #22
lake_harley
Oddometer: 687
I read the article you linked, and some parts of the longer article it referenced. It all left me still a bit confused, especially on the TC and TC3, or is it TCW3 ratings. The longer article talks about Sea-Doo only wanting the TC oil in their engines. If I caught it right it offers better protection at higher temps, etc. etc... Sounds like a really good oil for a 2-stroke bike(?), or not? Or, is TCW3 (or TC3?) OK for air-cooled bikes?
Being rather new (again) to 2-strokes I'm still confused about what to use in the F7 175 Kawasaki I'm working on. I'm building it to a "street-tracker" theme. I'm going against much of the opinion given when I inquired about going to pre-mix, rather than keep the injection system. The injection system is gone from the bike and stored away for a future owner, injection-is-better purist. So-o-o-o, brands aside, what rating oil do I use? FWIW, I have a Sea-Doo jet ski, so I have the oil on hand that they recommend and I think I gleaned out of the article that it's TC oil. I also have TCW3 (I think) oil on hand too, since that's what I use when I decide to punish myself by (on rare occasion) using the weedeater trimmer.
Lynn
lake_harley is offline   Reply With Quote
Old 04-02-2012, 08:58 PM   #23
Tim McKittrick
Oddometer: 1,756
I found the link helpful in explaining the different bases for the oils in question and the relative differences in oils intended for injection purposes vs mixing.... My take away is that for premix the castor derived oils still provide superior film strength but cost more and have some other side effects- more smoke and possible ring/power valve sticking. Many of the synthetics are aimed toward use with injection systems.
I came upon the article while looking for a proper oil to use in my Honda RS250 race bike this season- the machine is new to me and the Castor A747 recommended by HRC is no longer available. From all I've read, the choice for this machine came down to the Maxima Castor 927 or Motul 800 2t... all are blends and have reportedly some amount of bean oil in them but none are like the oils of yesteryear. I'm going to go with the Maxima as it's easier to get my paws on.
Of course, the F7 175 in question here is hardly one to be exposed to extreme stresses- it's not a racer and it probably won't need to survive being WFO for 80% of the time. You will probably be able to use just about any oil that'll mix with decent results- if you have cases of the oil for your Sea-Doo in the shed I'd go ahead and give it a shot- Just don't go much below 35:1 unless you are going to be spending a lot of time at low RPM.
Personally, I'd stick with the injection system if it's available and functional- your engine was designed for long service with it providing the lubrication and mixing fuel and oil is a pain in the rear everywhere but at the track.
Old 04-02-2012, 11:08 PM   #24
pdxjim
Two Stroke Terror
Oddometer: 161
Your old Kwakker will run fine on any old 2T oil you put in it.
Cheap chainsaw oil will gunk it up quicker, but expensive synthetic oil will put a hole in your wallet.
The choice is yours.
pdxjim is offline   Reply With Quote
Old 04-02-2012, 11:49 PM   #25
fallingoff
Oddometer: 3,677
Castor oil
Amate of mine still puts some castor oil in his same period2t
Brings back memories when I smell it
What is the modern thinking on castor oil
Sniff sniff lol
Cheers
fallingoff is offline   Reply With Quote
Old 04-03-2012, 05:04 AM   #26
lake_harley
Oddometer: 687
Thanks Tim. I bought three F7 Kaw's and after riding the running/riding one last evening for the first time on the highway, it almost sounded like it was almost WFO at 55 MPH. The Sea-Doo oil is rather pricy as I recall from the last time I bought some, but I might use it in the current injected bike until I sell it. On the "tracker" pre-mix bike I had settled on 32:1 being a good ratio from all of comments on the pre-mix vs. injected thread I started. Your mention of not going below 35:1 would bear that out. Where I live the riding I do is almost all at 50 MPH+.
Do the Maxima Castor 927 or Motul 800 oils you mentioned stay mixed in with the gas well, rather than separate out like the article mentioned some bean oil based oils do? I remember a friend of mine, who had an OSSA years ago, always gave it a good shake, side-to-side, when he got on it.
Lynn
Old 04-03-2012, 08:57 AM   #27
Tim McKittrick
Oddometer: 1,756
On my race bikes the fuel always gets mixed the day of use... but that's more about fresh gas than the oil falling out of suspension, so I really can't comment about that. I have never had any visible separation but it can happen under the correct conditions.... another possible plus for the newer blends. Even the mighty A747 was a blended oil, not a straight castor base (who knows how much actual castor oil remains in it), and what little was left in the racer when I tore it down for inspection was still in suspension.
The old shake the bike side to side may be more of a nervous habit than anything else. The good news is most oils are colored such that they will dye the fuel once mixed- any separation will be clearly visible as dark blue/green/purple/brown sludge in the bottom of your tank.
Old 04-05-2012, 12:12 PM   #28
deerslayR
Spodely Adventurer
deerslayR's Avatar
Oddometer: 3,028
Agreed that castor brings back memories. Just doesn't do a great job lubricating the way newer synthetics and blends do. Gets gooey in the cold and is too thin in the heat. Old tech that was "cutting edge" in the 60's.
I use this:
Works well premixed (EXC 250) or in an injection tank (1970 Suzuki TC250 Scrambler). Very few fouled plugs. NO seizures. ever.
Sniff sniff lol
Cheers
AMA 'MOA
ECEA 'RA
ARRA DHMC
TCSMC: teamhammer.org
"I'm a choker!" ask me how
"They're ALL dirt bikes.....some work better than others"-----Harley Huey
deerslayR is offline   Reply With Quote
Old 04-05-2012, 12:29 PM   #29
tokyoklahoma
75%has been25%wanabe
Oddometer: 1,723
Wicked Pre_mix
Since you canned the oil injection, and are running pre-mix, you might as well make it smell pretty.
https://www.denniskirk.com/ipone/sco...prd/306097.sku
tokyoklahoma is offline   Reply With Quote
Old 04-05-2012, 02:10 PM   #30
deerslayR
Spodely Adventurer
deerslayR's Avatar
Oddometer: 3,028
Too bad they don't have one with the aroma of BACON!
AMA 'MOA
ECEA 'RA
ARRA DHMC
Times are GMT -7.   It's 09:45 AM.
