01-23-2012, 12:29 PM
#1 |
Pepperfool
Oddometer: 2,587
Oilhead Centerstand Lube Mod.
BMW provides a Pin Grease Gun hole on the Sidestand to lube it on scheduled services. (every 6000 km)
For some reason they don't do it for the Centerstand....... I got tired of my Centerstand hanging up every couple of years and needing dis-assembly to re-lube it. The pictures below show an easy mod you can do to turn lubrication into a 1 minute job. The pictures below show a GS Centerstand but I'm sure it will work on all the other models too. I have done this on a few bikes now with great success. The 1/6" hole on the opposite side is so the grease can escape and you can visually see that an adequate amount has been applied. Mod Notes: The 3 "O" Rings on each side may need replacing if badly worn Clean up any Rust on the I.D. of the bores as well as the Shafts. Deburr holes so "O" rings don't get cut upon assembly ![]() ![]() ![]()
Old enough to know better.... Young enough to try it again |
01-23-2012, 01:20 PM
#2 |
I have little to say
Why not instal standard automotive grease fittings (Zerk) and give these points a squirt of grease now and then.......
01-23-2012, 02:23 PM
#3 |
Pepperfool
Oddometer: 2,587
Why complicate things?
Now you need to drill a larger hole, (weakening the forging) you need a tap and a grease fitting not to mention there is not much meat there to begin with.........
01-24-2012, 05:51 AM
#4 |
Oddometer: 677
This looks cool, Addict. I've wondered about it myself. I agree with you about not using a zerk due to weakening the stand. How long have you had this?
F650GS (Build Date 11/11) |
01-24-2012, 07:46 AM
#5 |
I replaced the 6 o-rings, lubed everything in there and the centerstand still needs a push when the bike is on it's wheels. I guess I got used to doing so and it's not a problem anymore :)
Dan. |
01-24-2012, 09:14 AM
#6 |
Pepperfool
Oddometer: 2,587
Have you got the inner return spring installed? If not, I have found the stand will need a 'nudge' to start the return.
01-24-2012, 09:42 AM
#7 |
Pepperfool
Oddometer: 2,587
I did the initial mod on my own machine 8 years ago.
I did this post because I was in the process of doing another machine and had the camera handy.
01-24-2012, 10:12 AM
#8 |
Oddometer: 1,101
What type of grease ya using Reto?
'64 BMW R50/2 - "Gone but not forgotten" '76 BMW R90/6 '02 BMW R1150 GSA |
01-24-2012, 10:20 AM
#9 |
Pepperfool
Oddometer: 2,587
Good quality wheel bearing grease.
01-24-2012, 10:23 AM
#10 |
01-24-2012, 10:25 AM
#11 |
Pepperfool
Oddometer: 2,587
F*#K I started another oil thread!!!!
Dino if you insist on pinning me!
01-24-2012, 11:17 AM
#12 | |
Oilhead convert
Oddometer: 930
Now this thread will degrade into utter craptitude.
Regards, Mark 2003 BMW R1150GS |
01-24-2012, 11:27 AM
#13 |
Taste Gunnels!
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,149
Why are you drilling a 1/16 and then a 3/32? It looks like they are in the same place? Is the 1/16 a pilot?
____________________________________________ 2005 GS1150 Adventure - Range Rover, 2002 DR650 SE - Land Rover "Not all who wander are lost" - JRR Tolkien |
01-24-2012, 11:29 AM
#14 |
Abenteurer
Oddometer: 9
Great idea
I love simple things like this, makes life easy and maintance a breeze. Thanks for the great idea.
01-24-2012, 11:31 AM
#15 | |
Pepperfool
Oddometer: 2,587
The 3/32" fill hole is for the needle to have something to seat to so it will stay on the hole.
